Bad timing...
Old March 9th 07, 01:48 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Bad timing...
In rec.aviation.owning Jay Honeck wrote:
Anyone know if it's possible for a brake to hang up and not release,
resulting in advanced wear like this?
Sure. Short answer: Check the flex line (rubber line) on that side.
If OK or not so equipped, see below.
Long answer:
When I got the engine running (for some value of running) in the first
car I've owned that's older than me, I of course had to take it around
the block. I had reasoned that its manual four-wheel drum brakes would
not respond as well as the power-assisted front disc, rear drum brakes
did on nearly every other car I had owned or driven. Still, when I got
to the stop sign just down the block, I was glad it was one of the
optional ones with the white stripe around it, because I got halfway
into the intersection before I stopped. When I let off the pedal and
tried to accelerate again, the car hesitated for a second, then there
was a ping! from one of the front wheels and the hesitation was gone.
At first I wondered if I was simply treading too lightly on the brakes,
so I got the car back up to 15 mph and literally stood on the pedal.
This still produced a rather anemic stop, so I was convinced something
was wrong. Again, as I tried to accelerate away, I was held back until
I heard the ping! from the front wheel. I carefully returned home to
investigate.
Online consultation with a group of enthusiasts brought a nearly
unanimous answer: The rubber lines in the brake system tend to
deteriorate on the inside as well as on the outside. Besides causing a
reduced flow of brake fluid and poor braking in general, a flap of
rubber will often form inside the line. This flap acts as a check valve:
when you stomp on the pedal and bring up the pressure in the system, the
fluid is forced past the flap and out to the wheel cylinder or caliper,
applying the brake. When you let off the pedal, the shoes or pads are
pushing back on the piston to return the fluid to the master cylinder,
but this pressure is not as great, and the flap is enough to prevent it
from returning. The result is that the brakes on that wheel stay
engaged. Eventually enough fluid may get back through to release the
brakes on that wheel - probably the ping! that I heard. Many people
said they liked to replace the flex hoses immediately on any old car new
to them, and then on a schedule of every 5 to 10 years thereafter.
After a little further inspection, I decided that although the master
cylinder and wheel cylinders were not original to the car, the flex
lines probably were. I ordered a new set, and when they arrived, I
swapped them out. I did a test on the old lines: with them lying on the
ground, not connected to anything, I hooked up my hand vacuum pump to
them. It should have been like sucking on a brand new soda straw, but
instead it was like sucking on a bottle - I could pull a 25" Hg vacuum
from either end of all the hoses. The brakes were probably only working
as much as they did because the hydraulic pressure in the system was
considerably higher, and could force a little fluid through the old
hoses. A road test with the new hoses proved much more satisfying; I
could reliably stop at both the optional and the mandatory stop signs.
One diagnostic for this problem in a car is to raise the wheels off the
ground and make sure they turn freely by hand. Then stomp on the brakes,
and make sure that the wheels don't turn. Finally, let off the brakes,
and see if the wheels turn freely again. If one of them doesn't, open
the bleeder valve on that wheel cylinder or caliper. If you get a spurt
of fluid from the valve and the wheel suddenly turns freely, then the
problem is probably in the lines or master cylinder. If the wheel is
still stuck, then the problem is probably in the wheel cylinder or
caliper.
An alternative way to see if a brake is dragging lightly is to travel in
a straight line for some distance, stop, then compare the temperatures
of the wheels from side to side. If you're optimizing for cheap, you
can check with a careful hand or wet fingertip. If you're optimizing
for shiny, this is a perfect excuse to buy one of those infrared remote
thermometers. If you can't travel in a straight line, one of the brakes
might be dragging more than lightly, or possibly the vehicle control
system is affected by ethanol.
I know that an airplane, in general, is not a car. On a Cessna 182, the
one airplane that I've been around the most, if you start at the wheels
and work in, the system is similar to a car. There is a pad moved by a
piston at the wheel. Then, there is some combination of hard line and
flex line that goes from the wheel back to the fuselage - the flex line
is there to account for relative motion between the wheel/landing gear
and the fuselage. Then it's hard line back to the master cylinder. The
mechanical linkage to operate the master cylinder is different, but the
principle is the same as in a car.
It could be that your airplane doesn't have any flex lines in its
braking system. In that case, you have to decide whether to go after
the wheel cylinder or the master cylinder next. You might be able to
swap existing parts from side to side to see if the trouble follows the
part or not. Or, tear down the parts from both sides, and play "One Of
These Things Is Not Like The Others."
Disclaimer: This is based on experience with braking systems on ground
vehicles. I don't have an A&P; I don't even have a TG&Y. Some of this
may not be allowable owner maintenance. Your mileage may vary.
Matt Roberds
Old March 9th 07, 02:10 AM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck
Didn't you just have an annual?
Nope. We're doing the annual as soon as we get back from Texas, cuz
we suspect it's gonna be a long one. (Still gotta find that fuel seep
in the right wing, which could turn into a hunting expedition, which
-- usually -- means lots of time, parts, waiting, waiting,
waiting....)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 9th 07, 02:14 AM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck
Thanks, Matt -- I appreciate the brake system primer. I will
definitely be checking the flexible lines.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 9th 07, 02:19 AM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck
Sorry about the brake deal. Things like that suck almost as bad as having
them happen "on the road".
I'm incredibly thankful that this happened at home, and not at some
little podunk airport in Oklahoma, where we had stopped for lunch next
Sunday.
Ever try to find emergency repair service on a Sunday? Oh,
wait...we'll always have Dalhart...
Okay, anywhere OTHER than Dalhart, Texas, losing a brake would have
been a real mess. We'd have been stuck for days, waiting for parts,
and listening to an ever-growing crescendo of whining from the
chitlins...
This worked out as well as could be expected -- as long as Spruce gets
those parts to me tomorrow morning...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 9th 07, 05:44 AM posted to rec.aviation.piloting,rec.aviation.owning
Jack Allison
resulting in advanced wear like this? Or should I keep blaming Mary
for riding the (right) brake?
No no no...it's "Hail Mary", not "Blame Mary". :-)
Jack Allison
PP-ASEL-Instrument Airplane
"To become a Jedi knight, you must master a single force. To become
a private pilot you must strive to master four of them"
- Rod Machado
(Remove the obvious from address to reply via e-mail)
Old March 9th 07, 12:03 PM posted to rec.aviation.piloting,rec.aviation.owning
Maxwell
"Jay Honeck" wrote in message
ps.com...
Sunday.
Where are you having lunch in Oklahoma?
Old March 9th 07, 12:59 PM posted to rec.aviation.piloting,rec.aviation.owning
Steve Foley
"Maxwell" wrote in message
My choice would be Durant, and grab a ride to Chucks BBQ.
Old March 9th 07, 01:32 PM posted to rec.aviation.piloting,rec.aviation.owning
Maxwell
"Steve Foley" wrote in message
news:AScIh.7993$pi.2627@trndny09...
Indeed. But I was going to recommend Ponca City. Excellent mexican food
located right on the field.
Old March 9th 07, 03:13 PM posted to rec.aviation.piloting
Edwin Johnson
That is an excellent recommendation - everything made there and is quite
famous among the pilot crowd.
One thing however: call and make sure they are open on Sunday (believe
that's when you were going) for they used to close on the weekends or part
of them.
....Edwin
__________________________________________________ __________
"Once you have flown, you will walk the earth with your eyes
turned skyward, for there you have been, there you long to
return."-da Vinci http://bellsouthpwp2.net/e/d/edwinljohnson
Old March 9th 07, 04:05 PM posted to rec.aviation.piloting,rec.aviation.owning
NW_Pilot
"EridanMan" wrote in message
ps.com...
Ouch...
This is one of those stories that makes me glad that I didn't spend
the extra money (and lost useful load) to install Toe-Brakes in 61J...
Yes it was odd... for the first 5 minutes of taxiing.
After seeing two of my old club's planes go through a set of pads per
100 hour inspection (one of them having a similar catastrophic right
(I believe) break failure... only during a landing... only a VERY good
instructor prevented a ground-loop). And then hear stories like this
from a very experienced pilot no-less...
I can't say I miss them.
I have had a right break failure in a piper with toe brakes also right brake
stuck upon applying them.
timing holds [email protected] Instrument Flight Rules 16 February 17th 05 12:18 AM
Approach Timing john smith Instrument Flight Rules 36 September 9th 04 03:37 PM
Timing light for electronic ignition Ron Home Built 4 August 20th 04 05:18 PM
internal timing of slick magneto Jerry Jensen Home Built 1 June 25th 04 07:59 PM
Timing on Subaru EJ22 ??? Randy Rotorcraft 1 November 9th 03 06:15 AM
