#31
On Mar 2, 11:57 am, wrote:
Is this SOP publicly available? No. |
#32
On Mar 2, 12:40 pm, Sam Spade wrote:
You should look at the airport and airspace at issue. I did. |
#33
On Mar 2, 12:42 pm, Sam Spade wrote:
I didn't say that it necessarily does. I can also understand why SoCal and KRAL tower don't want to do it.- Why do you believe they don't want to do it? |
#34
An IFR clearance can certainly be given to a departure in
Class G that is under or abuts. You can often contact ATC and get a void time, either over the telephone or by radio if there is a near-by facility. The clearance would be something like ... ATC clears N6662U to enter controlled airspace on heading 270 at 3000 feet. Cleared to the XYZ airport, via . Contact 128.975. Clearance void if not airborne by 1730, time now 1715. wrote in message s.com... | Recently I tried to depart from an non-tower airport that has no | instrument approach procedure, and hence no instrument departure. I | was told that I could not get a clearance on the ground, even with | VIFNO etc., and that I would have to depart VFR and pick my clearance | up while airborne. The recommendation made to me by both TRACON and | local FSDO for departing IFR with a low ceiling was to get a special | VFR clearance into the towered airport 6 miles away [which has an | approach and then depart IFR from there. | | My question is, if I take responsibility for staying away from the | rocks [assume a low ceiling, above the tops of small hills, but below | minimum vectoring altitude], shouln't I be able to get a clearance on | the ground? | | Alan, PP-AMEL-IA | |
#35
On Mar 2, 1:04 pm, wrote:
I just got off the phone with a supe for that sector. She was very "firm" that there is no SOP and no clearances will be provided. That's odd, Southern California TRACON Order 7232.2B STANDARD OPERATING PROCEDURES, dated 2/26/04, is still available through the FAA Facility Directives Repository. |
#36
On Mar 2, 1:19 pm, "Steven P. McNicoll"
wrote: That's odd, Southern California TRACON Order 7232.2B STANDARD OPERATING PROCEDURES, dated 2/26/04, is still available through the FAA Facility Directives Repository. And it shows the last update was on 1/2/07. |
#37
wrote: That's odd, Southern California TRACON Order 7232.2B STANDARD OPERATING PROCEDURES, dated 2/26/04, is still available through the FAA Facility Directives Repository. And it shows the last update was on 2/1/07. |
#38
On 03/02/07 09:51, Steven P. McNicoll wrote:
On Mar 2, 10:35 am, Mark Hansen wrote: On 03/02/07 08:04, Steven P. McNicoll wrote: You asked what he meant and I told you. Sheeesh. I didn't ask YOU what he meant. What qualifies you to speak for someone else? Sheeeeeesh. This is a news group. You asked what it meant - I told you. Get a clue. |
#39
![]() "Mark Hansen" wrote in message ... This is a news group. You asked what it meant - I told you. Get a clue. And I gave you some news, so get a clue yourself. |
#40
![]() "Sam Spade" wrote in message ... You would have to ask the TARCON and FSDO the original poster dealt with. I can only ask you to clarify what you wrote. |
Departure procedures notice | Jim Macklin | Instrument Flight Rules | 12 | January 27th 07 02:57 PM |
Fedex Departure (MCO) | Glen in Orlando | Aviation Photos | 0 | November 29th 06 11:13 PM |
Alternate same as departure? | dlevy | Instrument Flight Rules | 34 | December 11th 04 01:15 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
gliding back to your departure airport | Harold | Piloting | 34 | October 24th 03 11:12 PM |
