Altimeter 3066
Old December 3rd 06, 09:45 PM posted to rec.aviation.piloting,rec.aviation.student
M[_1_]
Default Altimeter 3066
ATC computer converts the pressure altitude with local altimeter
setting. If ATC knows everyone is using 3100 as their altimeter setting
(can be by regulation in high pressure 31" situation, such as in
Canada), the computer can do similar converson, so the IFR separation
would not be unaffected.
Wade Hasbrouck wrote:
I thought the Mode C transponder reports Pressure Altitude and is basically
fixed at 29.92?
Old December 3rd 06, 09:23 PM posted to rec.aviation.piloting,rec.aviation.student
J. Severyn
"M" wrote in message
I can hardly see how it should affect VFR flights.
Well pattern altitudes might be one problem. How about easterly/westerly
odd/even +500 altitudes?
John Severyn
@KLVK
Old December 3rd 06, 09:42 PM posted to rec.aviation.piloting,rec.aviation.student
M[_1_]
So everybody fly their pattern 100 ft higher than normal. Big deal.
As long as everyone all max out their Kollsman's window at 3100 in the
same vacinity, even/odd +500 altitude would be just fine. You still
have the same vertical separation. Plus, VFR is see and avoid.
even/odd +500 altitude doesn't really do much separation when someone
flying magnetic course 001 converge with someone flying course magnetic
179, all legally at odd+500 VFR altitude and only 2 degree off from a
head-on.
John Severyn
@KLVK
Old December 3rd 06, 10:06 PM posted to rec.aviation.piloting,rec.aviation.student
Newps
So you're a couple hundred feet off, that's no big deal. As for pattern
altitudes I always use 1000 agl, plus or minus depending on how I round
the field elevation.
Old December 2nd 06, 04:03 PM posted to rec.aviation.piloting,rec.aviation.student
Fred G. Black
M wrote:
BTW, FAR 91.144 restricts flight operations when barometric pressure
exceeds 31 inch mercury. Any idea why? (note this restriction applies
to VFR traffic a well).
The "why" is that the altimeter setting range on most altimeters doesn't
go past 31.00". Does anyone have an example of a NOTAM under 91.144?
(how restrictive is it).
The rules that apply in Canada are a bit more explicit:
http://www.tc.gc.ca/CivilAviation/pu...12-1.htm#12-12
Basically it says
- for enroute, set the altimeter to 31"
- for IFR approaches, set the altimeter to the actual altimeter setting
if able, otherwise set it to 31" and adjust the altitude minima (add
100' and 1/4 SM per 0.1" above 31.00")
- aerodromes which cannot report the actual altimeter setting are
restricted to VFR.
-"For aircraft operating VFR, no additional restrictions apply; however,
extra diligence in flight planning and in operating in these conditions
is essential. "
Old December 2nd 06, 04:09 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
And it may not be a perfect solution, but GPS altitude
readout may be independent of baro altitude.
"Fred G. Black" wrote in message
barometric pressure
restriction applies
altimeters doesn't
under 91.144?
| Basically it says
altimeter setting
minima (add
setting are
| restricted to VFR.
apply; however,
these conditions
| is essential. "
Old December 2nd 06, 02:16 PM posted to rec.aviation.piloting,rec.aviation.student
Heck,,, get out and go flying. The wings love the thick air and the
motor really LOVES it too.
M wrote:
A very high pressure settled in Pacific NW:
KPSC 020453Z 31006KT 6SM BR BKN007 BKN075 M07/M08 A3066 RMK AO2
SLP389 T10671078
That's the highest that I've ever remember seeing.
I always thought that the NW seems to have larger pressure swings
(probably more so in Alaska). We can go from 2960 to 3060 in about two
days.
Old December 2nd 06, 09:08 PM posted to rec.aviation.piloting,rec.aviation.student
Newps
Jim Macklin wrote:
Using carh heat on the ground,
In cruise flight carb heat should be set to give a carb temp of approx
45-50F.
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
