Requesting a hold from ATC for descents
Old January 2nd 07, 04:52 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Requesting a hold from ATC for descents
If it becomes impossible to respect your descent schedule, is it
permissible to ask ATC to give you a hold temporarily so that you can
descend in the hold pattern until you're back to your planned descent?
If so, is this a fairly common procedure, or very unusual? I'm
thinking with respect to large commercial jets in particular (or
potentially any jet, since they usually seem to be fast and slippery).
Old January 2nd 07, 05:22 PM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Tuesday, January 02, 2007 10:53 AM
Posted To: rec.aviation.ifr
Conversation: Requesting a hold from ATC for descents
Subject: Requesting a hold from ATC for descents
They also employ spoilers and can typically come down very quickly. Give
a more precise example of "becomes impossible to respect your descent
schedule" please.
Old January 2nd 07, 09:30 PM posted to rec.aviation.ifr
Mxsmanic
Jim Carter writes:
schedule" please.
I've tried spoilers and they don't always help enough.
I'm talking about the FMS disconnecting with a message like "ALT
UNACHIEVABLE" or something like that, when the deviation from the
expected descent profile gets too large.
Old January 2nd 07, 07:00 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Never happens. Like the other gentleman says, the spoilers (actually
speed brakes when used in flight) are the "ace in the hole."
Old January 2nd 07, 07:26 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Scott Skylane
Sam,
Never say never I have asked for, and received a turn in the hold to
lose altitude, after arriving at the final fix about 10,000 feet high.
This was due to descent restrictions from center because of other
approaches in progress. The flight spoilers on a 727 are *very*
effective, but they can't perform miracles!
Happy Flying!
Scott Skylane
Old January 2nd 07, 08:15 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Sam,
Happy Flying!
Scott Skylane
Your mileage may vary. ;-)
I've got almost 8,000 hours in the 727 and never, ever did an approach
hold or procedure turn. Delay vectors, yes.
Old January 2nd 07, 08:55 PM posted to rec.aviation.ifr
Jim Carter[_1_]
Posted At: Tuesday, January 02, 2007 2:15 PM
And then there was the time several years ago an American 727 into TUL
was hot, high, and straight-in -- but he wasn't going to sequence behind
my lowly Cherokee 6. He ended up going around after blowing across the
boundary well above Vref and ended up landing #2 behind the Bonanza that
followed me in. I wonder what that little excursion cost?
Of course I still love to hear the tower tell a pilot "left or right
turn at the end if able".
Old January 2nd 07, 08:23 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
You also must also factor in pilot incompetence. I can't begin to tell
you how many times these jet pilots, almost always from the majors like
NWA and UAL as well as from the regionals like Skywest, report on the
freq 35 miles out at FL230 or higher. This is not centers fault as the
descent clearance was given about 200 miles out. Center usually gives a
PD descent and these guys continually foul it up. So to illuminate your
mistake I will drive you right at the airport and make you beg for mercy.
Old January 2nd 07, 08:56 PM posted to rec.aviation.ifr
Jim Carter[_1_]
Posted At: Tuesday, January 02, 2007 2:24 PM
tell
like
a
your
mercy.
I seem to remember a "keep-em-high" program years ago that kept everyone
as high as possible for as long as possible to preserve fuel and reduce
noice. Could that policy still be in effect for some carriers?
Old January 2nd 07, 09:32 PM posted to rec.aviation.ifr
Mxsmanic
Jim Carter writes:
I was thinking the same thing. They may have company policies that
require them to stay as high as possible for as long as possible to
save fuel (noise abatement probably isn't as much of an issue, but it
might still be a factor).
Requesting a hold from ATC for descents Mxsmanic Piloting 10 January 3rd 07 02:31 AM
Different categories of ILS hold short lines at large airports Peter R. Piloting 3 March 6th 06 08:08 PM
IFR hold short line at uncontrolled airports? Peter R. Instrument Flight Rules 30 June 9th 04 04:47 AM
S-TEC 60-2 requires re-trim after altitude hold? Peter R. Owning 7 March 2nd 04 03:46 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
