Tried to send an email to Bumper to get instructions for the MK IV yaw
string installation. The email address on the package and what I have by searching RAS bounces. Anyone have the instructions or a valid email address for Bumper? Thanks in advance |
Thanks in advance his new email address: I have a copy somewhere I could scan/send, but it's kinda long winded... It just tells you to make a paper template of the V shape and use that to locate the string before sticking it on. I drew a centerline on my V template to help with alignment. He also recommends using a piece of string or yarn going from tip of nose to center tip of tail to establish the actual centerline down the canopy (look at string from front first, adjust as necessary) so you get it on centered. Carefully tape template on center at desired fore/aft position and then install yawstring. -Paul |
On Jun 6, 7:25*am, Ron Gleason wrote:
Tried to send an email to Bumper to get instructions for the MK IV yaw string installation. *The email address on the package and what I have by searching RAS bounces. Anyone have the instructions or a valid email address for Bumper? Thanks in advance Hi Ron: How goes it? I haven't had time to peruse ras for awhile but have spend much of the weekend recuperating from a nasty biking accident. Re yaw strings and slipping turns, here's a useful old thread from this newsgroup, focus on about message 26 onward: http://groups.google.com/group/rec.a...tring+&lnk=nl& Best Regards & Hello to Elsa, Gary Osoba |
On Jun 6, 9:32*am, Warren wrote:
Ron, John and I just traded a few emails. His address is Warren Thanks to all. I have the instructions and bumpers new email address |
Gentlemen,
Email addresses posted in network news groups are often obfuscated so that network idiots don't pick them up and flood you with spam. I read RAS via Google which does this to all the email addresses (and something similar to web site addresses). The end result is that the email address you mention above for Bumper is impossible to use. The alternative is to use something like "johnatyahoo.com" - hopefully it is obvious to substitute the "at" with an "@" sign to get a legitimate email address. Thanks! John |
Sorry for the confusion with email addresses. Looks like it's going to
happen again, as Verizon is dumping customers in some states (including NV). Next time I think I'll use an address not tied to an ISP. For now, though, it's still bumperm at verizon dot com Not to worried about bots or idiots picking that up as it's only good for another month or two. I'll post the new address here, as well as sending an email to my contact list. Yup, the installation instructions a bit long, one full page . . . I have a free replacement policy even if you goof on the install, so I want to make sure you don't (g). all the best and thank you for being my customers, bumper zz Minden |
On 6/6/2010 7:27 PM, bumper wrote:
Sorry for the confusion with email addresses. Looks like it's going to happen again, as Verizon is dumping customers in some states (including NV). Next time I think I'll use an address not tied to an ISP. For now, though, it's still bumperm at verizon dot com It's really bumperm at verizon dot NET. Since he is a recent Verizon customer, we'll forgive him; unfortunately, Verizon is going to dump him as a customer before he has a chance to remember it! They are dumping me, too, so I'm also looking for a permanent, non-ISP related email address. And, as long as I have change email addresses, I might as well look at other ISPs, and not just accept the one Verizon is selling us to (Frontier.com). -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
You don't need Bumper to install the Mark IV...anyone can do it.
Simlpy drill a 1/2 inch hole in your canopy and place a 1/2 diameter stove bolt in the hole. These are available on the aviation aisle at Home Depot. Put a nylok type nut on it ...leave it loose for now. Wrap the Mark IV around the bolt several times and secure it with a standard stevadore's Fernortner Hitch. Now carefully torque the stove bolt to 4500 Foot Pounds. Don't over torque. Finally, mix up a batch of Shell Epon 925 aviation epoxy and drizzle this goo on the bolt. Don't get the epoxy on the string. If you do epoxy the string make sure it is lined up on the longitudinal axis...you will feel a whole lot better about your flying. Next place 4 pounds of lead in the tail to re-balance the glider. Now get your log book out and log the install. Don't forget to have the glider re-weighed to verify proper balance. That's it. See, it's easy and I am sure that Bumper would approve of this procedure. Paul ZZ On 6/6/2010 7:25 AM, Ron Gleason wrote: Tried to send an email to Bumper to get instructions for the MK IV yaw string installation. The email address on the package and what I have by searching RAS bounces. Anyone have the instructions or a valid email address for Bumper? Thanks in advance |
On Jun 6, 10:46*pm, ZZ wrote:
You don't need Bumper to install the Mark IV...anyone can do it. Simlpy drill a 1/2 inch hole in your canopy and place a 1/2 diameter stove bolt in the hole. These are available on the aviation aisle at Home Depot. Put a nylok type nut on it ...leave it loose for now. Wrap the Mark IV around the bolt several times and secure it with a standard stevadore's Fernortner Hitch. Now carefully torque the stove bolt to 4500 Foot Pounds. Don't over torque. Finally, mix up a batch of Shell Epon 925 aviation epoxy and drizzle this goo on the bolt. Don't get the epoxy on the string. If you do epoxy the string make sure it is lined up on the longitudinal axis...you will feel a whole lot better about your flying. Next place 4 pounds of lead in the tail to re-balance the glider. Now get your log book out and log the install. Don't forget to have the glider re-weighed to verify proper balance. That's it. See, it's easy and I am sure that Bumper would approve of this procedure. Paul ZZ By posting your free DIY instructions for your heavy duty yaw string, you've likey desimated 12 years of development and labor that's gone into the, relatively speaking, delicate and frangible MKIV. How am I supposed to compete with that? BTW, you forgot to mention your yaw string mounting bolt should easily accept a Tost hook.This will quickly become the accepted and preferred tow hook position for all gliders as the pilot can easily sight right down the tow line to positively, absolutely stay in position behind the tow plane. And if the tuggie feeds you the rope 'cause he doesn't approve, "What the heck!" it's just another big, very well damped, yaw string streaming back. bumper bumperm at verizon dot net (thanks Eric) |
MKIII yaw string sale | bumper | Soaring | 38 | November 28th 15 03:22 PM |
Clear Yaw string tape? | Bruno | Soaring | 42 | August 30th 13 05:56 PM |
Mk II yaw string | Warren | Soaring | 19 | September 4th 09 01:00 AM |
Wikipedia:Yaw string | Doug Haluza | Soaring | 18 | January 30th 07 02:52 PM |
Yaw String in a Spin | John Galloway | Soaring | 52 | January 21st 05 10:14 PM |
