Source for Euro Trailer Jack & Bracket
Old August 3rd 12, 04:11 AM posted to rec.aviation.soaring
JohnDeRosa
Default Source for Euro Trailer Jack & Bracket
I envy the cobra trailers with a jack that is removable. I can find the jack itself but does anyone know of a source for the bracket? This is the part/clamp that allows that jack to be removed. Anyone have a old rusty jack/bracket lying around?
- John
Old August 3rd 12, 05:25 PM posted to rec.aviation.soaring
Wheaton
Look up Knott GmbH trailers out of Germany. I sourced a tongue damper with very positive results. Check the data plate on your trailer tongue for your equipment mfg.
Old August 5th 12, 02:59 AM posted to rec.aviation.soaring
JohnDeRosa
This is a (very nice) homebuilt trailer so no dataplate. I am trying to replace the standard "American" jack with a removeable "euro" jack. http://aviation.derosaweb.net/dg101/...3405_Large.JPG
Old August 5th 12, 03:42 AM posted to rec.aviation.soaring
JohnDeRosa
Thanks for directing me to http://www.knott-trailer-shop.com. They have exactly what I need.
What seems crazy is how inexpensive the parts are (shipping may be another story). The jack is E19.49 ($24.12) and the bracket is E6.00 ($7.43). Williams Soaring has the jack for $254.30 and the bracket for $44.22. 9.5x more expensive??? Am I missing something?
And I'd like to mention that the http://www.knott-trailer-shop.com web site is one of the best I have used.
- John
Old August 5th 12, 05:33 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
I've used a swivel jack with wheel on my Cobra trailer for 18 years.
Works well, swivels up out of the way for travel, only $30. Go to
westmarine.com and search for "swivel jack".
email me)
Old August 5th 12, 07:04 PM posted to rec.aviation.soaring
http://www.williamssoaring.com/catalog/cobra.html
Williams Soaring has these items in stock.
Regards,
Rex
Old August 6th 12, 05:53 PM posted to rec.aviation.soaring
JohnDeRosa
Eric Greenwell
Eric - Thanks for the comment. The type you describe is the type that
I have now and it is fine. But for various reasons having to do with
space considerations I want the removable type. It seems that here in
the US no such item is used or available (except from glider trailer
parts sources). However, in Europe and elsewhere, it is the
standard. It took me a while to figure out that a "swivel jack" in US-
speak is a "jockey wheel" in Euro-speak. American doing its own thing
I guess - and don't even get me started on why we are the only country
that doesn't use metric (except for Liberia and Myanmar!).
- John "Metric" DeRosa
Old August 7th 12, 02:53 AM posted to rec.aviation.soaring
Dan Marotta
So... If you're sinking at 1 meter/sec and cruising at 100 km/hr, what's
your glide ratio?
If you're sinking at 2 kts and flying at 60 kts, what's your glide ratio?
How many km per degree of longitude?
How many nm per degree of longitude?
I could go on...
"JohnDeRosa" wrote in message
Eric Greenwell
Old August 7th 12, 06:22 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
I could go on...
I don't fly using glide ratios, so being able to determine them easily
isn't an asset. I use McCready numbers for the speed to fly and for the
glide calculation, which is done by my flight computer. As for km, NM,
and degrees of latitude, I also let the flight computer work it's magic.
Doesn't everybody do it that way now? :^)
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old August 7th 12, 04:22 PM posted to rec.aviation.soaring
Dan Marotta
Frankly, I see no value in switching. I already have two sets of tools, SAE
and metric. If we switch, then my SAE tools will become redundant.
Heck, my Harley-Davidson requires both sets of tools (sheesh)...
I could go on...
glide calculation, which is done by my flight computer. As for km, NM, and
Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email
me)
Cobra Trailer Screw Jack Mike McCarron[_2_] Soaring 4 July 31st 12 09:07 PM
Cobra Trailer Screw Jack Mike McCarron[_2_] Soaring 0 July 30th 12 07:27 PM
WTB: Cobra Trailer Ramp Jack - US Gary Emerson Soaring 1 June 21st 09 01:34 AM
Ramp jack for Komet Trailer [email protected] Soaring 8 April 2nd 08 05:37 PM
Double scissor jack for trailer ramp? Bullwinkle Soaring 15 January 18th 06 05:18 PM
