#11
Roy Smith wrote:
It's easy to build an electric motor which spins a disk at 10,000 RPM. It doesn't cost much either... http://shop4.outpost.com/product/3120560/ I'm not sure that 10,000 is enough. Plus, the mass you'd probably be spinning in a gyro might be greater than a disk. The mechanics of allowing the gyro to pivot in both roll and pitch, with very little friction is also not trivial. Finally, you have to do this in a manner that will withstand environmental abuse, and run for years, reliably, without killing someone. The point I was trying to make is that there are often many, many technical reasons why something is designed the way it is, and why it might cost what it does. Jay often spouts off on this type of topic without having adequate background on these types of engineering issues. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
![]() Jay Honeck wrote: Personally, I think the fact that we're flying around behind vacuum instruments in the 21st century is patently absurd. Fine. Then quitcherbitchin and spring the bucks for the electric system. You're only flying behind a vacuum system because you're a cheapskate (as am I). George Patterson If you don't tell lies, you never have to remember what you said. |
![]() David Megginson wrote: That one might not go over so well, though, since it discourages people from suing even when they do have a legitimate case. I agree, so my variation of your idea is that punitive damages go into a fund that pays the winner's legal costs. George Patterson If you don't tell lies, you never have to remember what you said. |
![]() Jay Masino wrote: I suspect it's a lot easier to get a gyro to spin at 10 or 15,000 RPM (or whatever) using vanes and vaccum, than it is to design a reliable electric motor to spin the gyro at that speed. Actually, the main problem is building them small enough. That's what makes the electric gyros so expensive. George Patterson If you don't tell lies, you never have to remember what you said. |
"G.R. Patterson III" wrote: Jay Masino wrote: I suspect it's a lot easier to get a gyro to spin at 10 or 15,000 RPM (or whatever) using vanes and vaccum, than it is to design a reliable electric motor to spin the gyro at that speed. Actually, the main problem is building them small enough. That's what makes the electric gyros so expensive. George Patterson If you don't tell lies, you never have to remember what you said. I wonder how long it's going to take for things like ring laser gyros to become cheap enough for GA use. |
technical reasons why something is designed the way it is, and why it might cost what it does. Jay often spouts off on this type of topic without having adequate background on these types of engineering issues. Actually, I was referring to the new line of solid state electric AIs -- no internal spinning parts to wear out or fail. I saw one at SNF for less than $500 -- uncertified, of course. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
You're only flying behind a vacuum system because you're a cheapskate (as am I). It's amazing when spending something approaching $1500 for two lousy vacuum instruments makes me a "cheapskate"... Gotta love aviation! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Roy Smith writes:
I wonder how long it's going to take for things like ring laser gyros to become cheap enough for GA use. While you're waiting, consider a MEMS-based system. http://www.xbow.com/General_info/gyro_guide.htm --kyler |
![]() "David Megginson" wrote in message ogers.com... zip wrote: Do you know why ultralight piilots are flying Rotax two strokes? Because the company that makes them has NO assets in the USA, liniting the damage that can be done to them by silly lawsuits. Same with motorcycle helmets, there are NO manufacturers wuth assets in the U.S. Want to save american jobs? Stop frivolous profit oriented lawsuits. It's an easy problem to fix, if you American voters cared enough to make it an election issue: just revise the law so that punitive damages in a law suite go to the government instead of the plaintiff. That violates separaton of powers and creates overlap with civil law- not a good idea, as then they make it even worse to fill their coffers. Look at how much of traffic fines are merely to fill the revenue chest rather than promote safety. MOF, many jurisdictions compromise safety to as to encourage traffic violations and the revenue they generate. For example, if I get injured by someone, and the judge and jury determine that my injuries are worth 500K plus legal costs, then I get 500K plus legal costs. If they also decide to award 50M punitive damages to teach the defendant a lesson, that money should go to the government like any other fine would. See above. If lawyers cannot hope for a cut of the (enormous) punitive damages, they'll be less likely to take on trivial litigation. See below. Another alternative is the system that we have here in Canada (and, I think, in the U.K. and other Commonwealth countries, though I'm not sure). The loser in a civil case normally pays the winner's costs, so I'm not about to The entire world outside the US has "Loser Pays"...and it works. Punitives to the government is an "easy out" with dire consequences. |
become cheap enough for GA use. While you're waiting, consider a MEMS-based system. http://www.xbow.com/General_info/gyro_guide.htm I think Garmin has found some (Comparatively) cheap solution for that in their G1000 Regards Kai |
FS: 1913 Aero & Hydro Magazine | barry | Aviation Marketplace | 0 | July 19th 04 10:39 PM |
Shop Layout Questions | GreenPilot | Home Built | 37 | July 6th 04 02:47 PM |
Things I Have Learned As First Time Buyer/Owner (long) | MRQB | Owning | 12 | April 19th 04 02:12 PM |
Avionics Shop Is Done Nice Sticker In My Log Book Total Costs | MRQB | Owning | 0 | April 3rd 04 08:21 AM |
Q re Instrument lighting upgrade by Aero Enhancement: anyone with experience? | Andrew Gideon | Owning | 5 | March 22nd 04 07:37 PM |
