#11
Sorry but I don't see your point.
On Tue, 04 Oct 2005 16:34:57 GMT, "lardsoup" wrote:
I rent a Warrior from a local FBO and usually set the RPMs to 2400 in cruise. It gets about 110kts at 2400. But that seems too slow. Heck I've been getting 110kts from one of their C152s. Rereading the POH I see that the cruise RPM settings can be 2500 or 2600. So I'm curious. Where do others run their Warriors while in cruise. I'm not concerned about fuel burn because fuel is included in the rental price and my typical flight is around 2 hours. I know an old Warrior is no SR-71, but I want to at least try for some more speed. Thanks. I am learning on a Warrior PA28 161 which has no wheel fairings. I am told that cruise is between 2200 and 2300 rpm which gives around 100kts ias. I am told only to use full power on take off and climbing It could be that here in the UK avgas is 1.20 UK pounds per litre at my airport so I guess economy is a factor. |
Sounds like you should have charged more for wet fees.
I know the several Warrior II (PA28-161) planes I rented, both the owners and FBO made money off them. As for flying with the throttle firewalled (75% power or less depending upon altitude) versus reduced throttle there wasn't much difference in economy even with proper leaning. I would believe most owners (including myself) are more concerning with proper leaning, cold shock, and sloppy pilot landings & takeoffs. Those factors will bite into an owners & FBO's pocketbook. Nick PA28-180 Seth Masia wrote: This is one reason I no longer lease back my airplane -- because people ran it without regard for fuel burn, and the FBO charged me for the waste. When I fly it, I get 150knots at 10.5 gph, but I saw renters burn 40 gal every three hours. Nuts. Seth Comanche N8100R "Nick" wrote in message ... When I used to rent a Warrior 160hp, I would usually fly it with the throttle firewalled. Does the Warrior you fly have wheel pants on? If not that would cost you a least 5 knots. Nick PA28-180 'D' lardsoup wrote: I rent a Warrior from a local FBO and usually set the RPMs to 2400 in cruise. It gets about 110kts at 2400. But that seems too slow. Heck I've been getting 110kts from one of their C152s. Rereading the POH I see that the cruise RPM settings can be 2500 or 2600. So I'm curious. Where do others run their Warriors while in cruise. I'm not concerned about fuel burn because fuel is included in the rental price and my typical flight is around 2 hours. I know an old Warrior is no SR-71, but I want to at least try for some more speed. Thanks. |
Gonna throttle up next time I fly.
What's your hurry? If you enjoy flying, why be so eager to get back on the ground? vince norris |
When running it with the throttle firewalled, don't you introduce a
real risk of overspeed? Will the engine really make it to TBO running at max RPMs (especially considering the effects of ram-air and whatnot at speed)? Finally, if you owned instead of rented, would you do the same? Ben Hallert PP-ASEL |
![]() "Nick" wrote I would believe most owners (including myself) are more concerning with proper leaning, cold shock, and sloppy pilot landings & takeoffs. Those factors will bite into an owners & FBO's pocketbook. How does cooling shock show up, in a diagnostic/ overhaul/ shortening of engine life, if you know what I mean? What parts suffer, and how do you know other than tearing down the engine? (short of having it seize on you) I have my guesses, but am probably at least partially wrong, and possibly totally wrong. g -- Jim in NC |
![]() "Ben Hallert" wrote (especially considering the effects of ram-air and whatnot at speed)? Ahhh, the big ram air fallacy. Anyone have those calculations handy, that show how many inches (fractions) that the ram air increases the manifold pressure at various typical airspeeds? -- Jim in NC |
I rent so the plane has to be back by a certain time. I've been trying to
land at all the airports in the state so, and I've gone to all the ones that are close, so now I need to cover more distance. I know it's not that much more speed but...... |
real risk of overspeed? Will the engine really make it to TBO running at max RPMs (especially considering the effects of ram-air and whatnot at speed)? What is "overspeed" on a fixed prop? "Max RPMs" on an O-320 (and, in fact, all aircraft engines) are so retarded that the engine is really just loping along at 2700 rpm. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Transmittion Noise - High Power Settings | Paul Smedshammer | Owning | 6 | August 20th 05 06:17 PM |
Lycoming's views on best economy settings | [email protected] | Piloting | 37 | July 8th 04 04:00 PM |
Power settings for 182RG | Andrew Gideon | Piloting | 19 | March 3rd 04 07:41 PM |
Cessna 404 Cruise settings | Katia | General Aviation | 0 | December 19th 03 05:04 PM |
L-nav Settings Ventus 2ct-18 | Oliver Peters | Soaring | 4 | July 18th 03 04:14 AM |
