Handheld problem in NORDO plane
Old August 19th 06, 02:41 AM posted to rec.aviation.piloting
Default Handheld problem in NORDO plane
Hey folks,
I just bought a Luscombe 8A and am launching tomorrow to fly it home.
The problem is the handheld transceiver I'm using to communicate. It
works fine on the ground. But as soon as I get 100-200 feet off the
ground it gets overwhelmed with static, like the squelch is wide open.
It's a Vertex VXA-300 attached to an external antenna.
I' ve tried turning the squelch to max. I haven't checked whether it
occurs on all frequencies because that didn't occur to me until I had
put the plane back in the hangar.
Any ideas what's going on here? All help is appreciated.
Tailwinds and blue skies,
Old August 19th 06, 03:27 AM posted to rec.aviation.piloting
Mark Morissette
*Only* when you hit a few hundred feet...or anytime the engine is running?
Personally I'd venture to take a guess that it's picking up electrical
interference from an ignition component.
Old August 19th 06, 03:36 AM posted to rec.aviation.piloting
john smith
I thought that too, but it doesn't make sense that it would start
100-200 feet AGL. If it is ignition, it will be present any time the
engine is running.
Old August 19th 06, 04:19 AM posted to rec.aviation.piloting
engine is running.
Airframe static? Isn't that what they have the static dissipation
wires for? Just a WAG.
Old August 19th 06, 04:03 PM posted to rec.aviation.piloting
RST Engineering
What's a static dissipation wire?
Old August 20th 06, 04:54 AM posted to rec.aviation.piloting
It's the name I thought of late at night, for the wires that trail the
wings/elevators to dissipate static. People who know better probably
have a different name that more folks, also knowledgable, recognize
more quickly. Like I said, WAG. If I really knew what I was talking
about, I'da said so. big grin, late at night on Saturday
I'll be interested in the real cure, when the OP figures it out. I
learn a lot that way...
Old August 19th 06, 04:22 AM posted to rec.aviation.piloting
Mark Morissette
engine is running.
Agreed, hence my query to double confirm that.
I think someone else further down the thread may have nailed it -
airframe static, perhaps.
Old August 19th 06, 06:19 AM posted to rec.aviation.piloting
Jim Macklin
At the speed of the 8A in clear air, I doubt it is static
electricity, wicks are usually not installed until cruise
speeds get into the 150 + speed range.
Install a shield ignition system if you can, make sure that
your external antenna is properly installed.
"Mark Morissette" wrote in
message
m...
would start
any time the
| engine is running.
nailed it -
Connecting handheld to intercom in NORDO plane [email protected] Owning 2 July 7th 06 02:57 PM
aviation vhf handheld radio problem pwm Home Built 3 February 7th 06 02:03 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
