#21
Andrew Gideon wrote:
Newps wrote: As to your question you would handle it like any opther lost comm, that's why you were cleared to a point, that's the point you will go to and then pick an approach and land, and because there's no filed clearance you go right to the VOR and then directly to whatever approach you want. Perhaps I misunderstood, but I thought the VOR not near the destination airport. If a clearance is to an airport, I understand the "pick an approach" ...um... approach. But it's when the clearance limit is to a waypoint that's not an airport (ie. some VOR somewhere) that leaves me puzzled. Recall that there's no specification within "the system" as to the final destination in that case. Well, you shouldn't accept a clearance limit without an EFC. And you have your flight plan, so you fly to the clearance limit, hold until your EFC and then proceed per your flight plan and fly an approach. At least that is what I'd do. Matt |
![]() "Matt Whiting" wrote in message ... Well, you shouldn't accept a clearance limit without an EFC. And you have your flight plan, so you fly to the clearance limit, hold until your EFC and then proceed per your flight plan and fly an approach. At least that is what I'd do. Every IFR clearance has a clearance limit, an EFC is issued only if holding is anticipated. |
Steven P. McNicoll wrote:
"Matt Whiting" wrote in message ... Well, you shouldn't accept a clearance limit without an EFC. And you have your flight plan, so you fly to the clearance limit, hold until your EFC and then proceed per your flight plan and fly an approach. At least that is what I'd do. Every IFR clearance has a clearance limit, an EFC is issued only if holding is anticipated. Yes, but typically the clearance limit is an airport. :-) Matt |
![]() "Matt Whiting" wrote in message ... Yes, but typically the clearance limit is an airport. :-) Yes, but clearances with non-airport clearance limits do not include an EFC unless holding is anticipated. |
Canada makes the same distinction.
All the best, David |
"Matt Whiting" wrote in message ... Yes, but typically the clearance limit is an airport. :-) Yes, but clearances with non-airport clearance limits do not include an EFC unless holding is anticipated. OK, but I was taught to always ask for an EFC if given a clearance limit that wasn't an airport. Matt |
![]() "Matt Whiting" wrote in message ... OK, but I was taught to always ask for an EFC if given a clearance limit that wasn't an airport. Did your teacher say why? |
Peter wrote:
As a related question, does the USA permit a plain PPL holder (no IR) to fly above an overcast layer? yes. (might or might not be a good idea, depending on your point of view; there are a few other things that are legal and might not be a good idea either, but I really like making my decisions for myself) --Sylvain |
#29
Peter wrote:
"Steven P. McNicoll" wrote OK, but I was taught to always ask for an EFC if given a clearance limit that wasn't an airport. Did your teacher say why? As a related question, does the USA permit a plain PPL holder (no IR) to fly above an overcast layer? Yes. Matt |
#30
![]() "Peter" wrote in message ... As a related question, does the USA permit a plain PPL holder (no IR) to fly above an overcast layer? Yes. |
Hurricane relief | Gary Drescher | Owning | 67 | September 13th 05 06:09 AM |
Hurricane relief | Gary Drescher | Piloting | 66 | September 13th 05 06:09 AM |
Tent Buying Guide (long, print it out) | john smith | Piloting | 24 | August 5th 05 06:12 PM |
Czech body recommends gvt choose Gripen fighter | Karl | Military Aviation | 0 | December 1st 03 08:36 PM |
Bush's Trip: 747 or C-17 Which would you Choose? | Leadfoot | Military Aviation | 38 | November 30th 03 04:03 PM |
