Source for Euro Trailer Jack & Bracket
Old August 7th 12, 08:21 PM posted to rec.aviation.soaring
JohnDeRosa
Default Source for Euro Trailer Jack & Bracket (A.K.A Jockey Wheel)
Update - After some research, and after finding the right term to
search for (always the hardest part - "What is that thingy called?") I
have found lots of sources for the Jockey wheel (Australia, Europe)
but none in the US. Shipping is the killer, something like $80-$90
for a $30 part. I did find a beat up used item in Indiana. The
search goes on.
Old August 9th 12, 12:43 AM posted to rec.aviation.soaring
Dan Marotta
So... Why not put a locally sourced wheel on your trailer?
$35 for this:
http://www.etrailer.com/Trailer-Jack...J10000101.html
"JohnDeRosa" wrote in message
search goes on.
Old August 9th 12, 03:52 PM posted to rec.aviation.soaring
Papa3[_2_]
$35 for this:
I'm pretty sure John is looking for one where the entire screw-jack-and-wheel can be removed from the mounting bracket.
I looked at the one on my newer Komet trailer, and the bracket is definitely something that could be fabricated locally, albeit not without some effort. Two pieces of steel angle and a steel piano hinge with a threaded insert on the backing plate. A fair amount of drilling and grinding in addition to welding, now that I look at it...
Old August 10th 12, 12:25 AM posted to rec.aviation.soaring
Dan Marotta
There are many styles. The jack that I pointed out can be rotated 90
degrees which makes it parallel with the trailer tongue. Why would you need
to remove it?
"Papa3" wrote in message
$35 for this:
Old August 10th 12, 02:49 AM posted to rec.aviation.soaring
JohnDeRosa
Gentlemen,
The point is not that the "US rotate out of the way" jack is better or
worse than the Euro style. In fact I have one of the US types. Works
great.
The reason I want the Euro style is for space considerations. A
couple of reasons. 1) it is totally removable. 2) the crank is on
the top and not on the side 3) too hard to explain without twenty
seven eight-by-ten color glossy pictures with circles and arrows and a
paragraph on the back of each one.
I found a used one here in the US on eBay.
Thanks, John
Old August 10th 12, 03:33 AM posted to rec.aviation.soaring
Papa3[_2_]
Looks like you got what you needed to go with the tongue, chains, chocks and other implements of destruction...
On Thursday, August 9, 2012 9:49:56 PM UTC-4, JohnDeRosa wrote:
Gentlemen,
great.
Thanks, John
Old August 10th 12, 03:36 PM posted to rec.aviation.soaring
Dan Marotta
That's great! My posts weren't about US vs. EU, they were about the
difference between $35 and $280. As Ferris Bueller once said, "If you have
the means, you should pick one up..." Of course, he was referring to a
Ferrari.
Gentlemen,
great.
Thanks, John
Cobra Trailer Screw Jack Mike McCarron[_2_] Soaring 4 July 31st 12 09:07 PM
Cobra Trailer Screw Jack Mike McCarron[_2_] Soaring 0 July 30th 12 07:27 PM
WTB: Cobra Trailer Ramp Jack - US Gary Emerson Soaring 1 June 21st 09 01:34 AM
Ramp jack for Komet Trailer [email protected] Soaring 8 April 2nd 08 05:37 PM
Double scissor jack for trailer ramp? Bullwinkle Soaring 15 January 18th 06 05:18 PM
