#21
![]() Mxsmanic wrote: Dylan Smith writes: Funnily enough, a sturdy metal beam across the fuselage (usually two - one at the front, where the main spar attaches, and one at the rear). Windows can still be put in the roof. For a light aircraft 'sturdy' doesn't mean 'massive'. It sure is hard to see anything in photos. Are high-wing designs stronger, weaker, or about the same as low-wing designs? Do they have cost or safety advantages/disadvantages? *** On a strut-braced high wing airplane, the wing, the strut, and the fuselage form a triangle, which is inherently a strong shape. With a low-wing airplane, the same loads have to be borne by a spar inside the wing. The lift is trying to bend the spar. Another advantage of high-wing airplanes is that they require less dihedral, because the fuselage center of gravity is below the wing. OTOH, the struts are draggy. Don't know if they're more or less draggy than the thick wing root that you have to have without them. - Jerry Kaidor |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Control Reversal in WWII | Eunometic | Military Aviation | 14 | June 27th 04 01:03 PM |
Avoiding Vne | K.P. Termaat | Soaring | 120 | April 7th 04 07:56 PM |
Discus CS grounded in France | Marc Till | Soaring | 47 | September 20th 03 10:09 AM |
