Help understanding Aspen VOR/DME approach
Old August 6th 06, 12:02 AM posted to rec.aviation.ifr
SimGuy
Default Help understanding Aspen VOR/DME approach
The plate is here-
http://www.airnav.com/depart?http://.../05889VDGC.PDF
While trying to fly the approach in the sim I flew to the MAP with
relative ease but had trouble getting low enough to make the runway
without getting too hot. Looking at the plate it seems a drop of 2380'
must be made between MAFMU and the runway in a lateral distance of
1.4NM, this is a descent angle of 15 degrees!
Could someone please confirm this or help with my interpretation of
the chart. I am a PP beginning instrument training.
TIA
Old August 6th 06, 12:11 AM posted to rec.aviation.ifr
Sam Spade
SimGuy wrote:
The plate is here-
TIA
It is circling only minimums because of the steep descent angle.
It is a form of "Let the buyer beware."
Old August 6th 06, 12:13 AM posted to rec.aviation.ifr
Paul Tomblin
In a previous article, said:
The plate is here-
Well, yes, if you don't see the runway until the MAP and then want to land
on the runway ahead, you will have a very steep descent. But there are
two factors mitigating that:
- you might see the runway earlier and
- it's a circling approach, so you can circle around airport to descend if
you need to.
I used up all my sick days, so I'm calling in dead.
Old August 6th 06, 12:18 AM posted to rec.aviation.ifr
Sam Spade
The plate is here-
you need to.
At Aspen, circling around the airport is very risky business.
Old August 6th 06, 12:53 AM posted to rec.aviation.ifr
SimGuy
On Sat, 5 Aug 2006 23:13:21 +0000 (UTC),
The plate is here-
you need to.
Even if the runway is spotted well before the MAP, say at, ALLIX, it's
a very steep descent. At 100kts it is 1140fpm.
I'm not an expert, but this looks like a tough approach; the MA looks
challenging too. Would it even be possible in a 172 or would it would
too under-powered? I imagine you would want something with plenty of
extra oomph.
Old August 6th 06, 02:09 AM posted to rec.aviation.ifr
Bob Gardner
You get a clue from the fact that there are no straight-in minimums. Then
there is the "C" in the title. When there is no runway number, one of two
things is evident: either the runway is not aligned with the final approach
course (not in this case, of course), or the descent rate does not meet the
400-foot per mile maximum allowable descent rate. You have to circle.
Bob Gardner
"SimGuy" wrote in message
news
The plate is here-
TIA
Old August 6th 06, 02:27 AM posted to rec.aviation.ifr
Sam Spade
The plate is here-
you need to.
extra oomph.
This airport is death for IFR opes by normally-aspirated piston aircraft.
Old August 6th 06, 02:33 AM posted to rec.aviation.ifr
John R. Copeland
"SimGuy" wrote in message ...
The plate is here-
you need to.
extra oomph.
Yes, it *is* a tough approach.
I've flown it for real a few times, and I'm pretty sure it's *possible* to get
down without circling, but I've never actually done that.
(I have excuses, of course. :-))
Approach Control is accustomed to hearing requests for something
like a left 360 to lose altitude during final approach.
They've always let me maneuver however I've needed.
I wouldn't expect to see a loaded 172 making the 14000-ft initial altitude.
I've had 172s higher than that, but only when lightly loaded.
I suggest crossing Red Table slow, with gear and flaps already extended.
Set prop(s) at high RPM to increase drag, too, if applicable.
If you don't do that, you'll need to circle somewhere over the Roaring Fork River.
You don't need to reach the airport before circling, just be in VMC.
Remember that the northeast bank of the river is a high plateau,
and it's a noise-sensitive area that you should try to respect.
If you *do* circle the airport, you will scare the daylights
out of your passengers as you approach the base-to-final turn.
A rock wall fills your windshield!
You can look it up on Google Earth, if you wish, but I can tell you
that it looks worse in real life than it appears on Google Earth.
Old August 6th 06, 02:36 AM posted to rec.aviation.ifr
SimGuy
news
The plate is here-
TIA
On Sat, 5 Aug 2006 18:09:35 -0700, "Bob Gardner"
Bob Gardner
(you top-posted so I moved your message)
Thanks, that makes much more sense. But I have a question- the
circling minimum is 10,200', this applies up to the MAP right?
Obviously in circling the runway one would need to get lower.
Old August 6th 06, 03:45 AM posted to rec.aviation.ifr
Jim Macklin
Because you must be in visual conditions from the MDA and at
all time while circling. Bob Gardner gave the correct
answer. If you are fly a plane, such as a Helio Courier or
a similar STOL, you can land straight in, but most airplanes
will have to circle to land. Mountain flying is very nice
and also dangerous.
| news | The plate is here-
the MAP with
make the runway
a drop of 2380'
distance of
interpretation of
| TIA
number, one of two
the final approach
does not meet the
have to circle.
| Bob Gardner
right?
lower.
OLV GPS 36 approach question A Lieberma Instrument Flight Rules 59 August 15th 06 12:32 AM
procedure turns revisited [email protected] Instrument Flight Rules 37 June 20th 06 03:39 AM
VOR/DME approach radio calls Derek Fage Instrument Flight Rules 12 December 8th 04 11:36 PM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
