#41
![]() wrote in message ups.com... It looks like, practically speaking, the only way I'm going to be able to depart KRIR with a low ceiling is by going SVFR to KRAL first, then proceeding IFR from there. Receiving ATIS and TWR on the ground at KRIR is not an issue and, traffic and wx permitting they will provide a SVFR clearance for KRAL while I'm still on the ground at KRIR. Works if you can fly below 700 AGL into KRAL CDAS. And not at night. |
#42
Steve where did you find the SOCAL SOP?
Al "Steven P. McNicoll" wrote in message oups.com... On Mar 2, 9:53 am, wrote: Some specfics will be helpful now: the airport is Flabob, KRIR, field elevation 764 MSL. I spoke with several folks and each seemed to have a different take. The TRACON controller was the most helpful/ sympathetic; he told me his Minimum Vectoring Altitude in that area is 3200 [in addition to a small hill off the departure end of RWY 24 there are taller rocks to the North]. I heard from both the controller and local pilots that zero-zero departures used to be permitted until about 2 years ago and since then clearances while on the ground have been unavilable. Now the airport is only 10 NM SE of Ontario...so I'm guessing that my IFR departure off Flabob negatively impacts their inbounds into ONT until they have identifed me on radar or I'm through the MVA. I have suspected this is the funcamental I'm not permitted a clearance and that until 2 years ago there may have been a Letter of Agreement between ONT tower and SoCal departure that permitted Flabob IFR departures. If so, am I not getting a raw deal on "first come, first, served"? The current SOCAL SOP specifies a procedure for clearances for two airports without published departure procedures, Flabob and Perris Valley. The RIR procedure is, "Cleared to (destination), enter controlled airspace southwest of Fla-Bob. When entering controlled airspace, proceed direct RAL VOR, direct PDZ (remainder of route), maintain 4000' MSL, expect (filed or TEC altitude) 10 minutes after departure." I can find nothing else which mentions IFR departures from Flabob. BTW, the FSDO guy was the least helpful: "No instrument departure, no clearances on the ground." When I protested that this was clearly in error he just repeated what he said, adding some impatient attitude. That was the end of that conversation. Your experience with FSDO is not unusual. |
#43
On Mar 2, 1:43 pm, "Stan Prevost" wrote:
wrote in message ups.com... It looks like, practically speaking, the only way I'm going to be able to depart KRIR with a low ceiling is by going SVFR to KRAL first, then proceeding IFR from there. Receiving ATIS and TWR on the ground at KRIR is not an issue and, traffic and wx permitting they will provide a SVFR clearance for KRAL while I'm still on the ground at KRIR. Works if you can fly below 700 AGL into KRAL CDAS. And not at night. CDAS? The airports are only about 3 miles apart. Given a low ceiling rather than reduced vis, the topography and obstacles are not a problem. Departing KRIR from rwy 24 on a left 45 in seconds you are over the center of KRAL if that is your intent. But it is a pain-in-the-butt if time is an issue, if the vis is worse in that direction, if there is very low stratus to the South, as is sometimes the case. I'm still holding out hope that I can, under the right circumstances, get an IFR clearance on the ground, from KRIR. |
#44
Steven P. McNicoll wrote:
"Sam Spade" wrote in message ... You would have to ask the TARCON and FSDO the original poster dealt with. I can only ask you to clarify what you wrote. What I wrote was perfectly clear. |
#45
On Mar 2, 12:40 pm, Sam Spade wrote: You should look at the airport and airspace at issue. I did. Do you know where the closest SCT ASR antenna is to the OP's airport? |
#46
#47
On Mar 2, 12:42 pm, Sam Spade wrote: I didn't say that it necessarily does. I can also understand why SoCal and KRAL tower don't want to do it.- Why do you believe they don't want to do it? I said I can understand why they would not want to do it. It is more than a belief. I don't believe you understand the airspace issues in that area. It is different than Wisconsin. |
#48
![]() Sam Spade wrote: If controlled airspace was not involved you could do what you want. But, the rub comes in them providing you a clearance into (presumably 1200-foot floor Class E airspace without some procedure that assures obstacle clearance until reaching the minimum IFR altitude. Not ATC's problem. That's 100% on the pilot. |
#49
#50
On Mar 2, 11:57 am, wrote: Is this SOP publicly available? No. It would be with a FOIA request. |
Departure procedures notice | Jim Macklin | Instrument Flight Rules | 12 | January 27th 07 02:57 PM |
Fedex Departure (MCO) | Glen in Orlando | Aviation Photos | 0 | November 29th 06 11:13 PM |
Alternate same as departure? | dlevy | Instrument Flight Rules | 34 | December 11th 04 01:15 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
gliding back to your departure airport | Harold | Piloting | 34 | October 24th 03 11:12 PM |
