Help understanding Aspen VOR/DME approach
Old August 6th 06, 03:49 AM posted to rec.aviation.ifr
SimGuy
Default Help understanding Aspen VOR/DME approach
On Sun, 06 Aug 2006 01:33:35 GMT, "John R. Copeland"
"SimGuy" wrote in message ...
On Sat, 5 Aug 2006 23:13:21 +0000 (UTC),
(Paul Tomblin) wrote:
In a previous article, said:
The plate is here-
http://www.airnav.com/depart?http://.../05889VDGC.PDF
While trying to fly the approach in the sim I flew to the MAP with
relative ease but had trouble getting low enough to make the runway
without getting too hot. Looking at the plate it seems a drop of 2380'
must be made between MAFMU and the runway in a lateral distance of
1.4NM, this is a descent angle of 15 degrees!
Well, yes, if you don't see the runway until the MAP and then want to land
on the runway ahead, you will have a very steep descent. But there are
two factors mitigating that:
- you might see the runway earlier and
- it's a circling approach, so you can circle around airport to descend if
you need to.
Even if the runway is spotted well before the MAP, say at, ALLIX, it's
a very steep descent. At 100kts it is 1140fpm.
I'm not an expert, but this looks like a tough approach; the MA looks
challenging too. Would it even be possible in a 172 or would it would
too under-powered? I imagine you would want something with plenty of
extra oomph.
Yes, it *is* a tough approach.
I've flown it for real a few times, and I'm pretty sure it's *possible* to get
down without circling, but I've never actually done that.
(I have excuses, of course. :-))
Approach Control is accustomed to hearing requests for something
like a left 360 to lose altitude during final approach.
They've always let me maneuver however I've needed.
I wouldn't expect to see a loaded 172 making the 14000-ft initial altitude.
I've had 172s higher than that, but only when lightly loaded.
I suggest crossing Red Table slow, with gear and flaps already extended.
Set prop(s) at high RPM to increase drag, too, if applicable.
If you don't do that, you'll need to circle somewhere over the Roaring Fork River.
You don't need to reach the airport before circling, just be in VMC.
Remember that the northeast bank of the river is a high plateau,
and it's a noise-sensitive area that you should try to respect.
If you *do* circle the airport, you will scare the daylights
out of your passengers as you approach the base-to-final turn.
A rock wall fills your windshield!
You can look it up on Google Earth, if you wish, but I can tell you
that it looks worse in real life than it appears on Google Earth.
Thanks! Your explanation really helped. I will now go and try it in
the sim again, this time in a 182.
Old August 6th 06, 04:16 AM posted to rec.aviation.ifr
Bob Gardner
Yes. The minimum descent altitude is 10,200...either land (good luck!),
circle, or do the miss at the MAP. I've never done this approach in a sim or
in real life, so I'm just going by the plate.
As a general rule, not limited to this approach, nothing regulatory keeps
you from landing straight in if you are in position to do so, even with
circling-only minima. Doing so will always be tough.
Bob Gardner
Bob Gardner
news
The plate is here-
Could someone please confirm this or help with my interpretation of
the chart. I am a PP beginning instrument training.
TIA
On Sat, 5 Aug 2006 18:09:35 -0700, "Bob Gardner"
You get a clue from the fact that there are no straight-in minimums. Then
there is the "C" in the title. When there is no runway number, one of two
things is evident: either the runway is not aligned with the final
approach
course (not in this case, of course), or the descent rate does not meet
400-foot per mile maximum allowable descent rate. You have to circle.
Bob Gardner
(you top-posted so I moved your message)
Thanks, that makes much more sense. But I have a question- the
circling minimum is 10,200', this applies up to the MAP right?
Obviously in circling the runway one would need to get lower.
Old August 6th 06, 04:27 AM posted to rec.aviation.ifr
Mark Hansen
Well, they say you must be able to complete the approach and land using
"normal" maneuvers. They don't define "normal", but I would think a really
steep descent would not be normal.
Bob Gardner
Bob Gardner
news The plate is here-
TIA
approach
Bob Gardner
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old August 6th 06, 04:44 AM posted to rec.aviation.ifr
Jim Macklin
Note that the angle is given on then chart, at about 10
degrees. This is possible for some STOL aircraft, but 3
degrees is an average.
James H. Macklin
ATP,CFI,A&P
"Mark Hansen" wrote in message
land (good luck!),
regulatory keeps
do so, even with
and land using
| Bob Gardner
| Bob Gardner
| news | The plate is here-
the MAP with
make the runway
lateral distance of
interpretation of
| TIA
number, one of two
with the final
| approach
rate does not meet
| the
have to circle.
| Bob Gardner
question- the
right?
lower.
| Sacramento, CA
Old August 6th 06, 05:06 AM posted to rec.aviation.ifr
Doug[_1_]
At Aspen, by the time you get to the MAP you will have so much ice,
decending at the required 10 degrees will be no problem (hah, hah).
Extra points given for knowing which way to read the localizer on the
missed approcah (is it normal or reversed, answer quick now....)
Old August 6th 06, 12:59 PM posted to rec.aviation.ifr
Jim Macklin
With an HSI, it is always right if you set the front course.
With a cheap CDI it is reversed, unless the airplane has a
reverse switch.
James H. Macklin
ATP,CFI,A&P
"Doug" wrote in message
much ice,
(hah, hah).
localizer on the
now....)
Old August 6th 06, 01:43 PM posted to rec.aviation.ifr
Sam Spade
Not even a concern in a light aircraft. The ice and downdrafts will
likely have you in your final resting place at least 5 miles north of
the airport, if not atop the 11,775' peak upon which Red Table sits.
Most of the birds that can fly this approach when it is needed have LNAV
and moving maps. They don't tune the missed approach LOC.
Old August 6th 06, 03:55 PM posted to rec.aviation.ifr
Peter R.
Wouldn't it be a requirement that the missed approach LOC be tuned and used
as primary navigation by all pilots (serious question, as I am not at all
familiar with IFR regulations as they pertain to 135 or 121 operations).
Peter
Old August 6th 06, 04:12 PM posted to rec.aviation.ifr
Brad[_1_]
reverse switch.
Flying outbound on a backcourse gives "normal" course indications on a
CDI. Look at the shaded side of the arrow.
Old August 6th 06, 04:13 PM posted to rec.aviation.ifr
Brad[_1_]
reverse switch.
OLV GPS 36 approach question A Lieberma Instrument Flight Rules 59 August 15th 06 12:32 AM
procedure turns revisited [email protected] Instrument Flight Rules 37 June 20th 06 03:39 AM
VOR/DME approach radio calls Derek Fage Instrument Flight Rules 12 December 8th 04 11:36 PM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
