Unclear Clearance
Old April 13th 07, 06:57 PM posted to rec.aviation.ifr
Mark Hansen
Default Unclear Clearance
On 04/13/07 10:35, Ron Natalie wrote:
Mark Hansen wrote:
I don't think that's true. The FARs say that clearance must include the
words "Cleared to...".
Really, what FAR would that be? The FARs aren't much on phraseology.
That's a good question. During my IR training, I was taught that a
clearance must contain a certain set of items, one of which was
the "Cleared To...".
However, in looking at the FARs now, I don't see anything like that.
Even the AIM says that a clearance "may contain" the item(s). I don't
even see where the 7110.65 states that the clearance must contain these
items - it just says "issue the following items as appropriate...".
Hmmm, back to the books ;-\
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old April 14th 07, 02:31 PM posted to rec.aviation.ifr
Roy Smith
"Guillermo" wrote:
I had another situation where it was a little more unclear, when
departing from an uncontrolled field, IFR plan on file:
70V: "jax center, Cessna 70V at xxxx, would like to pick up IFR
clearance to FTY"
JAX:"70V, squawk 1234, climb to 5000, I'll have the rest of your
clearance in a few minutes"
5000 feet would put me in the clouds, and having not heard the words
"cleared to", I wasn't sure if I was considered to be flying IFR at
this point, so I told the controller that 5000 would put me in the
clouds, and he responded to go ahead, that I was already IFR.
Technically, this is a bum clearance, since you didn't have a clearance
limit. On the other hand, once you clarified your IFR status with the
controller, everybody is on the same page, even if the right magic words
weren't spoken. I'm not sure how you were supposed to navigate, but I
guess I would just continue on my present heading.
Whenever I'm not 100% I understand a clearance, I just read it back the way
I'm planning on executing it; this gives the controller a chance to correct
any errors (and gets it on the tape). In your case, I would have read back
something like, "70V is IFR at this time, 3500 climbing 5000, XXX heading".
Old April 14th 07, 05:45 PM posted to rec.aviation.ifr
Mark Hansen
clearance to FTY"
limit.
To help clarify an issue I tripped over the other day, can you please let
me know where it states that a clearance must include a clearance limit?
I've looked in the FARs, the AIM and th 7110.65 and can't find anything
which says a valid clearance must include this (some say it *may* include
it, but none say it *must*).
Sacramento, CA
Old April 14th 07, 06:30 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Mark Hansen" wrote in message
SeeFAA Order 7110.65 paragraphs 4-2-1 and 4-3-2.
http://www.faa.gov/airports_airtraff.../media/ATC.pdf
Old April 14th 07, 06:38 PM posted to rec.aviation.ifr
Andrew Sarangan
clearance to FTY"
limit.
It is in AIM 4-4-3. But you are correct that it says "clearances
normally contain the following". However, how can you consider this a
valid clearance if you don't know where you are cleared to?
Old April 14th 07, 10:00 PM posted to rec.aviation.ifr
Mark Hansen
clearance to FTY"
limit.
The point is that there is no "rule" which states that for it to be valid,
it must.
Sacramento, CA
Unclear Clearance Mitty Instrument Flight Rules 53 December 24th 05 02:36 AM
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Taxi Clearance Ron Rosenfeld Instrument Flight Rules 27 September 29th 05 01:57 PM
Clearance with an Odd Intersection Marco Leon Instrument Flight Rules 92 March 11th 05 03:16 PM
GPS clearance puzzle Roy Smith Instrument Flight Rules 26 December 9th 04 12:22 AM
