TT21 operation with no ICAO address
Old December 9th 10, 12:58 PM posted to rec.aviation.soaring
Andy[_1_]
Default TT21 operation with no ICAO address
I'm moving this to a new thread since it has nothing to do with the
requirement for altimeter TSO.
I asked what happened if a mode S transponder was installed without an
ICAO address. That was a sort of tongue in cheek reaction to the idea
that someone would not want their tail number broadcast to the Feds.
Darryl responded:
A Mode S transponder absolutely has to transmit the aircraft ICAO
address, a correctly configured ICAO address is required for the
transponder to actually work--bad things might happen if two aircraft
had the same default ICAO address were being interrogated at the same
time.
I like to continue that discussion.
Isn't it true that a mode S capable transponder cannot respond to a
mode S interrogation if it has no valid ICAO address?
Isn't it also true that a mode S transponder is also required to
respond to both mode A and mode C interrogations.
If both are true then doesn't it follow that a mode S transponder such
as the Trig TT21, if installed with no ICAO address, will not respond
to mode S interrogations but will respond to all mode A and mode C
interrogations.
If that is indeed the case then any new transponder purchaser who
wanted mode S capability in the future, but was paranoid about
broadcasting the tail number, could disable mode S responses by
leaving the ICAO address entry blank and use it just like a mode C
transponder.
Andy
Old December 9th 10, 02:02 PM posted to rec.aviation.soaring
Westbender
ICAO address. *That was a sort of tongue in cheek reaction to the idea
Darryl responded:
time.
interrogations.
transponder.
Andy
Not to derail your discussion, but why does the notion of
"broadcasting your tail number to the feds" keep coming up? It seems
to indicate either paranoia or illegal activity. Is there some other
reason to be concerned about that?
Old December 9th 10, 02:50 PM posted to rec.aviation.soaring
Andy[_1_]
On Dec 9, 7:02*am, Westbender wrote:
It seems
Aren't those two reasons sufficient? No others that I know of.
Andy
Old December 9th 10, 04:18 PM posted to rec.aviation.soaring
Westbender
It seems
Aren't those two reasons sufficient? *No others that I know of.
Andy
Is this a common concern among sailplane pilots? I'm just trying to
understand the thought process behind someone wanting to fly
"anonomously" with a Mode S transponder. I don't think sailplanes
would be much good for smuggling or terrorism. The only reasonable
intent I can think of is that people don't want to be identified when
wandering into airspace they shouldn't be in. What am I missing?
Old December 10th 10, 01:08 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 12/9/2010 8:18 AM, Westbender wrote:
On Dec 9, 8:50 am, wrote:
On Dec 9, 7:02 am, wrote:
It seems
Andy
If you wander into airspace you shouldn't be in, broadcasting your
position with Mode C, would you be left alone? In R or P airspace, I'm
pretty sure someone comes looking for you, but how about A, B, C, and D?
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old December 10th 10, 01:51 AM posted to rec.aviation.soaring
Andy[_1_]
I have first hand experience of being asked to "call the tower" after
an inadvertent class D incursion. I was not pilot in command at the
time.
I also had a "call approach control" after our malfunctioning encoder
made Phoenix approach think we had busted class B and caused a few
airliners to take evasive action. Again I wasn't PIC but as the holder
of the higher ratings would have been implicated. In this case it
seems that 2 transponder returns had been mixed up when another
aircraft came very close to us and the Class B violation was the other
aircraft and independent of our erroneous altitude squawk. It was good
that I had a Garmin track log and could prove we had not been where
they said we had been. Even better that our controlled passage of a
local class D was not consistent with the position of the violation
and that was all on the tower tapes.
Bottom like is, if they see you doing something wrong they'll try to
track the transponder to a point where they can identify and talk to
you. This may explain some sudden transponder failures.
Andy
Old December 9th 10, 03:09 PM posted to rec.aviation.soaring
jcarlyle
You're making an assumption that the Trig will actually work with no
ICAO address. It's smart enough to know when configuration is needed,
and automatically starts that process without going operational. Since
it's a Mode S transponder, and is required to have a valid ICAO
address, if I were writing the code I wouldn't let it operate at all
with a blank ICAO address. I admit I haven't tested the situation, and
I have no intention of doing so.
Further, the avionics technician will check the presence of the proper
ICAO code during the VFR transponder check (it's a Mode S transponder
so it will be checked as such), so if you subsequently blank out the
ICAO code you're making a deliberate change to the logged, tested
condition. What the legal implications are I don't know, and I'm not
going to bother looking it up since I won't be blanking my ICAO
address.
I must say I'm really sorry I started the ball rolling on Feds
tracking tail numbers in the other thread. It was not meant to be
taken seriously as an "advantage" of Mode A/C over Mode S.
-John
Darryl responded:
time.
interrogations.
transponder.
Andy
Old December 9th 10, 04:30 PM posted to rec.aviation.soaring
Andy[_1_]
For me it's more my engineer's curiosity rather than an admission of
paranoia.
According to the TT21 installation manual the installation menu is
entered the first time it is powered up. After that an overt user
action is required to re-enter the installation menus. I don't have
one yet but if/when I do I'll check it out. (even though I'm not, I
say NOT, paranoid)
Andy
Old December 9th 10, 06:10 PM posted to rec.aviation.soaring
JS
Does this mean that if the interrogator is not Mode S, the reply
will be downgraded to Mode C? From the book of Manuals, chapter 2,
verse 2.1:
The TT21 transponder responds to both legacy Mode A/C interrogations
and to Mode S interrogations from both ground radar and airborne
collision avoidance systems. In all cases, the interrogations are
received by the transponder on 1030MHz, and replies are transmitted on
1090MHz.
The idea that the unit broadcasts more information and the fact that
many of us fly at higher altitudes than the TT21 is rated for has
caused me to order a TT22. The transponders I've used in the past had
no way to tell ATC what they were, so that wasn't a problem. I don't
care about the N Number being broadcast (when you first call ATC, they
have your number to associate with your Mode C discrete squawk code)
for any other reason than it could - in future - be a problem using
equipment outside it's certified environment. Easier to pay a couple
of hundred more thingies now and have it over with.
The TT22 and certainly TT21 still use less power than, for example,
a Becker 4401-175.
Regarding the price of Mode S transponder certification, in recent
experience it's less than recertification of the pilot!
Old December 9th 10, 07:10 PM posted to rec.aviation.soaring
Darryl Ramm
On Dec 9, 10:10*am, JS wrote:
* Does this mean that if the interrogator is not Mode S, the reply
verse 2.1:
1090MHz.
* The idea that the unit broadcasts more information and the fact that
* The TT22 and certainly TT21 still use less power than, for example,
a Becker 4401-175.
* Regarding the price of Mode S transponder certification, in recent
Congrats on the TT22.
A Mode S transponder does not broadcast information about the device
power output. Technically the "class" describes the power output of
the transponder and that's just not transmitted AFAIK. Mode S
transponders do transmit (in the data register BDS (1,0)) detailed
information on all the many different data link things Mode S
transponders can implement (especially the high end ones used in
airliners etc.).
ATC cannot tell if you have a Trig TT21 or a Trig TT22 and they won't
care - the power output difference is really not significant in
practice. But if you want a TT22 to feel better about compliance with
regulation because you fly above 15,000' feet then go for it. The
important thing is to have and use a transponder where they are
needed.
And again to separate what _is_ really important - it is critical to
set up and use the correct Mode S/ICAO address for your aircraft
(issued to the aircraft by the FAA in its registration paperwork) on
any Mode S transponder at install time.
Darryl
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
ICAO Locations [email protected] Piloting 1 July 2nd 06 04:06 PM
ICAO Annex 6 Airwire General Aviation 0 January 10th 04 01:50 PM
