#11
Shut up!!
How am I gonna get rich selling these things if you post accurate info like that? bumper "kirk.stant" wrote in message oups.com... Darn things work even better when you tape both ends down. Just have to make sure it's on straight first... And they last longer on the inside of the canopy, anyway. 66 |
No one has mentioned that yaw strings work on helicopters, too.
Just as important to avoid adverse yaw on a helicopter - and no, the "downwash" does not render them useful. Colin |
Sounds like it would be a usefull instrument for a hot air baloon.
After all, you need to know which way the wind is blowing. On Jan 29, 4:51 pm, "COLIN LAMB" wrote: No one has mentioned that yaw strings work on helicopters, too. Just as important to avoid adverse yaw on a helicopter - and no, the "downwash" does not render them useful. Colin |
I should read twice and send once. I meant: does not render them useless. Time for a soda. Colin |
The FAA RFH (http://www.faa.gov/library/manuals/aircraft/media/faa-
h-8083-21.pdf) only mentions yaw strings on gyroplanes, so I added that. Find a ref for helicopters, and add the info to the WP article. On Jan 29, 8:19 pm, "COLIN LAMB" wrote: and no, the "downwash" does not render them useful.I should read twice and send once. I meant: does not render them useless. Time for a soda. Colin |
I do not recall seeing it written anywhere, but I am a helicopter pilot and
they are on most of the Schweizers (formerly Hughes) that I flew. The instructors seem to like them and noted when you think you are doing fine that the yaw string was not centered. Heck, instructors are the same everywhere, they like to find things you do wrong and point them out - thank goodness. Colin |
On Jan 29, 9:21 am, Jack wrote: Tom Gardner wrote: More surprisingly to me is the information that... Yaw strings are also fitted to the Lockheed U-2 high-altitude surveillance aircraft http://www.barryschiff.com/high_flight.htm ... but given how close U2s are to falling out the sky at altitude (the coffin corner), perhaps it isn't too surprising.Yaw strings have also been found on USAF fighters. They aid in gunnery training. Jack |
On Jan 29, 4:22 pm, "bumper" wrote:
Shut up!! How am I gonna get rich selling these things if you post accurate info like that? Same way everybody makes a small fortune in aviation - start with a big one! Actually, you should consider using the blank surface of the yawstring for advertising - how about string cheese? Or baling wire? 66 |
| Thread Tools | |
| Display Modes | |
| light twins? | Bellsouth News Server | Home Built | 83 | August 12th 05 03:56 AM |
| Yaw String in a Spin | John Galloway | Soaring | 52 | January 21st 05 11:14 PM |
| Yaw String refference - Spinning | Vassilios Mazis | Soaring | 1 | January 18th 05 08:30 AM |
| Long Island Crash - Kite String? | Neb Okla | Rotorcraft | 5 | September 3rd 04 06:43 PM |
| String in the middle does not protect you from a spin | Jim | Soaring | 10 | January 30th 04 03:57 PM |
