#21
Dave S wrote:
cavelamb himself wrote: I don't recall it here. How about share if you can find it. IIRC, AN bolts are grade 5 types to allow them to bend before braking. I will look.. but the gist of it is.. a grade 5 will still fail completely before the grade 8 starts to get strained... brittle versus bending is besides the point in that regard. And if that overstresses the attachment that is bolted together? A bent bolt is a sure sign of an overstress. A super hard bolt that didn't bend may be worse that a bent bolt. Of course, it's an amateur built - with no official quality control. So you can use whatever you want. But me? I'll stick to known aircraft grade hardware. |
"cavelamb himself" wrote in message
... But me? I'll stick to known aircraft grade hardware. And - if that is not available? Will you choose not to continue with your project, sell it incomplete and start something else? BTW, when buying some certified AN bolts, I had to go through the bin and pick out good ones. Two out of three had crooked threads. This is not unusual. Rich S. |
Rich S. wrote:
"cavelamb himself" wrote in message ... But me? I'll stick to known aircraft grade hardware. And - if that is not available? Will you choose not to continue with your project, sell it incomplete and start something else? BTW, when buying some certified AN bolts, I had to go through the bin and pick out good ones. Two out of three had crooked threads. This is not unusual. Rich S. Not available? Or not cheap enough? |
On Jan 3, 2:45 pm, "Stuart & Kathryn Fields" wrote:
Recent quote for 16 of these bolts was about $20.00 each!! Anyone out there with a less expensive source? I'm no expert at this but what if you where to call and ask about buying a bulk amount? More than you need to get the price down. This way you may also be able to get the shipping down. There are not too many places that won't deal to sell more. Then list the extras on ebay or elsewhere. Lou |
Yes you are right about discounts for quantity buys but $15.00 ea for 100 is
not going to be acceptable to my budget. What this has done is to make me carefully review the application and learn a bunch more about threaded joints and the strength requirements. Stu "Lou" wrote in message ... On Jan 3, 2:45 pm, "Stuart & Kathryn Fields" wrote: Recent quote for 16 of these bolts was about $20.00 each!! Anyone out there with a less expensive source? I'm no expert at this but what if you where to call and ask about buying a bulk amount? More than you need to get the price down. This way you may also be able to get the shipping down. There are not too many places that won't deal to sell more. Then list the extras on ebay or elsewhere. Lou |
... Not available? Not available. This was true of several different fasteners and pieces of hardware on the Emeraude. My plans came out in 1954 and there were no direct aircraft hardware replacements or substitutions. None. Nada. Zip. And, in the case of the landing gear bolts, it would be financially impossible to scrap and redesign the wing spar for different hardware. So, like Stuart, I learned a lot about bolt strengths and selected ones that would be more than adequate for the job. If a person is hung up on "certified" aircraft parts, he/she should have a 172 or fly commercially. Oh wait, they have failures, too. Rich S. |
Rich S. wrote:
"cavelamb himself" wrote in message ... Not available? Not available. This was true of several different fasteners and pieces of hardware on the Emeraude. My plans came out in 1954 and there were no direct aircraft hardware replacements or substitutions. None. Nada. Zip. And, in the case of the landing gear bolts, it would be financially impossible to scrap and redesign the wing spar for different hardware. So, like Stuart, I learned a lot about bolt strengths and selected ones that would be more than adequate for the job. If a person is hung up on "certified" aircraft parts, he/she should have a 172 or fly commercially. Oh wait, they have failures, too. Rich S. So be it, Rich. It's you choice on your airplane. I'll stick to certified FASTENERS. And recommend the same to anyone who will listen. Richard |
But me? I'll stick to known aircraft grade hardware. Thats nice. I'm using AN whenever possible, and reasonable. It's not reasonable to pay $10 for a bolt that has a pedigree when a $1 bolt in a noncritical application (or 50 cent.. or what have you) will work acceptably. Thats just me. My Mazda rotary engine has this weird thread scheme called "metric". I have yet to find those with AN numbers. So I go and get an appropriate or least incompatible grade in metric when needed to interface with the engine in some manner. Its called experimental for a reason. My whole point was giving info. Someone was asking if grade 5 was better than Grade 8. Thats subjective. The chart gives the cold hard numbers. And if you read it.. again.. a grade 5 bolt will completely fail before an 8 even gets strained (those values are in tension, not shear). If you WANT the bolt to fail in a certain situation in your application thats your business. If you want it to hold, thats your call as well. Pick whats best for you. Dave |
#29
Dave S wrote:
If you WANT the bolt to fail in a certain situation in your application thats your business. If you want it to hold, thats your call as well. Pick whats best for you. Dave One last point and I'll let it go... The above is truly important decision point - but you left out HOW you want the bolt to fail. Add that, adn I have no problem with your approach. |
#30
This is a personal experience with AN fasteners. Here in the far
North, tailwheel bolts of the AN variety are very commonly broken when landing in conditions they were never meant to endure, i.e., off- airport boulder patches. Someone discovered that if you replace that AN bolt with a CAT bolt, voila, problem solved. Standard Caterpillar bolts are equivalent to grade 8 and they have VERY strong ones for special applications. They come in a variety of sizes, but not "all" sizes, so you may have to adjust things a bit to get the closest size available to fit your application. Check the price, you will be pleasantly surprised. Good luck. |
Needed 4 socket cap bolts | Udo | Soaring | 2 | November 29th 07 02:21 PM |
Torque for prop bolts | Scott | Home Built | 15 | August 29th 06 02:58 PM |
Metric Aircraft Nuts and Bolts | John Scott | Soaring | 6 | December 14th 05 08:54 PM |
Oversized bolts | Kjell Sivertsen | Owning | 7 | April 14th 05 05:02 AM |
Source for Bolts | Dave | Home Built | 2 | May 20th 04 08:09 PM |
