LS4 trim weights
Old March 30th 14, 12:44 AM posted to rec.aviation.soaring
Default LS4 trim weights
Hello,
Does anyone have the dimensions for LS4 lead nose trim weights?
Thanks
Old March 31st 14, 03:21 AM posted to rec.aviation.soaring
Bill T
I can measure next weekend. There are 3 weights, the bottom of the 3 has rounded corners to fit the fusalge shape. Square corners would poke holes in the fiberglass. You'll also want the weight, the effect of each weight forward of your feet is the same as 11 pounds in the seat.
BT
Old March 31st 14, 04:28 AM posted to rec.aviation.soaring
BT
Thank you. That Would be very much appreciated. I know the weight is 2.4kg.
Cheers,
Nick
JSF/F-22 weights John Cook Military Aviation 2 September 11th 04 06:32 AM
Lak-12 weights pete83 Soaring 1 June 26th 04 11:25 PM
Lak-12 weights pete83 Soaring 0 June 26th 04 06:47 PM
Can you mix oil weights? Ben Jackson Owning 13 January 5th 04 02:51 AM
Engine weights Salem Farm & Garden Home Built 5 July 22nd 03 04:27 AM
