Bad timing...
Old March 9th 07, 07:13 PM posted to rec.aviation.piloting,rec.aviation.owning
David Lesher
Default Bad timing...
"Jay Honeck" writes:
Anyone know if it's possible for a brake to hang up and not release,
resulting in advanced wear like this? Or should I keep blaming Mary
for riding the (right) brake?
Yes. In cars, this is often caused by the caliper rusting.
That's caused by a) road salt b) water in the brake fluid.
Hence the recommendation to flush the fluid every 2 years.
I've read both the 'rotor runout' and seal material explanations
for retraction; I suspect there's some of each. In any case, with
no pressure/drag - i.e pads skipping along; there's very little if
any braking action.
The constricted hose IS a known problem if a rare one. I think
newer hoses/neopreme may have solved the issue.
Do NOT overlook master cylinder/pedal issues. One of those
old batttries wedged under the pedal and.......
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old March 9th 07, 07:41 PM posted to rec.aviation.piloting
Draw a straight line from KIOW to T82 and it crosses right over the
Lake Texoma area, so Durant would be much closer stop. Ponca City
would be further off the path.
I'd still opt for Cedar Mills (3T0) on the Texas side myself, just for
the scenery and experience of the approach to and takeoff from the
lake-end of the runway. Cheap fuel (plus a courtesy car and good BBQ)
is also available at Gainesville, TX (KGLE) just a few miles west of
the lake, and also cheap fuel at Sherman (KSWI) just a few miles
southeast of the lake.
Old March 9th 07, 07:54 PM posted to rec.aviation.piloting
Steve Foley
I use to BBQ in my back yard, until I went to Chucks.
Now I just cook out.
Old March 10th 07, 02:47 AM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck
No no no...it's "Hail Mary", not "Blame Mary". :-)
Now Jack here is obviously a successfully married man...
Well, the parts arrived from Spruce by 10 AM this morning, and the
brakes were fixed by lunch. Atlas is tucked safely back in his hangar,
fully fueled and ready to go.
All we need now is some nice weather on Sunday. It's 35 degrees and
raining, right now -- ain't nuthin' flying around Iowa City...
Prog charts show a big chunk of (argh!) thunderstorms moving into
Oklahoma and Texas on Sunday morning...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 10th 07, 04:28 AM posted to rec.aviation.piloting,rec.aviation.owning
Peter Dohm
Ouch...
This is one of those stories that makes me glad that I didn't spend
the extra money (and lost useful load) to install Toe-Brakes in 61J...
Yes it was odd... for the first 5 minutes of taxiing.
After seeing two of my old club's planes go through a set of pads per
100 hour inspection (one of them having a similar catastrophic right
(I believe) break failure... only during a landing... only a VERY good
instructor prevented a ground-loop). And then hear stories like this
from a very experienced pilot no-less...
I can't say I miss them.
I have had a right break failure in a piper with toe brakes also right
brake
stuck upon applying them.
This makes me just a little curious.
Is the handbrake on a Piper (without toe brakes) mechanical or hydraulic?
My reason for asking is that, if hydraulic, the same culd happen with the
handbrake--although the possiblility of inadvertantly dragging the right
brake while applying rudder would be eliminated.
Peter
Old March 10th 07, 04:33 AM posted to rec.aviation.piloting,rec.aviation.owning
Peter Dohm
any braking action.
And a few cars, such as Corvettes in the middle 1960s, were reputed to have
springs inside the calipers so that the pads would not retract. This was
supposed to keep the pads and disks cleaner and drier, with only a very
slight increase in the rate of wear.
I never owned one and don't know how well it worked.
Peter
(Anticipating the obvious question)
Old March 10th 07, 04:36 AM posted to rec.aviation.piloting,rec.aviation.owning
Yep, low ceilings, crappy visibility, possibly rain and thundershowers
from west of Wichita Falls all along the Red River all the way to Lake
Texoma forecast for most of the day Sunday. MVFR at best, probably
actually gonna be IMC though.
Might be a better idea to try again Monday. Or if you can, leave
Saturday morning. It's supposed to be very clear and almost no winds
all day Saturday across the local region here.
Old March 10th 07, 02:11 PM posted to rec.aviation.piloting,rec.aviation.owning
Jay Honeck
Yeah, we'll probably only make it half-way down Sunday anyway...so
flying in to Fredericksburg on Monday is no biggie.
Can't leave today, dang it. Got a million loose ends to tie before we
can leave the hotel for a week...
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #29
Old March 11th 07, 09:03 AM posted to rec.aviation.piloting,rec.aviation.owning
EridanMan
Yes its hydraulic (Single Cylinder)... so yes, it could definitely
still fail.
The whole system is much simpler (And lighter, by about 8 lbs) than
the toe-brake system though, and according to my mechanic at least,
its basically bullet-proof...
This is simply according to him - but apparently fried right wheels/
brakes are a reasonably common (especially on Grummans and training
aircraft)... he attributes it simply to the subconscious dragging on
takeoff/taxi... At the very least, the right pads wear faster than the
left on most planes he looks at, even with experienced pilots.
The only planes he doesn't see it on are the few that don't have toe
brakes. That was enough for me... (Disclaimer, I am a young, low-time
pilot with ABSOLUTELY no experience in this matter, other than I
learned in a few toe-brake planes before I bought 61J, and I adapted
to no toe-brakes in about 5 minutes...)
I do tend to trust the opinion of a mechanic who tells me not to give
him money for things though...
-Scott
  #30
Old March 12th 07, 12:07 PM posted to rec.aviation.piloting,rec.aviation.owning
Dylan Smith
I presume you're meaning on aircraft like the TriPacer which has the
hand brake, but no toe brakes.
In the TriPacer, a cable goes from the hand brake, around a few pulleys,
and ultimately it ends up under the pilot's seat. Under the pilot's seat
(and I'm not joking) you will find a Piper Cub heel brake, with a hole
in the back of the heel brake, where the cable connects.
The heel brake is hydraulic and applies both wheel brakes
simultaneously. The diaphragm has a habit of splitting just when you
really need the brakes, leaving you with nothing!
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
timing holds [email protected] Instrument Flight Rules 16 February 17th 05 12:18 AM
Approach Timing john smith Instrument Flight Rules 36 September 9th 04 03:37 PM
Timing light for electronic ignition Ron Home Built 4 August 20th 04 05:18 PM
internal timing of slick magneto Jerry Jensen Home Built 1 June 25th 04 07:59 PM
Timing on Subaru EJ22 ??? Randy Rotorcraft 1 November 9th 03 06:15 AM
