#31
#32
"Matt Whiting" wrote in message
news ![]() Just be careful as often the engineer designed the bolts to be the "fuse" in the system. Replacing a grade 3 or 5 bolt with grade 8 can be akin to replacing a fuse with a penny. It may not hurt for a long time, but there comes the day... And you know this how ???? Example ??? Rich S. |
#33
Rich S. wrote:
"Matt Whiting" wrote in message news ![]() Just be careful as often the engineer designed the bolts to be the "fuse" in the system. Replacing a grade 3 or 5 bolt with grade 8 can be akin to replacing a fuse with a penny. It may not hurt for a long time, but there comes the day... And you know this how ???? Example ??? Rich S. Not tryoing to start an argument---but maybe it's better to jerk the tailwheel off the spring, than to jerk the spring out of the ass of the airplane!--Jerry |
#34
Jerry Wass wrote:
Rich S. wrote: "Matt Whiting" wrote in message news ![]() Just be careful as often the engineer designed the bolts to be the "fuse" in the system. Replacing a grade 3 or 5 bolt with grade 8 can be akin to replacing a fuse with a penny. It may not hurt for a long time, but there comes the day... And you know this how ???? Example ??? Rich S. Not tryoing to start an argument---but maybe it's better to jerk the tailwheel off the spring, than to jerk the spring out of the ass of the airplane!--Jerry Good thinking, Jerry. Rich S., I know this because I'm an engineer. Here's an example: http://www.howard-australia.com/products/Jaylor.htm Bolts designed to fail in shear and protect more expensive components are very common. A quick Google search should have easily convinced you of this. You are familiar with Google, right? |
#35
"Matt Whiting" wrote Bolts designed to fail in shear and protect more expensive components are very common. A quick Google search should have easily convinced you of this. You are familiar with Google, right? I can certainly understand the value of a shear pin, in rotable machines. I'm not so sure of the value in the case of a tailwheel. If you were to hit a tail wheel hard enough to shear an axle in the tail wheel, the force that did that damage is still going to be there, and is going to continue pressing the tail wheel spring, until all the force has been dissipated. -- Jim in NC |
#36
" Someone discovered that if you replace that
AN bolt with a CAT bolt, voila, problem solved. " That would indicate that the tail does not break off instead of the bolt breaking, after a stronger bolt is used. |
#37
news ![]() Rich S., I know this because I'm an engineer. And I'm not - that may be why I asked. Here's an example: http://www.howard-australia.com/products/Jaylor.htm I notice that they make a point of stating that the bolt is a shear bolt. Must be a bit unusual if they feel the need to mention it. Bolts designed to fail in shear and protect more expensive components are very common. A quick Google search should have easily convinced you of this. You are familiar with Google, right? I don't remember getting snotty with you, Oh mighty engineer whose unreferenced opinions are above question. One more question - why should I do the search? You made the statement and I simply asked for a reference. I did not **** in your cornflakes. Stay away from mine. Rich S. |
#38
Rich S. wrote:
"Matt Whiting" wrote in message news ![]() Rich S., I know this because I'm an engineer. And I'm not - that may be why I asked. Here's an example: http://www.howard-australia.com/products/Jaylor.htm I notice that they make a point of stating that the bolt is a shear bolt. Must be a bit unusual if they feel the need to mention it. Bolts designed to fail in shear and protect more expensive components are very common. A quick Google search should have easily convinced you of this. You are familiar with Google, right? I don't remember getting snotty with you, Oh mighty engineer whose unreferenced opinions are above question. You are confusing matter-of-fact with snotty. One more question - why should I do the search? You made the statement and I simply asked for a reference. I did not **** in your cornflakes. Stay away from mine. You should do your own search as you should never trust answers you see posted in a newsgroup. I never touched your corn flakes? What is your problem? Matt |
| Thread Tools | |
| Display Modes | |
| Needed 4 socket cap bolts | Udo | Soaring | 2 | November 29th 07 03:21 PM |
| Torque for prop bolts | Scott | Home Built | 15 | August 29th 06 03:58 PM |
| Metric Aircraft Nuts and Bolts | John Scott | Soaring | 6 | December 14th 05 09:54 PM |
| Oversized bolts | Kjell Sivertsen | Owning | 7 | April 14th 05 06:02 AM |
| Source for Bolts | Dave | Home Built | 2 | May 20th 04 09:09 PM |
