LX-Nav S80 settings
Old May 17th 16, 02:19 AM posted to rec.aviation.soaring
Mark628CA
Default LX-Nav S80 settings
I just installed an LX-Nav S80 and remote stick controller, and while I am mostly impressed with the hardware, the operating manual is sorely lacking in many areas.
When trying to enter the value for ballast weight, you have a choice between overload, weight, lb/sqft and kg/m2. Absolutely no explanation is given in the manual about how to use these numbers. I can understand lb/sq ft and kg/m2, but this isn't how I normally load my glider. And I have no idea what "overload" might refer to.
I just want to set my empty glider weight and pilot weight with chute in the appropriate fields and then enter the weight of the ballast I intend to carry.
Do I enter the gross glider weight or the ballast weight added?
Any help would be appreciated. As I get more involved with the mysteries of the S80 and its woefully inadequate operating manual, I will undoubtedly have more questions.
V7/Oudie settings dbrunone Soaring 2 January 10th 13 07:14 PM
Flap Settings Ken Kochanski (KK) Soaring 14 July 13th 07 04:19 AM
Nav radio settings in FMC Mxsmanic Piloting 5 January 10th 07 08:39 PM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
L-nav Settings Ventus 2ct-18 Oliver Peters Soaring 4 July 18th 03 04:14 AM
