Why 4130 tube?
Old March 18th 04, 02:19 AM
Leon McAtee
Default Why 4130 tube?
Why do we homebuilders use 4130 tube? My old Aeronca does just fine
being made of mild steel. A bit of napkin calcs says that going up
just one tube diameter for the size tube we normally use, the area,
and the strength/weight goes up between 15% and 20%. This pretty
much offsets the difference in tensile strength between 4130 N and
1026, and more than offsets it for something like 1040. The "mild
steels" can be welded using MIG or TIG with little worries about HAZ
and since we are not heat treating the 4130 to obtain its strength
advantage it seems to me to actually be a poorer choice for amateur
aircraft construction.
For a typical rag and tube plane, properly choosing the tube sizes
should result in a weight gain of less than 15% for the same strength
which is, what, around 20 pounds for something like a Tailwind or
Aeronca. This to me seems like a good trade off to eliminate the
possibility of cracked welds due to poor technique. Not to mention
maybe saving a few bucks and being able to get the steel locally.
Could the availability of cheap WWII surplus steel have created a
tradition that has persisted in spite of other possibly superior
options?
Driving sheet-metal screws into 4130 Grandpa B. Home Built 10 February 3rd 04 07:23 PM
4130 Chromaloy Sheet Availability c hinds Home Built 1 January 24th 04 04:17 AM
Tube Cluster Weld Question Dick Home Built 6 January 17th 04 12:10 AM
Pitts Special Steel Tube Fuse Mod. Martin Morgan Home Built 0 November 23rd 03 11:08 PM
4130 frame? Steve Thomas Home Built 23 August 27th 03 05:50 PM
