aerobatic power to weight ratio
Old August 5th 08, 01:45 AM posted to rec.aviation.piloting
Morgans[_2_]
Default aerobatic power to weight ratio
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote
B. Control would be a problem. Hanging from the prop results in torque
rolls. Airplanes don't have tail rotors or cyclic control over the
propeller.
Sean Tucker overcomes the torque with 4 great big ailerons on a biplane,
with the prop wash giving enough deflection to keep him pretty straight.
Old August 5th 08, 01:43 AM posted to rec.aviation.piloting
Morgans[_2_]
"Superdoof" wrote
Is this technically feasible, or have the aircraft already reached a
developmental limit ?
Sean tucker has already perfected the hover, in his Super Pitts.
Old August 5th 08, 04:42 AM posted to rec.aviation.piloting
Adam Cope
http://video.google.com/videoplay?do...92639009239481
Wayne Handley had his Turbo Raven that crashed in 99. It could hover and
then climb.
Adam
Adam Cope
www.dcaerobatics.com
703-623-9445
"Superdoof" wrote in message
Hi,
I've noticed in the videos at www.fulldeflection.com that all the top
aerobatic aicraft, such as the Sukhoi SU-31, Egde 540, Extra 300,
etc., can almost hover.
It seems that within a few years they will be able to climb on power
alone.
Aerobatics will look completely different once that occurs. Can you
imagine Svetlana Kapanina hovering her Sukhoi for a couple of minutes
at 300', then reversing down to an even lower altitude. I can imagine
Peter Besenyei performing the perfect square shaped hover in his Extra
540.
Superdoof.
Old August 5th 08, 03:12 PM posted to rec.aviation.piloting
Gig 601Xl Builder
Superdoof wrote:
Hi,
alone.
540.
Superdoof.
If the trick is done with purely with power it really isn't that
spectacular. Think about what you described above. It can be done today
by a student pilot in a helicopter.
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 04:24 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
Diesel engines- forced induction, power-weight Jay Home Built 4 December 7th 03 09:23 AM
