#41
("David Lesher" wrote)
It might be interesting to take a container with some small quantity of gas-damp kitty litter and ignite it safely -- ie well clear of any burnable stuph and with a 6' pole to set it off. Jim is "out there" in California. He might want to hold off on the kitty litter fire, until the other fires are put out. -- Montblack |
#42
("G.R. Patterson III" wrote)
You forgot - he's gonna fill it with fuel cell foam. :-) .....after he puts a cement weight in the bottom of the can!! -- Montblack "Styled by the laws of nature.............Concorde" |
#43
![]() "Montblack" wrote in message ... Whatever you choose, just separate the heating thing from the thermal mass pan thing. It isn't clear to me that evaporating the fuel is what you want to do. A coffee can of liquid fuel is a whole lot better than a enclosed space full of fuel vapor. |
#44
On Sun, 26 Oct 2003 11:09:13 -0800, Jim Weir wrote:
Hm. I guess I could rotate the whole airport so that my hangar faces lefthand UPHILL instead of downhill, but it is going to take a moby-large bulldozer to do it. My hangar slopes slightly downward toward the left wing. I just park my 182L (LR tanks) with the left wheel sitting on a 1/4" x 12" x 6" chunk of plywood. Even without the plywood, mine only drips if it is brim full, or if the temperature increases by 40 degrees F or more since it was fuelled. It doesn't drip if the temperature drops, or if the fuel level is below or just even with the bottom of the filler neck, at which point you can only jam in another 2-3 gallons per side. MikeM Skylane '1MM |
#45
Plus the EPA is gona get ya for air pollution.
Ron Natalie wrote: "Montblack" wrote in message ... Whatever you choose, just separate the heating thing from the thermal mass pan thing. It isn't clear to me that evaporating the fuel is what you want to do. A coffee can of liquid fuel is a whole lot better than a enclosed space full of fuel vapor. |
#46
![]() ("Ron Natalie" wrote) It isn't clear to me that evaporating the fuel is what you want to do. A coffee can of liquid fuel is a whole lot better than a enclosed space full of fuel vapor. You're probably right. There just aren't many airplane projects that start by mixing up a small bag of Quick-Crete. -- Montblack "Styled by the laws of nature.............Concorde" |
#47
"Jay Honeck" wrote in message news:ud0nb.38050$Tr4.78719@attbi_s03...
You guyzes is clever. Thanks. All this, and the solution is a gas can with a funnel stuck in it? Geez, after this many days, I thought for sure you guys would come up with a more "Jetson's-like" solution for Jim... :-) Well, back when I worked for Spacely Sprockets we used a gas can with a built-in, nuclear powered, matter disintegrator (with a funnel stuck in it). John Galban=====N4BQ (PA28-180) |
#48
How about dripping into a coffee can of water w/dishsoap. Should
emulsify and mix w/the water. You could even add the funnel idea into the plastic lid. -- Kevin McCue KRYN '47 Luscombe 8E Rans S-17 (for sale) -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
#49
![]() I thought about this one for a while, and thanks to all of you who chimed in. Between the lot of you, I came up to what is an optimal solution for me. In the first place, I am clumsy. I can trip over my own shadow. If there was a way for me to kick a can over and spill all the trapped gasoline, I would. In the second place, I am one with Ron Natalie who opined that liquid gas is a hell of a lot safer than gas fumes. The problem then is not to evaporate the spill, but to contain it. So down I goes to the local Auto Zone and there staring me in the face is a small (5 quart) oil change drip pan -- the round "pancake" style. There in the center of the pancake is a small round "oil drip" hole just made to put a funnel into. Viola. Problem solved. You can't kick over something that is a foot in diameter and 2 inches tall. You have a capped pour spout at the end to pour the liquid gas into your lawnmower. You could fill it with dishwasher soap and water to emulsify the fuel if you wished. You could fill it with half a quart of used oil and let the fuel absorb into the oil with a much lower flash point and practically zero evaporation. Thanks to all... Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#50
Jim Weir wrote: You could fill it with dishwasher soap and water to emulsify the fuel if you wished. I love the smell of napalm in the morning! -- Ben Jackson http://www.ben.com/ |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Fuel Drip Containment -- My Solution | Jim Weir | Home Built | 4 | November 1st 03 05:22 AM |
Fuel Drip Containment | Sven | Home Built | 28 | October 27th 03 10:28 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
