Wanted: FRONT nose Trim weights for LS gliders
Old June 16th 19, 06:47 PM posted to rec.aviation.soaring
Paul Kaye
Default Wanted: FRONT nose Trim weights for LS gliders
Here's a shot of a ballast weight with the dimensions added:
https://www.flickr.com/gp/paul_kaye/70f1Xf
Old June 17th 19, 07:36 AM posted to rec.aviation.soaring
Thanks Paul, for the photo and measurements! I was able to retrieve the one that I have from my cockpit yesterday (before it rained!). But now I don't have to do so much! It IS really simple!
The corners on mine are also worn out/rounded off, and so I think this is an important feature---not to have sharp corners.
I will post what happens when I go to the machinist---depending on my work schedule, it may be a few days. It is always fun to have some project related to soaring going on.
Old June 17th 19, 10:44 PM posted to rec.aviation.soaring
After seeing the photo, I believe I have some LS-3/4 nose weights. 3.6 #, 4.0#, and 6.2#. Believe a couple of them will solve your problem. Have photo.
JJ
Factory Grob 103 Twin II balast weights wanted Scott Williams Soaring 1 March 27th 19 02:11 PM
Antonov An-124 Ruslan pics [09/12] - An-124-100 kneeling with front ramp down (aircraft fuselage tilted and front wheels retracted).jpg (1/1) Miloch Aviation Photos 0 February 4th 18 10:07 AM
LS4 trim weights [email protected] Soaring 2 March 31st 14 04:28 AM
More getting gliders in front of the masses.... Dave Nadler Soaring 20 September 3rd 10 04:37 PM
206 front cowl wanted Nigel T Peart Owning 0 January 6th 05 06:20 PM
