Garmin GPS 20A with Trig TT22 in Experimental Glider - OK?
Old December 18th 15, 03:29 PM posted to rec.aviation.soaring
Sarah[_2_]
Default Garmin GPS 20A with Trig TT22 in Experimental Glider - OK?
Hi Paul,
Here is a post from a Garmin engineer about compatibility of the 20A with the Trig TT22.
http://www.vansairforce.com/communit...60&postcount=5
Here is the list of certified GPS WAAS sources on Trig's web page currently:
http://www.trig-avionics.com/support...b-stc-program/
Putting the two together, it seems likely the 20A is compatible with the Trig. However you would need Trig to say that is so.
The link to the FAA page in the Van's forum post explains what the FAA expects for experimental non-TSO'd GPS WAAS sources.
None of this applies to non-Experimental gliders. The 20A is not permitted, a TSO'd GPS source is required. Since gliders don't ever seem to make it onto "approved model lists" in transponder/ADS-B STCs, a field approval would be required.
That's my understanding at least. Any traffic in the area that knows better, please advise.
Sarah Anderson
On Tuesday, December 15, 2015 at 11:25:30 PM UTC-6, Paul Remde wrote:
Hi,
I'm gaining knowledge in ADS-B over the years. But I can't say I'm an
expert. I could use some feedback from some of the extremely knowledgeable
people that monitor this group.
I sell Trig TT22 transponders - which are FAA approved for ADS-B when used
with an approved GPS source. But currently approved GPS units are $3500+.
I have been hoping that a much lower cost GPS unit "designed to meet the
requirements..." would become available in the future - making it possible
to have FAA approved ADS-B out that meets the requirements for 2020.
This week a customer pointed out a solution - I think. It is the Garmin GPS
20A. It sells for $845. That is still a lot of money for a WAAS GPS, but
it is a lot better than $3500. I believe the antenna is extra.
https://buy.garmin.com/en-US/US/in-t...rod525504.html
The web site says that it is approved for ADS-B out in LSAs. It is not
clear to me whether it would be legal to use it with a TT22 in an
experimental, or non-experimental sailplane.
I believe that ADS-B will make our flying much more safe. I am angry that
the FAA requires $3500+ GPS units at this time. They are reducing safety.
I'm not trying to push ADS-B down the throats of anyone. I am just trying
to fill a need. Many gliders already have TT22 units and might consider
adding an $845 GPS, but not a $3500+ GPS unit.
Also, it is my understanding that "field approvals" are required when
installing ADS-B out systems in certificated aircraft. Would there be a lot
of expensive paperwork necessary to get FAA approval for a system that
includes a TT22 and Garmin GPS 20A?
Any thoughts?
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old December 18th 15, 03:30 PM posted to rec.aviation.soaring
Richard Pfiffner
On Thursday, December 17, 2015 at 9:49:30 PM UTC-8, Mike Schumann wrote:
On Thursday, December 17, 2015 at 11:46:45 AM UTC-6, Andrew Ainslie wrote:
Apparently it can't just be any non TSO'ed GPS to be fully compliant. A few months ago the FAA opened up a new category whereby "equivalent" units could be used in Experimental, and this device of Garmin's is the first to fit this new niche. Hopefully others are following, including Trig. But agreed, it's ridiculous that we can't just use on of the other GPS's floating around our cockpits to give the TT22 the required information. Anything WAAS (hell, actually anything at all) is way better than either radar or nothing at all. Part of the frustration is that without ADS-B we get no input. It would be so nice to know where the power guys with mode C are relative to us. The FAA definitely needs someone like JC to explain why their strategy of "forcing" us to get ADS-B out in order to get in is deeply flawed, and the requirements to either spend over $3000 or be blind is equally dumb... But that ain't going to happen. In the interim, I'm going to keep hoping that a reasonable solution shows up.
There is an intermediate solution whereby you can hook up a non compliant unit but if you properly declare the signal, I don't think you get ADSB in but I don't recall the exact details. I'd prefer full compliance but I think it might be time to play with that option over winter.
The next problem, of course, is to get a transponder shop to help you get anything done. They are very leery of helping with experimental planes and non TSO'd options. My local guy just told me that he'd no longer do my transponder certification, even though the TT22 is a TSO'd unit and he installed it a year ago - he claims the FAA does not allow him to work on experimental. Sounds like baloney but not much I can do about it if he doesn't want to do the work.
Gliders are currently exempt from the 2020 ADS-B rules. As a result, you should be able to use a non-compliant GPS source with a Trig21 or Trig22, as long as the Trig is compatible with the GPS's datastream. Even though the GPS source is non-compliant, it will trigger the ADS-B ground stations so that you will get TIS-B and ADS-R transmissions.
This is what the Dynon Skyview systems do today. According to Dynon, this will continue to work after 2020 if you are flying in airspace where ADS-B is not required.
I expect that we will see affordable 2020 compliant GPS sources in the relatively near future. The Dynon units, which are suppose to start shipping by the end of this year, have set a pretty aggressive price point (under $600). While the Dynon module only works with the Skyview system, I was talking to an engineer at Trig a couple of months ago, who told me that they were planning to introduce an affordable compliant GPS source at a similar price point shortly after the Dynon units start shipping.
One thing that you should think about if you want to be fully 2020 compliant is that you buy a Trig21, NOT a Trig22 transponder. The Trig22, while it is ADS-B OUT compatible and will trigger the ADS-B ground stations, is NOT 2020 compliant.
Mike,
The TT21 is not 2020 compliant.
The TT22 is 2020 compliant
http://www.craggyaero.com/Trig/ADS-B Just Got Easy - Trig ADS-B STC
Richard
www.craggyaero.com
Old December 18th 15, 07:23 PM posted to rec.aviation.soaring
Darryl Ramm
To be clear here if your glider is certified you cannot install any old GPS source. You needs to meet the FAA requirements which includes a TSO'ed IFR GPS source, discuss with your A&P/FSDO.
Unless you are a super-geek wanting to play with this stuff, just wait and see what happens with ADS-B and TABS carriage requirements for gliders.
The FAA is making it clear that non-compliant ADS-B out sources will not continue to receive ADS-B ground services in the future even if they do now. January 2016 I think is the cutoff threatened/promised by the FAA, if SIL/SDA=0 from your GPS source you will not be provided ADS-R and TIS-B ground services. And in the meantime the friendly FAA may drop you a snail mail to remind you that your aircraft is flying around with a non-complaint ADS-B Out. Having an ADS-B Out system that triggers ADS-B ground based services (ADS-R and TIS-B) won't help you anyhow if your ADS-B receiver is a PowerFLARM which receives 1090ES direct and is not capable of receiving ADS-R or TIS-B data).
Good advice, if buying a transponder now and wanting best ADS-B options/flexibility in future. But in the big picture again this may change if TABS carriage regulations happen (the TT-21 meets TABS power requirements even if it does not meet ADS-B out power requirements).
Old December 18th 15, 07:56 PM posted to rec.aviation.soaring
Darryl Ramm
OK thanks for the private emails :-) Doh I did not spot the (likely accidental) transposition in Mike's post. To be clear the lower-powered Trig TT-21 does *not* meet the ADS-B out requirements in the USA. You need a higher-powered Trig TT-22 (and certified IFR GPS source). But as I said, TABS devices have lower power requirements so if TABS is adopted a TT-21 should be usable as a TABS device (and that includes triggering all the ADS-B ground infrastructure base services). But since there are no TABS installation or carriage regulations yet we have no real idea about any of this actually happening.
Old December 18th 15, 08:08 PM posted to rec.aviation.soaring
Darryl Ramm
OK and one more... since I see this come up occasionally. The 2020 Carriage ADS-B Out regulations that require a TT-22 (if you wanted to do any install in a certified glider or a complaint install in an experimental glider) and not a (lower power) TT-21 are completely separate from the old needing a higher power (Class 1) transponder over 15,000' regulation. The TT-21 unfortunately does not meet the ADS-B Out power requirements in the USA (a unique issue to the USA because of the reliance on widely space ADS-B ground stations), even below 15,000'.
Bottom line if buying a transponder today in the USA, just get the Trig TT-22. A fine piece of kit. If you don't need a new transponder today (like you have a working Mode C transponder already, just WAIT... and see what happens with FAA regulations and new products entering the market).
Old December 19th 15, 01:08 AM posted to rec.aviation.soaring
son_of_flubber
I've no personal knowledge of the following kickstarter. It could be totally legit, self-delusional vaporware, or a deliberate money-extraction-scheme. It promises some subset of ADS functionality at a very low price point and may therefore be of interest.
https://www.kickstarter.com/projects...tegory_popular
I'd guess that you'd want to use it with an Iphone in a glider not an Ipad Mini.
Old December 19th 15, 01:26 AM posted to rec.aviation.soaring
Darryl Ramm
The ADS-B receiver is really not the issue...
Old December 19th 15, 09:56 PM posted to rec.aviation.soaring
Darryl Ramm
And just becasue I can't resist... this is a UAT only receiver. It won't see 1909ES Out equipped aircraft directly. If your aircraft is equiiped with the correct/compliant ADS-B Out and it is correctly fofigured to dvertise you have this receiver and you are in range of the FAA ground infrastrucure then you should recive ADS-R services that allow this receiver to see 1090ES Out equipped aircraft. The exact same applies to TABS (since it is a version of 1090ES and does not transmit on UAT frequencies) should TABS be adopted in regulation in the USA and in particular for gliders.
Bottom line on this is there are excellent low cost and well proven portable general aviation ADS-B receivers from Stratus and Garmin (GDL-39 series). All these products are dual-band, i.e. driectly recve ADS-B from 1090ES Out and UAT Out equipped aircraft, do not rely on ADS-R at all, will recive both out side FAA ground station range, and imprtnatly will receive both revgarless of wether your own aidcraft has ADS-B Out or not. This Bad-Elf product just sucks, there is no excust for a USA manufatuer to be developigng an ADS-N revciver today that is not dual-band/link layer. It makes no sense, and with any silgle link layer receiver the reuqirmnts to fully paricate int he ADS-B srvicesd are likely too confusing/diffiuclt for the market/many owners/piots to undertsand and configure correctly (anybody want to tell me how they can change the capavility code bits cnfiuguration on their ADS-B Out system when they mount this reciver in their aircraft?... ah no I thought not.
And in glider land in the USA, we have for better or worse, and I think for the *much* better significant PowerFLARM adoption.
PowerFLARM does receive 1090ES directly but not UAT and is not compatible with ADS-R . In an ideal world PowerFLARM would be also be a dual-link receiver, but it's ancestry is from Europe and I suspec tthe complexity of baking a cusotm system just for the USA glider market means that would never happen.
Did somebody recently suggest not over worrying about all this stuff and just waiting and seeing what happens? Ah yes I did :-)
  #29
Old December 19th 15, 11:56 PM posted to rec.aviation.soaring
Darryl Ramm
(repost with more details, sorry the earlier one escaped)
And just becasue I can't resist a good rant and chance to kick a bad idea.... This BadElf ADS-B is a UAT In only receiver. It cannot directly "see" 1009ES Out (or TABS equipped... if TABS takes off in the USA) equipped aircraft.
OK sure, if your aircraft is equipped with this BadElf receiver and also the correct/compliant ADS-B Out that is correctly configured to advertise you have a UAT receiver and you are in range of the FAA ground infrastructure then you should receive ADS-R services that allow this receiver to "see" 1090ES Out equipped aircraft. Oh wonderful stuff (he cries sarcastically...).
But to give them credit it has pretty good naming, as this BadElf product is indeed a bad idea, just fundamentally flawed. And Stupid Elf might be an even better name. There is no excuse for a USA based manufacturer to be developing an ADS-B receiver today that is not dual-band/link layer. It just makes no sense. And with any single link layer receiver the requirements to fully participate in the ADS-B services are likely too confusing/difficult for the market/many owners/pilots to undertsand and configure correctly (anybody want to tell me how they can change the capability code bits in their ADS-B Out system so it transmits the right magic so the FAA ground infrastructure knows you have a UAT receiver so it will provide ADS-R services to your aircraft?... ah no I thought not).
I hope, for saftey reasons, that this BadElf product just will not get crowd funded/will not sell well. If it does that may reflect more market confusion than them having a great product. Why would anybody buy it when there are better, and already relatively low-cost dual-link receivers already available from much larger/proven manufacturers. Including Apparero Stratus 2S (https://www.appareo.com/aviation/ads-b/stratus) and Garmin GDL-39 series (https://buy.garmin.com/en-US/US/in-t...rod93601.html). The GDL-39 starts at less than $600. Those products directly receive ADS-B from 1090ES Out *and* UAT Out equipped aircraft, without relying on ADS-R at all. They will work outside FAA ground station range, and importantly will work regardless of whether your own aircraft has ADS-B Out installed or not. (The Status 1S is UAT In only, the 2S I mentioned is a dual link-layer receiver).
And in gliders in the USA we have significant PowerFLARM adoption. PowerFLARM as deployed in the USA, where it has the 1090ES In option included, does receive 1090ES directly but not UAT. And PowerFLARM has a limitation that it is not compatible with ADS-R or TIS-B--so whether you have ADS-B Out in your glider or not does not change what your PowerFLARM shows you. If you have 1090ES Out other PowerFLARM can see your 1090ES Out signal, and hopefully at significant longer ranges than typical PowerFLARM to PowerFLARM. In an ideal world PowerFLARM's ADS-B In capability would also be dual-link, but it's a specialized device mostly for the glider market and its ancestry is from Europe, and UAT, ADS-R and TIS-B are USA only silliness. I suspect the complexity of building a custom system just for the USA glider market means that just will never happen. So there is a trade off of putting good enough ahead of perfect. At least PowerFLARM has PCAS support that helps warn of transponder equipped aircraft (if they are being interrogated etc.).. which will help with UAT Out equipped aircraft which also have transponders (most/nearly all will). And anyhow I'm suspecting there will be more 1090ES Out adoption than UAT Out across the whole USA aircraft fleet as we approach 2020, and if TABS is adopted for gliders and maybe other aircraft then that is even more 1090ES Out... which all works great for those with PowerFLARM. And hopefully glider owners/pilots/FBOs/Clubs etc. have enough sense by now to know that UAT Out only devices are not good choices for equipping gliders with, or other aircraft with, that mix frequently with gliders.
There is no way of just connecting/combining say a PowerFLARM and separate UAT or dual-link ADS-B receiver. That would take significant custom software development, for a likely market of a small number of glider owners/pilots in the USA who care enough to want both FLARM and dual-band ADS-B In capability. And just having two separate systems in the cockpit is likely far too much confusion/distraction, especially trying to think about/manually deduplicate threats showing up on both systems.
Did somebody recently suggest not over worrying about all this stuff and just waiting and seeing what happens? Including with possible TABS installation and use regulations and adoption in the USA? Ah yes I did, several times now :-)
  #30
Old December 20th 15, 04:12 AM posted to rec.aviation.soaring
Bill T
You no longer need to trigger ground stations to get TIS-B or FIS-B data on the UAT frequency.
I have a Raspberry Pi set up to receive UAT TIS-B and FIS-B data. Get great data with no "trigger".
BillT
Mods to glider = experimental? Bret Soaring 3 June 16th 10 09:29 PM
New Trig TT22 Transponder Paul Remde Soaring 1 January 14th 10 07:27 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Licensing new Experimental glider in USA John Bojack[_2_] Soaring 5 January 2nd 09 01:54 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
