Wanted: FRONT nose Trim weights for LS gliders
Old June 10th 19, 05:00 PM posted to rec.aviation.soaring
Default Wanted: FRONT nose Trim weights for LS gliders
Does anyone have nose trim weights for their LS-3 up to LS-10 glider that they do not use and would sell to me? They are 2.45 kg = 5.4 lbs each.
I need TWO more trim weights for the nose of my LS-8 that I can add when I fly and remove when my husband flies.
Thanks.
--Cathy
Old June 11th 19, 04:48 PM posted to rec.aviation.soaring
Paul Kaye
Thanks.
--Cathy
I have some weights but I'd like to keep them (and I'm based in the UK)! However, I'd be happy to give you detailed dimensions; I'd sure you'd be able to get some made up by a local machine shop. They're just oblong blocks with a hole in them .
Old June 11th 19, 09:15 PM posted to rec.aviation.soaring
Paul,
We were thinking of that. We actually have one already (I need three total), so we have a real-live model! So thanks for this post and offer to provide measurements. Maybe just hearing someone say to just get them made is what I needed to hear to just do that.
--Cathy
Old June 11th 19, 11:31 PM posted to rec.aviation.soaring
You can do a plaster cast of existing, then go to a fishing store and buy large sinkers. Melt them in a steel can (coffee can, etc.) using a small propane torch.
Pour into your plaster mold, let cool......done.
Yes, many variations on the theme, but all basically he same.
Old June 12th 19, 06:51 AM posted to rec.aviation.soaring
Per Carlin
Easiest way of doing nose trim weights is to make an dwg (cad-file) of the chunk and go to a local laser-/plasma- or water cutting work shop. They can plates in 5-10mm steel. As steel has lower density do you need a higher stack of plates to get the weight right, there are usually a lot of space for ballast in the LS-ships so this is not an issue.
If you do not have the skills to make the dwg file, just make a drawing in scale 1:1 on a paper and give it to the workshop. Most likely can the make their own drawing.
Old June 12th 19, 01:14 PM posted to rec.aviation.soaring
There are nice suggestions, thanks!
I am going to check with a machine shop that I found one town over from me to see what they'd want as input. I've never used a cad program myself, but know people and I have done mechanical drawing before albeit 43 years ago! Not a hard part to draw,
You are correct that the post that holds the ballast is pretty tall (double the height?) compared to the height that the maximum of three trim ballasts allowed would be.
Well, I've gotta get out to the airport to retrieve my existing ballast from the cockpit and then I can get started!
--Cathy
Old June 13th 19, 12:47 AM posted to rec.aviation.soaring
--Cathy
You can also buy lead sheet from McMaster- Carr supply in a thickness that can be cut with tin snips. Stack up as many as needed.
UH
Old June 13th 19, 03:18 AM posted to rec.aviation.soaring
George Haeh
Cathy,
Be extremely careful about melting lead in the kitchen. You can contaminate your house and expose yourself and [grand]children to dust and fumes.
Lead weights get distorted from being bumped about and may no longer fit into an enclosure. Filing creates neurotoxic dust.
Consider brass.
DG uses it in the DG-1001
Old June 13th 19, 03:46 AM posted to rec.aviation.soaring
No worries, I am going to check out a machine shop to make them and they probably will not be lead! The most I’ll do at my kitchen table is to make a scale drawing if they want it!
Thanks everyone for the tips.
Old June 13th 19, 05:19 PM posted to rec.aviation.soaring
Ray Lovinggood[_2_]
Thanks.
--Cathy
Not an exact response to the original poster: My LS1-d is tail heavy and needs weight in the nose. Several years ago, an A&P shop built a ballast box per the Technical Note from LS, but made it out of sheet metal rather than fiberglass.
They cut a hole in the floor in front of the instrument panel, again according to the TN.
They bolted the box to the floor. Top of the open box is flush with the floor.
Okay, the ballast box wasn't quite the exact dimensions per the TN, but close. They modified the dimensions so I could get two sealed lead-acid batteries in the box.
Works great. I have room for two batteries. Depending on when and where I buy them, they are 10 ah or 10.5 ah "ballast weights".
Factory Grob 103 Twin II balast weights wanted Scott Williams Soaring 1 March 27th 19 02:11 PM
Antonov An-124 Ruslan pics [09/12] - An-124-100 kneeling with front ramp down (aircraft fuselage tilted and front wheels retracted).jpg (1/1) Miloch Aviation Photos 0 February 4th 18 10:07 AM
LS4 trim weights [email protected] Soaring 2 March 31st 14 04:28 AM
More getting gliders in front of the masses.... Dave Nadler Soaring 20 September 3rd 10 04:37 PM
206 front cowl wanted Nigel T Peart Owning 0 January 6th 05 06:20 PM
