Unclear Clearance
Old April 11th 07, 12:58 PM posted to rec.aviation.ifr
Andrew Sarangan
Default Unclear Clearance
When ATC says you are "cleared" that is exactly what that means. You
are ok to proceed from that instant. The exceptions are when they add
"hold for release". At tower controlled airports, you are actually on
hold for release because you need a separate clearance for takeoff, at
which point you are considered to be released into the system.
On Apr 11, 2:11 am, "Travis Marlatte"
"Andrew Sarangan" wrote in message
ps.com...
I am unclear on why you thought this clearance was unclear. You were
cleared to D95 and you were told to climb to 5000. What additional
instructions were you expecting to make that clearance valid?
Regarding the squawk code, it is not all that unusual to get the code
on the first call and get the complete clearance afterwards.
I dunno.
I guess I am more used to the three-step process of filing the clearance,
receiving the clearance, and finally being released into the system. On the
ground, that always happens.
Someone suggested that I don't air-file very often. That's probably true in
the big scheme of things but I have done it a good number of times. I don't
ever remember questioning whether I was really cleared or not before so
maybe I'm just having a brain fade.
I think I was expecting something like, "readback correct. Proceed on
course. Climb maintain 5000."
Someone suggested that as soon as the words were spoken they would have
turned and climbed. That doesn't seem right. That seems like it doesn't give
the controller a chance to manage their airspace. In my mind, I'm leaving
room for something different. Such as, "readback correct. Fly heading 030
for traffic. Climb maintain 3000. I'll have higher for you in a few miles."
OK. I'm done. Every response has been along the lines of "what's the
problem!" so I guess it's just me.
Travis
Lake N3094P
PWK
Old April 11th 07, 03:22 PM posted to rec.aviation.ifr
Peter R.
Travis, you were wise to ask about this scenario here. Do not take the few
"duh!" replies personally. This is a discussion group that serves more than
just the contributors. There were most likely many more in lurk mode who
benefited from your legitimate question and the responses it received.
Peter
Old April 11th 07, 04:07 PM posted to rec.aviation.ifr
Mark Hansen
I'll second that! - Travis: Thanks for bringing this up.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old April 11th 07, 04:21 PM posted to rec.aviation.ifr
Newps
The airspace management happened before he read you the clearance.
Besides you're flying at 120 knots, it's hard for you to cause problems.
Old April 11th 07, 09:54 PM posted to rec.aviation.ifr
Scott Skylane
Newps wrote:
/snip/
Hey, Travis never said anything about being in a power dive
Happy Flying!
Scott Skylane
(Ducking from the Lake drivers around here!)
Old April 11th 07, 04:19 PM posted to rec.aviation.ifr
Newps
With the exception being the controller gave him a code and then said he
was going to look for his clearance. If he finds one it will have a
different code on the strip so either the pilot will have to change
codes or the controller will have to make an ammendment on the flight
plan. That's working too hard.
Old April 13th 07, 05:13 AM posted to rec.aviation.ifr
Guillermo
On Apr 9, 10:48 pm, "Travis Marlatte"
This didn't cause any problems other than some additional radio traffic but
it caught me off guard. Let me know what you think...
As many people already stated, once you hear the magic words "cleared
to", it means you are already in the system, under IFR (you can now
fly in the clouds and do whatever they told you to do)
I had another situation where it was a little more unclear, when
departing from an uncontrolled field, IFR plan on file:
70V: "jax center, Cessna 70V at xxxx, would like to pick up IFR
clearance to FTY"
JAX:"70V, squawk 1234, climb to 5000, I'll have the rest of your
clearance in a few minutes"
5000 feet would put me in the clouds, and having not heard the words
"cleared to", I wasn't sure if I was considered to be flying IFR at
this point, so I told the controller that 5000 would put me in the
clouds, and he responded to go ahead, that I was already IFR.
So you can be IFR already even without having received your complete
clearance.
When the controller issues a "Climb to 5000", it IS a clearance, even
though it does not tell you where you are going (yet).
Old April 13th 07, 01:16 PM posted to rec.aviation.ifr
Jose
clearance to FTY"
clearance.
Well, that was an improperly delivered clearance. What do you do if you
lose comm? (I suppose fly your flight plan, and hope he actually finds it.)
No, I would not rely on that to be true, at least not without asking
=explicitly= if I am IFR.
Jose
Get high on gasoline: fly an airplane.
Old April 13th 07, 04:03 PM posted to rec.aviation.ifr
Mark Hansen
clearance to FTY"
clearance.
I don't think that's true. The FARs say that clearance must include the
words "Cleared to...". In such a situation, I think the correct thing
to do is ask, as you did. However, I don't think what the controller
initially gave you should generally be interpreted as a clearance.
Sacramento, CA
Old April 13th 07, 06:35 PM posted to rec.aviation.ifr
Ron Natalie
Really, what FAR would that be? The FARs aren't much on phraseology.
Unclear Clearance Mitty Instrument Flight Rules 53 December 24th 05 02:36 AM
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Taxi Clearance Ron Rosenfeld Instrument Flight Rules 27 September 29th 05 01:57 PM
Clearance with an Odd Intersection Marco Leon Instrument Flight Rules 92 March 11th 05 03:16 PM
GPS clearance puzzle Roy Smith Instrument Flight Rules 26 December 9th 04 12:22 AM
