Condor Joystick/Rudder
Old January 8th 13, 11:05 PM posted to rec.aviation.soaring
Piet Barber
Default Condor Joystick/Rudder
I have a Microsoft Sidewinder Force Feedback 2 joystick. Unfortunately, after upgrading to Windows 7, the force feedback part doesn't work anymore. Now it just slops around with no tactile center. I haven't been able to give ground instruction on a flight simulator since this upgrade. This is terribly disappointing since the operating system upgrade was done by Microsoft, and the hardware made obsolete by the same company now makes it more or less useless.
What I would really like is a force feedback joystick that closely represents the style of control column you see in real life gliders. Something that doesn't sit on a table, but is positioned on a chair, and be grabbed in the customary fashion that a normal flight control stick is grasped. And something with a mini-throttle built in that I could use as a trim-tab. I don't need all those 85 buttons and control hat that all the modern joysticks have.
Old January 8th 13, 11:52 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
If you can find something like an old CH Pro gaming stick (two buttons on
the stick, throttle wheel and X and Y trim pots it shouldn't be too hard
to adapt it. Make a stick of the right length from alloy tube and mount
it on a box or whatever so it has the right relationship to your chair.
Fit a mechanical link from your stick to the the CH Pro stick so it will
follow your stick's movements. Take the handle off the CH Pro and put it
on the top of your stick and wit up its two buttons in case you find a
use for them. Lengths of bicycle brake cable can be used to connect home
made brake and trim levers to the throttle and trim pots on the CH base
or use that sort of linkage to make the throttle into an airbrake and
build a mechanical trim setup with springs on the stick (would be more
realistic since the CH trim pots don't physically affect the position of
its stick).
Of course, the CH Pro is an old-style stick that plugs into a game port
and it may be hard to find a game port adapter to fit a modern PC.
However, I bet you could do a similar butcher job on a cheap modern USB
stick and simply discard all the buttons etc you don't need.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 8th 13, 11:53 PM posted to rec.aviation.soaring
WAVEGURU
I'm using the SGS 2-32 joystick and rudder combo...
Boggs
https://www.facebook.com/NWSkysports
Old January 9th 13, 03:59 PM posted to rec.aviation.soaring
Beeper
Over in a Linux group, someone found a partial fix for the floppy stick.
http://scribblette.livejournal.com/643709.html
Old January 13th 13, 05:01 AM posted to rec.aviation.soaring
Bart[_4_]
On Jan 8, 3:05*pm, Piet Barber wrote:
I have a Microsoft Sidewinder Force Feedback 2 joystick. *Unfortunately, after upgrading to Windows 7, the force feedback part doesn't work anymore. *Now it just slops around with no tactile center. I haven't been able to give ground instruction on a flight simulator since this upgrade. *This is terribly disappointing since the operating system upgrade was done by Microsoft, and the hardware made obsolete by the same company now makes it more or less useless.
Apparently, it does work for some: http://forum.condorsoaring.com/viewt...p?f=15&t=14804
I have W7 64 bit and am planning to get Condor and MSFF2. I hope that
the combination will work fine. If it does not, then I will simply run
Condor in a virtual machine under WinXP.
Bart
Old January 20th 13, 06:59 PM posted to rec.aviation.soaring
Tony V
You may be disappointed with the VM. On my machine, the response time to
mouse and keyboard inputs is noticeable slower than normal. Whether or
not it's too slow for Condor, I don't know.
Tony "6N"
Old January 21st 13, 07:35 PM posted to rec.aviation.soaring
Bart[_4_]
I have not experienced anything like this (I use VMware Workstation/
Player). What do you use?
Bart
Old January 21st 13, 07:55 PM posted to rec.aviation.soaring
noel.wade
Bart -
I have (and use) Condor on Win7 64-bit. It works fine, just make sure
you have at _least_ 2GB of RAM (that's for Win7, more than Condor)!
--Noel
Old January 23rd 13, 06:06 PM posted to rec.aviation.soaring
Bart[_4_]
On Jan 21, 11:55*am, "noel.wade" wrote:
I have (and use) Condor on Win7 64-bit. *It works fine, just make sure
Noel,
I am sure Condor works fine under Win7 - it's a supported product
after all. CPU/RAM will not be an issue; I have plenty.
It is the Microsoft force feedback joystick that worries me a bit.
Bart
Old January 23rd 13, 06:50 PM posted to rec.aviation.soaring
Ian Kennedy
"Bart" wrote in message
Noel,
Bart
Bart,
I'm using Win7 64 bit with Condor and a Microsoft force feedback
joystick....no problem.
Cheers
Ian K
Condor Thanksgiving and Condor Christmas Contests [email protected] Soaring 0 October 22nd 12 03:33 PM
Condor Joystick/Rudder Pedals Peter von Tresckow Soaring 5 January 4th 12 04:08 PM
What's the best PC joystick? John Doe Simulators 5 June 11th 06 06:01 AM
good joystick/rudder/throttle choices for MS Flight Sim 2004 on XP [email protected] Simulators 5 September 3rd 05 10:29 AM
Which joystick Oysters8 Simulators 3 February 15th 04 01:36 PM
