Condor Joystick/Rudder
Old January 7th 13, 09:35 PM posted to rec.aviation.soaring
Peter von Tresckow
Default Condor Joystick/Rudder
As much as it pains me to part with my vintage Thrustmaster F16 FLCS,
throttle, and rudders, I think it's time to move into the 21st century and
get a USB setup. What is the current consensus on what joystick/rudder
combo to go with??
Thanks
Pete
Old January 7th 13, 09:46 PM posted to rec.aviation.soaring
Terence Wilson[_2_]
Saitek yoke and rudder. Works well in Condor, FS9, FSX, X-Plane. I've had mine for 3 years are so and use it a lot. No issues.
Old January 8th 13, 12:31 AM posted to rec.aviation.soaring
Paul Remde
Hi Peter,
I sell the Logitech Extreme 3D Pro Joystick and CH Pro Pedals. Customers
seem very happy with them. I use them and I'm happy with them.
http://www.cumulus-soaring.com/condor.htm
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Peter von Tresckow" wrote in message
combo to go with??
Thanks
Pete
Old January 8th 13, 01:51 AM posted to rec.aviation.soaring
Dan Daly[_2_]
On Jan 7, 7:31*pm, "Paul Remde" wrote:
Hi Peter,
I sell the Logitech Extreme 3D Pro Joystick and CH Pro Pedals. *Customers
seem very happy with them. *I use them and I'm happy with them.http://www.cumulus-soaring.com/condor.htm
Best Regards,
Paul Remde
"Peter von Tresckow" *wrote in ...
combo to go with??
Thanks
Pete
I have the same as Paul; happy with both. The stick isn't force
feedback, if that is important to you.
Dan
Old January 8th 13, 03:08 AM posted to rec.aviation.soaring
Bill D
Hi Peter,
Best Regards,
Paul Remde
combo to go with??
Thanks
Pete
Dan
I've been using the Logitech "Extreme 3D Pro" for several years (Since I found it in a discount bin for $15.) I decided pedals were too much hassle so I learned to use the twist grip for rudder. This works so well (for me) that I'm sometimes discomfited by simulators with a pedal set-up.
Old January 8th 13, 03:49 PM posted to rec.aviation.soaring
Daniel Sazhin
Pete,
I use a Sidewinder 2 Force Feedback stick and Saitek Pro Flight Rudder
Pedals. The Sidewinder has been the best stick I have ever used and gives
the most "feel" to the glider. They haven't been made in almost 10 years,
but are pretty cheap on Ebay.
Daniel Sazhin
and
combo to go with??
Thanks
Pete
Old January 8th 13, 05:29 PM posted to rec.aviation.soaring
John Carlyle
I second Daniel's recommendation. They offer a wonderful "feel" to the Condor glider - almost lifelike.
-John
On Tuesday, January 8, 2013 10:49:25 AM UTC-5, Daniel Sazhin wrote:
Pete,
Daniel Sazhin
Old January 8th 13, 06:01 PM posted to rec.aviation.soaring
soartech[_2_]
Daniel Sazhin
Daniel,
What does Force Feeback mean? Does it have little motors inside the
stick?
Is this feature supported by Condor?
Old January 8th 13, 06:13 PM posted to rec.aviation.soaring
JP Stewart
Daniel Sazhin
Daniel,
stick?
Yes and yes. Force feedback tries to make the stick respond to stick forces in the plane. It is usually pretty good, however I have not found it to really make a huge difference. I prefer the Saitek X-52 Pro because it is very smooth and has a good bit more stick travel (Vs. the Logitech joystick) which makes it feel more precise to me. Try some out and find what you think feels right and remember to join us on US Nightly Soaring every day (except Monday) at 9PM eastern. http://gliderracing.com/pub/
JP
Old January 8th 13, 11:05 PM posted to rec.aviation.soaring
Piet Barber
I have a Microsoft Sidewinder Force Feedback 2 joystick. Unfortunately, after upgrading to Windows 7, the force feedback part doesn't work anymore. Now it just slops around with no tactile center. I haven't been able to give ground instruction on a flight simulator since this upgrade. This is terribly disappointing since the operating system upgrade was done by Microsoft, and the hardware made obsolete by the same company now makes it more or less useless.
What I would really like is a force feedback joystick that closely represents the style of control column you see in real life gliders. Something that doesn't sit on a table, but is positioned on a chair, and be grabbed in the customary fashion that a normal flight control stick is grasped. And something with a mini-throttle built in that I could use as a trim-tab. I don't need all those 85 buttons and control hat that all the modern joysticks have.
Condor Thanksgiving and Condor Christmas Contests [email protected] Soaring 0 October 22nd 12 03:33 PM
Condor Joystick/Rudder Pedals Peter von Tresckow Soaring 5 January 4th 12 04:08 PM
What's the best PC joystick? John Doe Simulators 5 June 11th 06 06:01 AM
good joystick/rudder/throttle choices for MS Flight Sim 2004 on XP [email protected] Simulators 5 September 3rd 05 10:29 AM
Which joystick Oysters8 Simulators 3 February 15th 04 01:36 PM
