Warrior cruise RPM settings
Old October 7th 05, 06:18 AM
Morgans
"Jay Honeck" wrote \\
Perhaps you have a cruise prop on both aircraft, Ben? You shouldn't be
exceeding red line simply by going to full throttle in level flight,
*unless* your prop has been pitched differently than stock.
That would be a climb prop, wouldn't it? I thought a cruise prop had more
pitch to keep from overspeeding during level cruise, and a climb prop had
less pitch (or diameter) to let the engine spin up to maximum RPM's (and HP)
during the normally slower RPM, higher load climbs.
  #33
Old October 7th 05, 02:44 PM
Seth Masia
Cooling shock is, IMHO, an overblown issue in normally aspirated airplanes.
Coming east over the mountains, I regularly descend from 13,000 to land at
5300 -- and my cylinders are still tight 500 hours over TBO. It's a plain
vanilla O-540, severely understressed, and I baby it by running lower rpm
most of the time.
Seth
Comanche N8100R
"Morgans" wrote in message
"Nick" wrote
I would believe most owners (including myself) are more concerning with
proper leaning, cold shock, and sloppy pilot landings & takeoffs. Those
factors will bite into an owners & FBO's pocketbook.
How does cooling shock show up, in a diagnostic/ overhaul/ shortening of
engine life, if you know what I mean? What parts suffer, and how do you
know other than tearing down the engine? (short of having it seize on you)
I have my guesses, but am probably at least partially wrong, and possibly
totally wrong. g
  #34
Old October 7th 05, 09:18 PM
lardsoup
New Jersey. So far, 20 public fields, one landing at Lakehurst NAS and a
low approach at McGuire AFB.
  #35
Old October 9th 05, 07:13 AM
Seth Masia
Then you're burning more fuel than you need to for no perceptible
performance gain.
"lardsoup" wrote in message
Sorry but I don't see your point.
  #36
Old October 9th 05, 11:59 PM
Greg Copeland
most of the time.
IIRC, Rod Machado also has the same sentiment about the subject. His take
is if shock cooling was a major factor, twins used for training should
constantly have a problem with once engine dying before the other....but
as he sees it, most training twins see TBO or better for both engines.
Greg
Transmittion Noise - High Power Settings Paul Smedshammer Owning 6 August 20th 05 06:17 PM
Lycoming's views on best economy settings [email protected] Piloting 37 July 8th 04 04:00 PM
Power settings for 182RG Andrew Gideon Piloting 19 March 3rd 04 07:41 PM
Cessna 404 Cruise settings Katia General Aviation 0 December 19th 03 05:04 PM
L-nav Settings Ventus 2ct-18 Oliver Peters Soaring 4 July 18th 03 04:14 AM
