Metric aircraft countersunk machine screws
Old February 7th 18, 04:56 PM posted to rec.aviation.soaring
Default Metric aircraft countersunk machine screws
On Wednesday, February 7, 2018 at 10:50:55 AM UTC-5, Soartech wrote:
On Tuesday, February 6, 2018 at 12:49:20 PM UTC-5, Bob Kuykendall wrote:
On Sunday, February 4, 2018 at 4:05:21 AM UTC-8, wrote:
'Aircraft Spruce and Specialty' has metric aircraft hardware
Link?
http://www.aircraftspruce.com/menus/...inescrews.html
See any metric screws there? Looks like AN/MS part numbers to me.
UH
Old February 7th 18, 07:07 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Link?
UH
McMaster Carr
https://www.mcmaster.com/#machine-screws/=1bgwklj
Stainless 100 degree countersink
Richard
www.craggyaero.com
Old February 7th 18, 07:09 PM posted to rec.aviation.soaring
Link?
UH
McMaster Carr
Richard
www.craggyaero.com
https://www.mcmaster.com/#machine-screws/=1bgwlmh
Steel 100 deg countersink
Richard
www.craggyaero.com
Old February 7th 18, 07:14 PM posted to rec.aviation.soaring
Bob Kuykendall
Yup, those are machine screws. Didn't see any metric ones, though I didn't check them all.
--Bob K.
Old February 7th 18, 08:02 PM posted to rec.aviation.soaring
--Bob K.
Mil Spec screw on McMaster Carr are metric and have the 100 deg countersink.
Richard
www.craggyaero.com
Old February 8th 18, 01:44 AM posted to rec.aviation.soaring
On Saturday, February 3, 2018 at 3:51:27 PM UTC-5, Charles Longley wrote:
Does anyone have a source for metric aircraft countersunk machine screws? Similar to MS24693S28. They need to be aircraft hardware store screws have the wrong taper on them. This is for Blanik L-23 & L-33’s.
I went through this a couple months ago. As noted above, metric countersunk screws have a 90 deg countersink, and of course there are different kinds of heads like flat or oval. I wasn't able to find a single supplier that had everything I needed, so ended up ordering some from Mr Metric (aka Mountz) and others from Bel-Metric. Needless to say I bought a few extra of each size!
Good luck,
Brian
Old February 8th 18, 06:19 PM posted to rec.aviation.soaring
Good luck,
Brian
Brian
Mil Spec screw on McMaster Carr are metric and have the 100 deg countersink..
Richard
www.craggyaero.com
Old February 9th 18, 01:07 AM posted to rec.aviation.soaring
Charles Longley
I looked at the McMaster screws and they’re the wrong head size for Blanik’s.
  #29
Old February 9th 18, 01:22 AM posted to rec.aviation.soaring
AS
--Bob K.
Richard
www.craggyaero.com
Richard - can you post a McMaster Carr p/n for a 'metric MIL-spec' countersunk Philips head screw? I can only find imperial sized ones under MIL-spec. Maybe I am not looking in the right place.
Thanks
Uli
'AS'
  #30
Old February 9th 18, 05:35 AM posted to rec.aviation.soaring
2G
On Saturday, February 3, 2018 at 8:21:17 PM UTC-8, Charles Longley wrote:
The head diameter on that screw is too big. I need a 4 mm screw with a head diameter around 6.5 mm. I am not sure what the countersink angle is. Looks closer to 100 though.
That head diameter is totally unrealistic; it should be about twice the shaft diameter. Grind the head down if you want it less, but you will have a very small shoulder as a result.
Tom
Fairey Long-range Monoplane pics 2 [4/9] - Like the first machine, it is fitted with a Napier Lion engine. Refinements have been added to this second machine, such as the spats over the undercarriage wheels.jpg (1/1) Miloch Aviation Photos 0 January 6th 18 04:31 PM
Blanik screws? Wade G Soaring 10 March 28th 16 03:03 AM
Metric Aircraft Hardware [email protected] Soaring 2 November 27th 07 06:23 AM
FAA Screws Up Again BushOKDemocratsSTUPID Instrument Flight Rules 2 March 22nd 06 10:39 PM
Metric Aircraft Nuts and Bolts John Scott Soaring 6 December 14th 05 08:54 PM
