Bad timing...
Old March 9th 07, 07:13 PM posted to rec.aviation.piloting,rec.aviation.owning
David Lesher
Default Bad timing...
"Jay Honeck" writes:
Anyone know if it's possible for a brake to hang up and not release,
resulting in advanced wear like this? Or should I keep blaming Mary
for riding the (right) brake?
Yes. In cars, this is often caused by the caliper rusting.
That's caused by a) road salt b) water in the brake fluid.
Hence the recommendation to flush the fluid every 2 years.
I've read both the 'rotor runout' and seal material explanations
for retraction; I suspect there's some of each. In any case, with
no pressure/drag - i.e pads skipping along; there's very little if
any braking action.
The constricted hose IS a known problem if a rare one. I think
newer hoses/neopreme may have solved the issue.
Do NOT overlook master cylinder/pedal issues. One of those
old batttries wedged under the pedal and.......
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old March 10th 07, 04:33 AM posted to rec.aviation.piloting,rec.aviation.owning
Peter Dohm
any braking action.
And a few cars, such as Corvettes in the middle 1960s, were reputed to have
springs inside the calipers so that the pads would not retract. This was
supposed to keep the pads and disks cleaner and drier, with only a very
slight increase in the rate of wear.
I never owned one and don't know how well it worked.
Peter
(Anticipating the obvious question)
timing holds [email protected] Instrument Flight Rules 16 February 17th 05 12:18 AM
Approach Timing john smith Instrument Flight Rules 36 September 9th 04 03:37 PM
Timing light for electronic ignition Ron Home Built 4 August 20th 04 05:18 PM
internal timing of slick magneto Jerry Jensen Home Built 1 June 25th 04 07:59 PM
Timing on Subaru EJ22 ??? Randy Rotorcraft 1 November 9th 03 06:15 AM
