GPS-NAV security sealing
Old August 27th 08, 03:50 AM posted to rec.aviation.soaring
Paul Remde
Default GPS-NAV security sealing
Hi,
Yes, it is possible to change the backup battery without breaking the seal.
Just keep the unit powered with 12V power while replacing the backup
battery.
The customer that started this thread had the backup battery get too low and
die before it was replaced. The unit then had a security failure and needs
re-sealing.
Paul Remde
"Fred Blair" wrote in message
Can't you change the internal battery before it gets real low without
breaking the seal?
On Aug 25, 10:54 pm, Sam Discusflyer
Is there a way to input a security code in a Cambridge GPS_NAV and seal
it
without spending hundreds of dollars?
Inquiring minds want to know.
Steve Michalik
Exact cost for 1 day turnaround by Gary at NK the week before last was
$130 including memory battery , calibration chart,and next day return
delivery.
My experience is that this is excellent service for a very fair price.
Certainly not the "hundreds of dollars" you seem to anticipate.
UH
Old August 27th 08, 04:24 AM posted to rec.aviation.soaring
HL Falbaum
"Paul Remde" wrote in message
news:vh3tk.315622$yE1.151194@attbi_s21...
Hi,
seal. Just keep the unit powered with 12V power while replacing the backup
battery.
and die before it was replaced. The unit then had a security failure and
needs re-sealing.
Paul Remde
breaking the seal?
it
Steve Michalik
delivery.
UH
The old Cambridge DOS program for the PC reads the voltage of the backup
battery. The Cambridge Nav head also shows the backup voltage upon power-up.
It pay to obsesrve this from time to time.
Hartley Falbaum
USA
Old August 27th 08, 05:09 AM posted to rec.aviation.soaring
Sam Discusflyer[_2_]
Yes these are all good answers. And yes I let the battery get low. And you
change the lithium battery while it's hooked up to external supply. But
no I don't use the GPS_NAV display so the voltage doesn't show all the
time. And it will be less cost if I ship through the post office. And no
offense to the vendors.
In this age of computers and rising fuel costs and shipping costs plus
insurance, isn't it possible to make better use of technology and provide
for security sealing by computer communication? We transfer money
electronically don't we? A lot of people have done electronic payments
right? You can give control of your PC to someone over the internet and
they can run a software program on their computer to load a device hooked
up to your computer. And so me average joe doesn't have the key program
to cheat (like I really want to anyway). I know this communication is
possible because I've done it.
So why is it not possible to hook up the GPS unit to the PC connected to
the internet, connect with the key master and load the serial #?
You can still pay the $20 or $40 dollar cost to the proprieter with paypal
or visa and both parties are happy.
I guess I still have to support Brown Company anyway. Thanks for the
discussion.
Steve Michalik
Hi,
backup
battery.
low
and
needs re-sealing.
Paul Remde
breaking the seal?
seal
it
Steve Michalik
was
delivery.
price.
UH
backup
power-up.
Hartley Falbaum
USA
Old August 27th 08, 05:22 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Open up case, insert $2 microcontroller between GPS receiver and flight
recorder logic board, close case, call up manufacturer say "hey my
flight recorder unsealed itself", reload key, go set some world records.
The manufacturer or designated agent is supposed to inspect the interior
of the unit for tampering before resealing. Otherwise, there's not much
point to sealing it in the first place...
Marc
Old August 27th 08, 09:21 AM posted to rec.aviation.soaring
ContestID67
A few comments on this thread;
- A reseal is not a recalibration. A recalibration might include a
reseal.
- The $140 (in my case) for NK is to do a complete recalibration
(required by FAI/SSA every 2 years). What does a recalibration do?
As far as I know it doesn't change anything in the recorder. It only
reviews how the pressure altimeter (versus GPS altimeter) relates to
reality. The recalibration process is to put the recorder into a
barometric (hyperbaric) chamber, then change the pressure in the
chamber to preset altitudes, get the recorder's altitude reading and
finally produce a report of any altitude offsets. NK also changes the
battery on GPS-NAVs (which means that they unseal and reseal the
unit?). Is there anything else that is done during a recalibration?
If so it does seem kind of pricey. But then I don't know how much a
barometric chamber costs these days.
- Craggy Aero's cost of $40 (plus s/h) is for a reseal only. Why do
recorders get unsealed? Physical tampering/opening or mechanical
failure are my only thoughts. Are there other possibilities?
- Resealing via the Internet? I'm up for that. But what seems easy to
implement probably isn't in a secure fashion (PC Anywhere
nonwithstanding). In reality there just isn't enough need for reseals
to pay for the development necessary to make this happen...with every
manufacturer...and get FAI approval to do so.
- About why we need all this damned security anyway (from the
Newbie). No doubt there have been cases of tampering with the
evidence, human nature being what it is. I can also imagine that
during the migration from mechanical recorders to electronic
recorders, there was a fear that electronics were more suseptible to
tampering. Mechanical recorders seem more secure because you can SEE
what they are doing. It's called resistance to change which is rather
rampant in the aviation field. Thus they chose to set the security
bar high. How high? You can't open the device without tripping the
unsealed flag. I guess I don't call that too invasive.
- How can Craggy (and others) do a reseal or recalibration but not us
regular Joes? Craggy has been blessed by the manufacturer similar to
being an authorized service center. He also has the proper
equipment. I believe for a reseal, he also has to call the
manufacturer to get a code. Could he get in cahoots with someone to
fake a world record? It would take some pretty good technical skill
to tamper with things, but if you could, consider the fame and
fortune!! Yeah. Right.
- I may be a heretic to say so but is a recalibration really
necessary? Hmmmm. I don't see an OLC rule requiring it. Do they ask
for calibration documentation at regional, national or world
competitions? For badges you are requested to send in a copy of the
recalibration report (less than 2 years old as of the date of the
flight). However, you can wait up to 1 month AFTER your epic flight
to get the recalibration done. Strange but true. My calibration is
due next Feb. However, I am unlikely to need it any time soon unless
I get a lucky break and make a gold leg. I will probably wait until
after my next epic badge flight. I am less clear about the rules
surrounding records.
- Is a reseal really necessary? I would have to say yes. A broken
security seal marks the IGC file as forever bad. No amount of
resealing or recalibration will fix that. This means that you epic
flight is toast and only good for vicarious reliving of your past
glories in SeeYou.
My $0.02.
- John DeRosa
Old August 27th 08, 01:21 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
On Wed, 27 Aug 2008 01:21:12 -0700, ContestID67 wrote:
Minor clarification:
For badges you are requested to send in a copy of the recalibration
report (less than 2 years old as of the date of the flight). However,
you can wait up to 1 month AFTER your epic flight to get the
recalibration done.
A calibration certificate within -2yrs to + 1 month is only needed for a
height claim, not for distance or duration. In these cases the logger
altitude doesn't need to be accurate because all it has to do is to show
that you didn't land and take a relight or trailer the glider during the
task.
That applies here in the UK and, AFAIK, worldwide unless you have local
rules I don't know about.
Strange but true. My calibration is due next Feb.
I don't think that's so strange. The logger isn't likely to drift much
during that month.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 27th 08, 02:47 PM posted to rec.aviation.soaring
Richard[_1_]
for security sealing by computer communication? *We transfer money
right? *You can give control of your PC to someone over the internet and
possible because I've done it. *
the internet, connect with the key master and load the serial #? *
discussion.
Steve Michalik
"Paul Remde" *wrote in message
Hi,
backup
battery.
low
and die before it was replaced. *The unit then had a security failure
and
needs re-sealing.
Paul Remde
"Fred Blair" *wrote in message
breaking the seal?
*wrote in message
seal
it
Steve Michalik
was
delivery.
price.
UH
The old Cambridge DOS program for the PC * reads the voltage of the
backup
power-up.
Hartley Falbaum
USA- Hide quoted text -
- Show quoted text -
Sam,
I provide calibration for $60 + $40 to reset seal = $100 + shipping.
My Standard turn is 1 day. If I receive today I will ship back
tomorrow. I find that many customers appreciate this service as they
can save $ on shipping by using US Priotiy Mail or FEDEX Saver.
I would replace the battery every year. They are inexpensive.
Powering the recorder while replacing the battery does not break the
electronic security seal. Take the top cover GPS Antenna off while
the recorder is powered and replace the battery. Use a CR2330
battery, this is 5mm thicker than the recommended battery BR or CR
2325, and insures good contact.
http://www.craggyaero.com/calibration.htm
Thanks
Richard
www.craggyaero.com
Old August 27th 08, 03:36 PM posted to rec.aviation.soaring
Paul Remde
Hi Steve,
I understand your point and I agree with it. I do web conferencing all the
time and connect to the customer's computer so I can see that they are doing
and walk them through procedures. With their permission I can even control
their PC. That method could probably be used to re-seal your GPS-NAV. I
would be in control from my office and I would enter the re-seal codes told
to me over the phone by NK. Give me a call if you want to give it a try.
Since I'm in full control and you can't duplicate what I'm doing, I don't
see any reason why there would be any security concerns.
Paul Remde
"Sam Discusflyer" wrote in message
discussion.
Steve Michalik
Hi,
backup
battery.
low
and
needs re-sealing.
Paul Remde
breaking the seal?
seal
it
Steve Michalik
was
delivery.
price.
UH
backup
power-up.
Hartley Falbaum
USA
Old August 27th 08, 03:37 PM posted to rec.aviation.soaring
Paul Remde
Hi Marc,
Good point. I really would need to have the unit in hand.
Paul Remde
"Marc Ramsey" wrote in message
recorder logic board, close case, call up manufacturer say "hey my flight
Marc
Old August 27th 08, 03:39 PM posted to rec.aviation.soaring
Paul Remde
Hi Steve,
Never mind. I guess it makes sense for me (or NK) to have the unit in hand
to make sure it hasn't been tampered with. That is the reason for the
existing process.
Paul Remde
news:7Edtk.261163$TT4.65181@attbi_s22...
Hi Steve,
the time and connect to the customer's computer so I can see that they are
doing and walk them through procedures. With their permission I can even
control their PC. That method could probably be used to re-seal your
GPS-NAV. I would be in control from my office and I would enter the
re-seal codes told to me over the phone by NK. Give me a call if you want
to give it a try. Since I'm in full control and you can't duplicate what
I'm doing, I don't see any reason why there would be any security
concerns.
Paul Remde
you
paypal
discussion.
Steve Michalik
Hi,
backup
battery.
low
and
needs re-sealing.
Paul Remde
breaking the seal?
seal
it
Steve Michalik
was
delivery.
price.
UH
backup
power-up.
Hartley Falbaum
USA
Sealing The PIK-20B Canopy P. Corbett Soaring 5 August 21st 05 08:32 PM
Sealing an ASW 28 canopy Bob Caldwell Soaring 13 August 10th 05 09:59 PM
Sealing a Schweizer; 1-35 mainly TOM RENT Soaring 0 April 11th 04 08:46 PM
Libelle Gap Sealing Owain Walters Soaring 4 April 11th 04 07:13 PM
sealing cork float against gasoline - how to... jt Home Built 13 July 18th 03 10:51 PM
