TT21 operation with no ICAO address
Old December 10th 10, 01:08 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default TT21 operation with no ICAO address
On 12/9/2010 8:18 AM, Westbender wrote:
On Dec 9, 8:50 am, wrote:
On Dec 9, 7:02 am, wrote:
It seems
to indicate either paranoia or illegal activity. Is there some other
reason to be concerned about that?
Aren't those two reasons sufficient? No others that I know of.
Andy
Is this a common concern among sailplane pilots? I'm just trying to
understand the thought process behind someone wanting to fly
"anonomously" with a Mode S transponder. I don't think sailplanes
would be much good for smuggling or terrorism. The only reasonable
intent I can think of is that people don't want to be identified when
wandering into airspace they shouldn't be in. What am I missing?
If you wander into airspace you shouldn't be in, broadcasting your
position with Mode C, would you be left alone? In R or P airspace, I'm
pretty sure someone comes looking for you, but how about A, B, C, and D?
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old December 10th 10, 01:51 AM posted to rec.aviation.soaring
Andy[_1_]
I have first hand experience of being asked to "call the tower" after
an inadvertent class D incursion. I was not pilot in command at the
time.
I also had a "call approach control" after our malfunctioning encoder
made Phoenix approach think we had busted class B and caused a few
airliners to take evasive action. Again I wasn't PIC but as the holder
of the higher ratings would have been implicated. In this case it
seems that 2 transponder returns had been mixed up when another
aircraft came very close to us and the Class B violation was the other
aircraft and independent of our erroneous altitude squawk. It was good
that I had a Garmin track log and could prove we had not been where
they said we had been. Even better that our controlled passage of a
local class D was not consistent with the position of the violation
and that was all on the tower tapes.
Bottom like is, if they see you doing something wrong they'll try to
track the transponder to a point where they can identify and talk to
you. This may explain some sudden transponder failures.
Andy
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
ICAO Locations [email protected] Piloting 1 July 2nd 06 04:06 PM
ICAO Annex 6 Airwire General Aviation 0 January 10th 04 01:50 PM
