#31
"Peter Clark" wrote in message ...
Doesn't removing the transponder from the tray disconnect it from the static system and thus require a re certification under 91.411(2) before it can be used IFR in controlled airspace? No. |
#33
YES
"John R. Copeland" wrote in message news ![]() ... Doesn't removing the transponder from the tray disconnect it from the static system and thus require a re certification under 91.411(2) before it can be used IFR in controlled airspace? No. |
#34
"kgruber" wrote in message ...
YES Your transponder has a barometric encoder *inside* it? I've never had one like that. |
#35
Peter Clark wrote:
On Tue, 18 Oct 2005 08:37:43 -0700, wrote: My take is that once a transponder acts up like that, it's time to have it bench checked. With a light aircraft panel mount, the owner could certainly remove the unit and take it to the avionics shop. Doesn't removing the transponder from the tray disconnect it from the static system and thus require a re certification under 91.411(2) before it can be used IFR in controlled airspace? KT-76 does not have an internal altitude encoder and thus it does not have any connections to the static pressure system. IIRC, disassembling the front panel needs a couple of small hex keys to handle the control knobs. The OP's problem sounds like the IDENT push switch is loose or broken - a clear case for an avionics shop. -- Tauno Voipio (CPL, avionics engineer) tauno voipio (at) iki fi |
#36
John R. Copeland wrote:
"kgruber" wrote in message ... YES Your transponder has a barometric encoder *inside* it? I've never had one like that. Ackshully, it's 91.413(b). Removal from the panel (and reinstallation) can introduce data correspondence error between the encoder and the transponder. So it must be checked. A log entry referencing transponder work should contain or be followed immediately by an entry referencing 91.413. |
#37
Jose wrote:
As to a transponder, and its vitial importance to the system (and to my TCAS when sharing the airspace with VFR aircraft) a transponder's proper functioning has importance to everyone using the system. Your proper tire inflation does not. Improper tire inflation can have a significant adverse impact on the system and on safey, especially at busy airports such as those in class B. Improper fueling can too, but I do fuel my own aircraft on occasion rather than pay a professional. The issue isn't whether the item in question is of "vital importance" but whether it is simple or tricky to fix, which relates to the likelyhood of a non-pro causing problems. It is not unreasonable to expect that a stuck ident button is simple to fix. It is also not unreasonable to expect that it could be tricky to fix. Therefore the question is perfectly reasonable, and replies should be helpful rather than insulting. Jose The issue isn't whether and item is of "vital importance", or whether it is simple to fix. The issue is whether an owner/operator holds the privilege to perform a task. The FARs allow an owner/pilot to air up his tires, service struts, do a little brake work, touch up paint, fix interior items, etc. The FARs allow the owner/pilot to remove and install a panel-mounted radio. They prohibit him from repairing it (other than tightening a knob or touching up paint). If he makes a repair and notes it in the aircraft records, the FAA has three years to catch him. If he makes a repair and makes no entry, he commits fraud, and the FAA can prosecute at any later date. Parts 1, 43, and 91, as related to preventive maintenance, maintenance, repair, and entries; part 13 as to violations. |
#38
Dale Scroggins wrote:
Jose wrote: As to a transponder, and its vitial importance to the system (and to my TCAS when sharing the airspace with VFR aircraft) a transponder's proper functioning has importance to everyone using the system. Your proper tire inflation does not. Improper tire inflation can have a significant adverse impact on the system and on safey, especially at busy airports such as those in class B. Improper fueling can too, but I do fuel my own aircraft on occasion rather than pay a professional. The issue isn't whether the item in question is of "vital importance" but whether it is simple or tricky to fix, which relates to the likelyhood of a non-pro causing problems. It is not unreasonable to expect that a stuck ident button is simple to fix. It is also not unreasonable to expect that it could be tricky to fix. Therefore the question is perfectly reasonable, and replies should be helpful rather than insulting. Jose The issue isn't whether and item is of "vital importance", or whether it is simple to fix. The issue is whether an owner/operator holds the privilege to perform a task. The FARs allow an owner/pilot to air up his tires, service struts, do a little brake work, touch up paint, fix interior items, etc. The FARs allow the owner/pilot to remove and install a panel-mounted radio. They prohibit him from repairing it (other than tightening a knob or touching up paint). If he makes a repair and notes it in the aircraft records, the FAA has three years to catch him. If he makes a repair and makes no entry, he commits fraud, and the FAA can prosecute at any later date. Parts 1, 43, and 91, as related to preventive maintenance, maintenance, repair, and entries; part 13 as to violations. Should have checked Part 43, App. A before I replied. Section 31 says he can remove panel-mounted radios EXCEPT transponders and DMEs. I'm not sure now he can even tighten knobs or touch up paint. |
#39
True, and driving that issue is what I said above. The OP was merely asking a question which should not bring the wrath of usenet upon him (lotsaluck!) nor does it indicate any kind of disregard for the FARs. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#40
![]() Jose wrote: The issue isn't whether and item is of "vital importance", or whether it is simple to fix. The issue is whether an owner/operator holds the privilege to perform a task. True, and driving that issue is what I said above. The OP was merely asking a question which should not bring the wrath of usenet upon him (lotsaluck!) nor does it indicate any kind of disregard for the FARs. My my perch it indicated either an igorance or predisposition to disregard the FARs. You are very kind to conclude that it simply did not indicate any kind of disregard for the FARs. |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Operation without a transponder | flyer | Piloting | 11 | September 14th 04 08:48 AM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Transponder petition | Ian Cant | Soaring | 11 | February 28th 04 06:38 AM |
More on transponder petition | Ian Cant | Soaring | 1 | February 27th 04 06:37 PM |
