#21
Robert M. Gary wrote:
So you've never taken off IFR from an airport that didn't have class D (or E) to the surface??? Or landed. |
![]() "Ron Natalie" wrote in message m... : Robert M. Gary wrote: : : : So you've never taken off IFR from an airport that didn't have class D : (or E) to the surface??? : : : Or landed. : Yes, but I had a clearance. Granted the clearance was to be at a fix by a specific time when taking off, and the airport had an approach with weather above minimums. I need to see more examples... |
On Apr 16, 4:32 pm, "Blueskies" wrote:
"Ron Natalie" wrote in ting.com... : Robert M. Gary wrote: : : : So you've never taken off IFR from an airport that didn't have class D : (or E) to the surface??? : : : Or landed. : Yes, but I had a clearance. You definitely did not have a clearance for the class G portion of your flight. |
I need to see more examples... Then look up (just off the top of my head) Eureka, NV (05U) on skyvector. Suppose you want to get from there to, well, anywhere under IFR. You have no choice but enroute IFR in class G. The entire country was once like Eureka, NV. |
"Ron Natalie" wrote in ting.com... : Robert M. Gary wrote: : : : So you've never taken off IFR from an airport that didn't have class D : (or E) to the surface??? : : : Or landed. : Yes, but I had a clearance. Granted the clearance was to be at a fix by a specific time when taking off, and the airport had an approach with weather above minimums. ATC can't issue an IFR clearance for airspace that they don't control (class G). There would be no point. -Robert |
So even though you're flying an appropriate altitude for the course
flown, theres no guarantee that when climbing/descending you won't hit someone else doing the same? On Apr 16, 9:33 pm, "Robert M. Gary" wrote: On Apr 16, 4:32 pm, "Blueskies" wrote: "Ron Natalie" wrote in ting.com... : Robert M. Gary wrote: : : : So you've never taken off IFR from an airport that didn't have class D : (or E) to the surface??? : : : Or landed. : Yes, but I had a clearance. Granted the clearance was to be at a fix by a specific time when taking off, and the airport had an approach with weather above minimums. ATC can't issue an IFR clearance for airspace that they don't control (class G). There would be no point. -Robert |
kevmor wrote:
So even though you're flying an appropriate altitude for the course flown, theres no guarantee that when climbing/descending you won't hit someone else doing the same? Yep, big sky. There actually has been an FAA enforcment action that says that climb/descend in uncontrolled airspace without a clearance for obtained for the part in controlled airspace is reckless and dangerous. Essentially they figure that while ATC is not excercising control in the uncontrolled area, the idea that the "one at a time" rule in the transition area would protect you. |
Wichita Airspace Question and overlapping airspace | Owen[_4_] | Piloting | 1 | February 14th 07 09:35 PM |
OLC and airspace | 5Z | Soaring | 6 | July 30th 05 03:25 AM |
Two airspace classes for one airspace? (KOQU) | John R | Piloting | 8 | June 30th 04 04:46 AM |
GPS and airspace | Marty from Sunny Florida | Owning | 5 | June 29th 04 02:08 PM |
Do I own my airspace? | Chief McGee | Rotorcraft | 17 | March 16th 04 01:36 AM |
