Subject line says it all. In light of the fact that VFR on top subjects
you to both VFR and IFR constraints, why would anyone ever choose to fly VFR on top? I can only think of two possible reasons: 1. There happens to be clear air at a +500 foot altitude and not at the corresponding even-thousand altitude (though how would know that without popping up 500 feet to have a look is still a mystery). 2. You can get a more direct routing because of the less restrictive separation requirements. Have I missed a possible reason? rg |
Ron Garret wrote: Subject line says it all. In light of the fact that VFR on top subjects you to both VFR and IFR constraints, why would anyone ever choose to fly VFR on top? I can only think of two possible reasons: You can fly IFR thought the clouds, come out on top in clear skies, cancel IFR and then fly VFR (VFR over the top). Or you can fly IFR through the clouds and remain 'in the system' as you fly VFR (VFR on top) and if there are more clouds ahead or at your final airport you don't have to call ATC again. |
Example: I know (or strongly suspect) that the tops at at 6000. I call
Ground and tell them that I want an IFR clearance to VFR-on-top. No flight plan filed. Ground says "Whizbang 1234X is cleared to (nearby VOR), climb and maintain 7000, if not on top at 7000 advise. Squawk 3456." Great time saver. Example: I am in Spokane, or somewhere else where it is severe clear and I want to go to Seattle or somewhere that I know is VFR. I file an IFR flight plan with VOT in the altitude block. I am cleared to operate VOT and cleared for takeoff. Because I am on an IFR flight plan, I make all required reports and stay in communication with Center until I can see over the tops of the mountains that there is nothing on the other side but white puffy stuff. I say "Center, Whizbang 3456 requests a hard altitude." Center gives me an IFR altitude. Voila....I am back to "normal" IFR for the rest of the trip. I used to carry packages from SEA to OAK and back in the middle of the night and used VOT more often than not. Bob Gardner "Ron Garret" wrote in message ... Subject line says it all. In light of the fact that VFR on top subjects you to both VFR and IFR constraints, why would anyone ever choose to fly VFR on top? I can only think of two possible reasons: 1. There happens to be clear air at a +500 foot altitude and not at the corresponding even-thousand altitude (though how would know that without popping up 500 feet to have a look is still a mystery). 2. You can get a more direct routing because of the less restrictive separation requirements. Have I missed a possible reason? rg |
Ok, I understand the first example - you just want to go through the
cloud deck, no flight plan, no hassle, as you said - great time saver. What is the good part about the second way? I mean - how is it really different from flying it at a hard altitude? You still had to file the flight plan, you still have to file the assigned route. The only benefit I see is being able to change altitudes at your discretion. Is this what you're after or am I missing something else? Bob Gardner wrote: Example: I know (or strongly suspect) that the tops at at 6000. I call Ground and tell them that I want an IFR clearance to VFR-on-top. No flight plan filed. Ground says "Whizbang 1234X is cleared to (nearby VOR), climb and maintain 7000, if not on top at 7000 advise. Squawk 3456." Great time saver. Example: I am in Spokane, or somewhere else where it is severe clear and I want to go to Seattle or somewhere that I know is VFR. I file an IFR flight plan with VOT in the altitude block. I am cleared to operate VOT and cleared for takeoff. Because I am on an IFR flight plan, I make all required reports and stay in communication with Center until I can see over the tops of the mountains that there is nothing on the other side but white puffy stuff. I say "Center, Whizbang 3456 requests a hard altitude." Center gives me an IFR altitude. Voila....I am back to "normal" IFR for the rest of the trip. I used to carry packages from SEA to OAK and back in the middle of the night and used VOT more often than not. Bob Gardner |
![]() "Bob Gardner" wrote in message ... Example: I know (or strongly suspect) that the tops at at 6000. I call Ground and tell them that I want an IFR clearance to VFR-on-top. No flight plan filed. Ground says "Whizbang 1234X is cleared to (nearby VOR), climb and maintain 7000, if not on top at 7000 advise. Squawk 3456." Great time saver. Great time saver compared to what? What are you going to do when you reach VFR conditions? Example: I am in Spokane, or somewhere else where it is severe clear and I want to go to Seattle or somewhere that I know is VFR. I file an IFR flight plan with VOT in the altitude block. Put OTP in the altitude block. VOT is "VOR test signal" or "vorticity". |
Bob Gardner wrote:
Example: I know (or strongly suspect) that the tops at at 6000. I call Ground and tell them that I want an IFR clearance to VFR-on-top. No flight plan filed. Ground says "Whizbang 1234X is cleared to (nearby VOR), climb and maintain 7000, if not on top at 7000 advise. Squawk 3456." Great time saver. What happens if there's a comm failure and you're wrong about the tops? Of course, this is a general question about any clearance limit that's not an airport or certainly VFR. - Andrew |
![]() Andrew Gideon wrote: Bob Gardner wrote: Example: I know (or strongly suspect) that the tops at at 6000. I call Ground and tell them that I want an IFR clearance to VFR-on-top. No flight plan filed. Ground says "Whizbang 1234X is cleared to (nearby VOR), climb and maintain 7000, if not on top at 7000 advise. Squawk 3456." Great time saver. What happens if there's a comm failure and you're wrong about the tops? Of course, this is a general question about any clearance limit that's not an airport or certainly VFR. First off he doesn't want VFR on top but rather an IFR climb to VFR. VFR on Top is an IFR clearance. As to your question you would handle it like any opther lost comm, that's why you were cleared to a point, that's the point you will go to and then pick an approach and land, and because there's no filed clearance you go right to the VOR and then directly to whatever approach you want. |
Newps wrote:
AsÂ*toÂ*yourÂ*questionÂ*youÂ*wouldÂ*handleÂ*it like any opther lost comm, that's why you were cleared to a point, that's the point you will go to and then pick an approach and land, and because there's no filed clearance you go right to the VOR and then directly to whatever approach you want. Perhaps I misunderstood, but I thought the VOR not near the destination airport. If a clearance is to an airport, I understand the "pick an approach" ...um... approach. But it's when the clearance limit is to a waypoint that's not an airport (ie. some VOR somewhere) that leaves me puzzled. Recall that there's no specification within "the system" as to the final destination in that case. Obviously, the first/best course is to maintain VFR. But if the VOR (at the assigned altitude) is not VMC (despite the expectation/hope that led to the request), then what? - Andrew |
![]() Andrew Gideon wrote: Newps wrote: As to your question you would handle it like any opther lost comm, that's why you were cleared to a point, that's the point you will go to and then pick an approach and land, and because there's no filed clearance you go right to the VOR and then directly to whatever approach you want. Perhaps I misunderstood, but I thought the VOR not near the destination airport. In his particular example the VOR is very close, certainly in approach controls airspace. If a clearance is to an airport, I understand the "pick an approach" ...um... approach. But it's when the clearance limit is to a waypoint that's not an airport (ie. some VOR somewhere) that leaves me puzzled. Recall that there's no specification within "the system" as to the final destination in that case. Obviously, the first/best course is to maintain VFR. But if the VOR (at the assigned altitude) is not VMC (despite the expectation/hope that led to the request), then what? Pick an approach and land. And do it now, we are holding up everybody else while you figure out what to do. |
Hurricane relief | Gary Drescher | Owning | 67 | September 13th 05 06:09 AM |
Hurricane relief | Gary Drescher | Piloting | 66 | September 13th 05 06:09 AM |
Tent Buying Guide (long, print it out) | john smith | Piloting | 24 | August 5th 05 06:12 PM |
Czech body recommends gvt choose Gripen fighter | Karl | Military Aviation | 0 | December 1st 03 08:36 PM |
Bush's Trip: 747 or C-17 Which would you Choose? | Leadfoot | Military Aviation | 38 | November 30th 03 04:03 PM |
