#11
Op dinsdag 23 juni 2020 02:43:12 UTC+2 schreef Delta8:
I refinished a Komet trailer 3 yrs ago with Boat paint . Self leveled and didn't see any roller marks afterwards. Came out great, UV protection as well although about $50.00 a Qt. I sanded first with an orbital sander 150 and used 5 coats . Very good coverage for a qt. Also afterwards I used a white roofing silicone along the galvanized base . http://tinyurl.com/yaudtp3z -- Delta8 What's a Qt if I may ask? Or is that in liters? (I'm from EU) |
I used Lesonal 540 2K primer. Great stuff, not cheap but the base coating is really good.
Available in Europe, from AKZO I believe. Next step is to finish the final layer in gloss white. Ronald de Vries |
Op dinsdag 23 juni 2020 09:36:46 UTC+2 schreef :
I used Lesonal 540 2K primer. Great stuff, not cheap but the base coating is really good. Available in Europe, from AKZO I believe. Next step is to finish the final layer in gloss white. Ronald de Vries Is it the 2K filler 540 white? I found this on a Dutch website, pricing seems about the same (€ 75 for 3 liters) as others for 0.75-1 liter. What would you finish it with and how many layers of the 2K primer would you use? |
![]() Quote:
https://www.google.com/search?q=quar...hrome&ie=UTF-8 |
On Tuesday, June 23, 2020 at 2:03:54 AM UTC-4, Senna Van den Bosch wrote:
Op dinsdag 23 juni 2020 02:43:12 UTC+2 schreef Delta8: I refinished a Komet trailer 3 yrs ago with Boat paint . Self leveled and didn't see any roller marks afterwards. Came out great, UV protection as well although about $50.00 a Qt. I sanded first with an orbital sander 150 and used 5 coats . Very good coverage for a qt. Also afterwards I used a white roofing silicone along the galvanized base . http://tinyurl.com/yaudtp3z -- Delta8 What's a Qt if I may ask? Or is that in liters? (I'm from EU) US Quart = .946 l |
Lesonal 540 2k primer/filler is white with a yellowish tint, but not grey and not flashing white.
When you finish with a topcoat glossy white you will not see this. I applied with a roller and did one coating, a bit thick. You can also do two coatings but more thin. Regards, Ronald de Vries |
I painted my trailer with HC-2500 Amerflint II polyurethane from Tamco paint. It's been in sun and snow year around for 3 years and still looks like it did the day I painted it. It's excellent...I'm painting my glider with it this month.
https://tamcopaint.com/products/dura...30875014496336 . You have to wear a passive carbon filter mask that traps organics while spraying, but it's no big deal. Excellent customer service, too. |
On Tuesday, June 23, 2020 at 9:08:16 PM UTC-6, Bret Hess wrote:
I painted my trailer with HC-2500 Amerflint II polyurethane from Tamco paint. For primer I used https://www.homedepot.com/p/Rust-Ole...0502/100126115 . I thinned it with urethane thinner and it worked great. Very tough stuff. (On my glider I'll use a urethane 2K primer, but this is perfect for the trailer). |
The HC-2500 Amerflint II polyurethane is 2K. You mix in the hardener. It's called "Single stage" which means its gloss comes with a single application (no clearcoat needed).
On Sunday, June 21, 2020 at 11:00:06 AM UTC-4, Senna Van den Bosch wrote:
I got an older Anschau Komet trailer that needs some care and decided to repaint the entire top side, which is white painted fiberglass. What paint would you recommend for doing this? I'd like it to be a bit glossy and waterproof, as the trailer will stay outside in summer but hangared in winter. Thanks! I just re-did my PIK-20 trailer by shooting a leveling coat of fiberglass boat "Topside" primer (from lowes), and then using rustoleum professional white gloss as a spray top coat. It was super cheap, and seems to have made a pretty nice and even covering. Not something you would see coming out of a professional shop, but i also didn't bother to block sand it or any of that. |
Cobra trailer aluminum vs fiberglass top | 2G | Soaring | 31 | July 20th 18 03:32 AM |
Foam for inside of fiberglass trailer | John[_27_] | Soaring | 9 | April 4th 13 04:12 AM |
Painting fiberglass Cobra trailer | [email protected] | Soaring | 12 | January 19th 13 02:23 AM |
Touch Up White Paint | O. Sami Saydjari | Owning | 10 | May 29th 05 11:58 PM |
Painting a Fiberglass Trailer Experiences | ContestID67 | Soaring | 4 | April 28th 05 07:40 PM |
