Inner Tubes
Old May 14th 07, 12:17 AM posted to rec.aviation.owning
john smith[_2_]
Default Inner Tubes
In article .com,
Jay Honeck wrote:
Mary and I fill the tires at least twice a month. It's her least
favorite task, since -- thanks to our Fancy Pants -- it's a real bitch
to do.
Hmm... I would have reworded that sentence so that there was no
ambiguity as to what and whom I was referring. ;-)
Old May 14th 07, 04:23 AM posted to rec.aviation.owning
Jay Honeck
Default Inner Tubes
Ha! And here I was worried about that "pushing and pulling" line...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 14th 07, 04:05 PM posted to rec.aviation.owning
Blanche
Default Inner Tubes
Jay Honeck wrote:
Both my mechanic and Desser recommended the Aero-Classic LeakGuard
tubes. We installed them a couple years ago and I can't remember the
last time I filled them. Definitely more expensive than a regular tube,
but worth it.
Now that is high praise.
to do.
I don't like the wheelpants on a cherokee either - most of the time,
they're sitting in the back of the hangar. However...I took the
electric air pump over to my neighborhood hardware store (strangely
enough, one of the Big Box stores!) and probably the only staffer
there who knew anything about tools picked out a 2-way chuck,
one of those widgets that are tapered at each end
to act as a splice on hoses, and (are you ready for this?)
actually INSTALLED the stuff on my air pump! I think it was the most
interesting activity he had all day. Cost me the price of the
widgets.
He was retired from the Navy, was the equivalent of an A&P in
the Navy, and he told great stories of being on a carrier while he
built the gadget.
Now, I can add air to the tires really easy, and no longer bend
the rubber valve - which forced me to buy another tire & tube in
the past.
Old May 15th 07, 03:25 AM posted to rec.aviation.owning
Jay Honeck
Default Inner Tubes
the past.
Hmmm. That *might* work, but the real problem is that the little
hatch doors on the Fancy Pants don't line up well with the location of
the valve stem.
(On our old Warrior's stock wheel pants, you could reach the valve
stem from under the bottom of the wheel pants. No-can-do with the
Fancy Pants, which fair the wheel almost all the way to the ground...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 13th 07, 05:08 PM posted to rec.aviation.owning
Roger (K8RI)
Default Inner Tubes
On Sun, 13 May 2007 06:49:14 -0400, Doug Vetter
RST Engineering wrote:
Anybody got a lead on who has them for relatively few AMUs for common sizes
like 600-6 and so on?
but worth it.
I put them on the Deb nigh onto two years ago? Been quite a while any
way. It's been over a year since I put air in them. Late this past
winter I checked them and they were still right where I had put them.
Yes, they cost a bit more, but as I recall they weren't all that much
more and I heartily agree, they are worth it.
-Doug
Where can you get empty caulking gun tubes... Jerry Wass Home Built 16 March 3rd 11 04:36 PM
Connecting hoses to pitot/static tubes Ernest Christley Home Built 9 October 23rd 06 01:44 PM
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup Juan Jimenez Aviation Marketplace 7 September 19th 06 10:20 PM
Leak proof tubes Roger Owning 9 December 8th 05 09:15 AM
Seeking US Source for Main Wheel Tubes Chris OCallaghan Soaring 7 August 28th 04 03:46 PM
