Casey Wilson wrote:
For the boiling point, stick the probe in a pot of boiling water and it should read 100 degrees. Except, of course, for the barometric pressure. We all know water boils at lower and lower temperatures (?? 3 degrees per 1,000 feet??) as altitude is increased. Question: Why doesn't the same pressure effect occur for the freezing point? It does. It's just that the melting point curve is a lot steeper than the boiling point curve, so it takes a lot more pressure for the same effect. An interesting experiment can demonstrate the effect. Suspend an ice cub between two supports. Loop a fine wire over the ice cube, and use it to suspend some significant weight (say 0.5-1 pounds). After some time the wire will be in the middle of the ice cube, with ice above and below it. After even more time, the wire will "cut" through the cube and fall out the bottem, leaving behind a solid block of ice. (The pressure of the wire on the ice raises the melting point, so that the ice in immediate contact with the wire becomes liquid. After the wire passes that spot, the melting point returns to normal and the water re-freezes. Rich Lemert |
Total Air Temperature question | Mike Rapoport | Instrument Flight Rules | 12 | December 14th 04 06:20 PM |
Total Air Temperature question | Julian Scarfe | General Aviation | 6 | December 14th 04 06:20 PM |
Total Air Temperature question | Mike Rapoport | General Aviation | 5 | December 11th 04 09:30 PM |
'Room Temperature' | Anthony | Home Built | 11 | August 23rd 04 07:36 PM |
Wanted to Buy/Trade: CTH Bayonet Type Probes | aRKay | Aviation Marketplace | 0 | August 14th 04 03:40 PM |
