#21
Ron Webb wrote:
There is no difference between mild steel and 4130 as far as corrosion resistance is concerned, Now you have got my curiosity in gear. As I said, my personal experience is that I have seen a significant differance. I went looking for some quantized data on the subject. I have not found what I was looking for on the net, and may run up to the University library later on. For now I found http://www.armycorrosion. com/summit2001/DAY_1_PM/schario.pdf It does not have much in the way of quantized data, comparing 1010 to 4130 corrosion properties, but there is enough to refute the claim that there is no differance. The stuff in my garage doesn't seem to notice any difference. It is more than happy to rust if I don't do anything to protect it. It could be that it happens slower; I haven't done any sort of scientific testing to see. But the bottom line is that rusty is rusty. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Agreed...but if it took 30 years to rust out the back of the longerons on your new float equipped Bearhawk to the point of them being unsafe, since they are .049" 4130 - but it would take 100 years to do the same thing to ..063 1010 --that might be enough to tip the scales if the weight differance was 20 pounds or so... OK, I'll admit it...I made the longerons on my MoHawk out of 1/2 x.032 4130 too, just like the plans say...but there are MANY things I'd do differently if I was starting over...like start with a set of Bearhawk plans for instance;^} |
In Ron Webb wrote:
Agreed...but if it took 30 years to rust out the back of the longerons on your new float equipped Bearhawk to the point of them being unsafe, since they are .049" 4130 - but it would take 100 years to do the same thing to ..063 1010 --that might be enough to tip the scales if the weight differance was 20 pounds or so... My position is that if the lower longerons are getting rusty, there are other parts in there that I need to be just as concerned about. Beefing up parts doesn't make the airframe any stronger necessarily, it only shifts the weak point elsewhere. I would expect that to be true of corrosion issues as well as overall strength. I would rather go the extra mile with corrosion protection measures NOW while the plane is under construction, than add a bunch of unneeded weight by making everything thicker. In 20-30 years I will most likely want to tear the fabric off and inspect everything closely no matter what anyway. I've got a sandblaster and I'm not afraid to use it. OK, I'll admit it...I made the longerons on my MoHawk out of 1/2 x. 032 4130 too, just like the plans say...but there are MANY things I'd do differently if I was starting over...like start with a set of Bearhawk plans for instance;^} I hear that a lot. 8^) ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
A building material that is less expensive and more available may in
practice end up building a lighter airframe. The reason is that you're more likely to be able to use the exact right stock instead of just over building because you couldn't find or afford the expense to buy a special piece of the lighter guage material. Bend versus break. Old cars were build on rigid chassis, the safety argument was that you want something really strong. But modern cars are generally built uni-body designated crush zones to dissipate some of the energy instead of transfering it to the passengers. "In theory, practice and theory are the same. But in practice, they are often very different." |
In Jay wrote:
A building material that is less expensive and more available may in practice end up building a lighter airframe. The reason is that you're more likely to be able to use the exact right stock instead of just over building because you couldn't find or afford the expense to buy a special piece of the lighter guage material. Speak for yourself. If my plans call for a specific material, that is what I use. On the couple of occasions where I have deviated, I placed long distance calls to the designer to get his okay on the changes. Bend versus break. Old cars were build on rigid chassis, the safety argument was that you want something really strong. But modern cars are generally built uni-body designated crush zones to dissipate some of the energy instead of transfering it to the passengers. I'm all in favor of less rigidly constructed car chassis for other people. That way, when I get into a collision with one of them, they will serve as a crush zone for my rigid chassis and heavy duty bumpers. If I get into an accident where (for example) my '73 pickup truck isn't sufficient to protect me, chances are I wouldn't want to survive that anyway. Not to say I won't try to improve my chances where it makes sense; I just finished fabricating a set of brackets to convert the old beast from lap belts only to lap with shoulder belts. "In theory, practice and theory are the same. But in practice, they are often very different." "No plan survives contact with the enemy intact." ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
"Ernest Christley" wrote in message http://www.ernest.isa-geek.org/
What is a typical critical angle of attack for stalling on the Dyke Delta? I'm thinking it's somewhat higher than most because of the low aspect ratio. D. |
Capt.Doug wrote:
"Ernest Christley" wrote in message http://www.ernest.isa-geek.org/ What is a typical critical angle of attack for stalling on the Dyke Delta? I'm thinking it's somewhat higher than most because of the low aspect ratio. D. I think it is somewhere up around 90. 8*) Actually, it doesn't stall in the conventional manner. I will slow down and descend like a leaf once you hit MCR (minimum control rate), but at that point there isn't enough elevon authority to pull it to a stall. I have heard that it will spin, though. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
![]() "Capt.Doug" wrote in message ... "Ernest Christley" wrote in message http://www.ernest.isa-geek.org/ What is a typical critical angle of attack for stalling on the Dyke Delta? I'm thinking it's somewhat higher than most because of the low aspect ratio. D. It isn't the aspect ratio that gives it the high angle of attack. It is the delta characteristic, that all delta wings have. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.629 / Virus Database: 403 - Release Date: 3/17/2004 |
#29
#30
Gentlemen,
I have no real experience and very little formal training. The absolute reliance on 4130 is a wives tale. Very serviceable aircraft were and are built regularly with mild steel tube. For amateur construction mild steel makes more sense than 4130. On the Yahoo Piper Cub site in the files section is a factory drawing of a Super Cub fuselage. It is predominently mild steel in the sizes of 3/8-7/8 ..035 wall. These planes did not rust away or disappear from tubing failure. The US military materials book from WW2 notes that after welding 4130 is reduced substantially in tension, 74 thousand #/ as compared to mild steels 54 thousand #/, and the compression of tubes is a minor difference in the lengths we deal with. Please reference Bob Whittier's book on tubing for this discussion. The problem of weight moving backward is real but not a reason for not using mild steel. The Circa Nieuports with thier aluminum tubes work fine, it is a matter of design. A second coat of paint, a big swivel tail wheel, or balancing the elevator will be as much of a change and many homebuilts have these changes made over the plans regularly. If a guy can't keep control of his C of G then he needs help. I have done a design study using .049 mild steel to replace .035 4130 in a standard low wing Warren truss fuselage. The effect on the C of G was neglidgeable due to the increased weight in the forward fuselage were the largest and more cocentrated collections of tubing existed. The added weight in the tail feathers was compensated for with a movement of the speced A65 forward 2-3 inches. I've decided to use wooden tail feathers and actually save a lot of weight. Many homebuilts do not come close to the designers empty weight and operate over stated design grosses all the time, even those built from 4130. Or the guy who puts an extra hundred #'s of Lyc. and electrics in an A65 design is never questioned so severly as a guy who wants to use mild steel tube accepted and certified for aircraft construction by civil and military specs for 70 years. Many fine planes were built and designed using common sense, alternate materials and the engineering from established designs. Pete Bowers discussed this in his book on Homebuilts he wrote in the seventies prior to the litigation era we now live in. In fact I have a collection of fuselage plans from the past and they would appear to be designed in 1930 out of light gauge mild steel and copied since. Recently I saw some sitka from an established aircraft supplier. I wouldn't have used it for ladder rails. I have hand picked perfect quarter sawn Western Hemlock for a fraction of the cost at a local building store that was far superior to the aircraft grade stuff that cost more in brokerage fees than my wood. Get educated about inspection and alternatives using established experts and build around the limitation. A can of line oil or linseed oil used according to Tony Bingelis in a properly ventilated fuselage will take care of rust. Probably good idea with 4130 as well. |
Driving sheet-metal screws into 4130 | Grandpa B. | Home Built | 10 | February 3rd 04 07:23 PM |
4130 Chromaloy Sheet Availability | c hinds | Home Built | 1 | January 24th 04 04:17 AM |
Tube Cluster Weld Question | Dick | Home Built | 6 | January 17th 04 12:10 AM |
Pitts Special Steel Tube Fuse Mod. | Martin Morgan | Home Built | 0 | November 23rd 03 11:08 PM |
4130 frame? | Steve Thomas | Home Built | 23 | August 27th 03 05:50 PM |
