Handheld problem in NORDO plane
Old August 19th 06, 06:19 AM posted to rec.aviation.piloting
Jim Macklin
Default Handheld problem in NORDO plane
At the speed of the 8A in clear air, I doubt it is static
electricity, wicks are usually not installed until cruise
speeds get into the 150 + speed range.
Install a shield ignition system if you can, make sure that
your external antenna is properly installed.
"Mark Morissette" wrote in
message
m...
| I thought that too, but it doesn't make sense that it
would start
| 100-200 feet AGL. If it is ignition, it will be present
any time the
| engine is running.
| Agreed, hence my query to double confirm that.
| I think someone else further down the thread may have
nailed it -
| airframe static, perhaps.
Old August 19th 06, 02:53 PM posted to rec.aviation.piloting
Ron A.[_1_]
If you are using a handheld GPS, try moving the transceiver away from the
gps. My ICOM breaks squelch badly when it is near the Garmin 196 display
(even on batteries). I move it a few feet and it goes away.
Old August 19th 06, 04:03 PM posted to rec.aviation.piloting
RST Engineering
What's a static dissipation wire?
Airframe static? Isn't that what they have the static dissipation
wires for? Just a WAG.
Old August 19th 06, 04:05 PM posted to rec.aviation.piloting
RST Engineering
Busted ground wire off the coax at the antenna end.
Any ideas what's going on here? All help is appreciated.
Tailwinds and blue skies,
Old August 19th 06, 04:40 PM posted to rec.aviation.piloting
Jose[_1_]
While I've got you, (heh heh) what's your take on a car radio that
buzzes (ignition noise) much louder than the radio station coming in,
but intermittently? I'd guess the same thing, but we haven't been able
to find it.
Jose
The monkey turns the crank and thinks he's making the music.
Old August 20th 06, 04:54 AM posted to rec.aviation.piloting
It's the name I thought of late at night, for the wires that trail the
wings/elevators to dissipate static. People who know better probably
have a different name that more folks, also knowledgable, recognize
more quickly. Like I said, WAG. If I really knew what I was talking
about, I'da said so. big grin, late at night on Saturday
I'll be interested in the real cure, when the OP figures it out. I
learn a lot that way...
Old August 20th 06, 07:03 AM posted to rec.aviation.piloting
RST Engineering
static wick. You can make one out of a solder lug, a high value resistor,
and a pinpoint for less than a penny if you google my KitPlanes article on
the subject.
However, for aircraft less than 200 knots cruise speed, it isn't a problem.
Old August 20th 06, 10:29 AM posted to rec.aviation.piloting
Cub Driver
Sounds like a Garmin family foible. I have the same problem (though
only on trasmit) between my 296 and my Vertex Standard. Since I really
have no option, and since the Cub is so obviously Nordo anyhow, I just
don't use them at the same time. When I have my destination in sight,
I turn off the Garmin. After I'm clear of the pattern on takeoff, I
turn it on again and go to the waypoint for the home airport
(whatever). Awkward, but I don't own the plane.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Old August 20th 06, 01:37 PM posted to rec.aviation.piloting
Matt Whiting
the subject.
There are some occasions where it is. I flew my Skylane in cold, dry
snow once and got so much static that the comm radio was completely
useless. Installed the wicks a short time later and never had that
problem again.
The 182 is much slower than 200 knots and I never had a problem other
that in fairly dry (cold) snow.
Matt
Connecting handheld to intercom in NORDO plane [email protected] Owning 2 July 7th 06 02:57 PM
aviation vhf handheld radio problem pwm Home Built 3 February 7th 06 02:03 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
