Sacrificial layer for gear-up protection.
Old May 15th 15, 07:59 PM posted to rec.aviation.soaring
Bill D
Default Sacrificial layer for gear-up protection.
Lets say you are deploying a retractible gear glider in a club with members who some might suspect of landing the thing gear-up someday. (Of course, you private owners never land gear-up...) Is there a way to minimize the damage when the inevitable day arrives?
Maybe. One of my favorite materials is UHMW-PE - a plastic with many superlative characteristics including astonishing abrasion resistance and a very low coefficient of friction. A 9mm thick strip, 150mm wide might very well withstand a gear-up landing of an 850 kg glider. It's also very light, cheap and a shade of white closely matching gel-coat.
Until recently, there was no way to glue this stuff to anything even itself but new epoxy adhesives have appeared on the market that advertize the ability to stick it to almost anything including fiber reinforced composite epoxy structures like glider belly's and wing tips.
So, obviouisly, some testing is in order before slapping a strip of UHMW-PE on the belly of your glider. A test rig on a pick-up's reciever hitch could slam a patch of it down on a concrete runway to simulate a gear-up. Anybody interested?
Old May 15th 15, 08:31 PM posted to rec.aviation.soaring
Bill,
Could you provide the brand name of the particular epoxy that will stick to this stuff? I would like to install a couple strips to the down-turned wing tip skids on my LS-3. The design of the tips makes it difficult to use mechanical fasteners.
Ron C.
Old May 15th 15, 08:42 PM posted to rec.aviation.soaring
Bill D
On Friday, May 15, 2015 at 1:31:32 PM UTC-6, wrote:
Bill,
Ron C.
Here's one - there are dozen more.
http://reltekllc.com/adhesivesforuhmw.aspx
Just Google "uhmw-pe epoxy adnesive"
Old May 19th 15, 12:28 AM posted to rec.aviation.soaring
Most gliders come with a sacrificial layer for protection. It is called rubber and it is on a little round thing tat you lower before landing. Checklists and mindfulness keep this thing as the number one protection against damage while landing! You could also install a steel plate but why, just use the wheel. Now the glide computers, independent micro switches and checklists are all guards against somehow forgetting to put the ship in landing configuration.
One poster wrote that radio warnings to a pilot on final is prohibited, really? If the verbal memonic check and the gear warning system were not working, I would want to know if my gear was up. I can fly and think, if I can safely lower the gear I would and have very low. If someone radioing you that your gear is up causes you to crash, the cause was not the radio transmission rather the pilot's failure to adequately aviate. If we adjust all radio transmissions for the absolutely lowest possible "skill" level, maybe we should require a higher skill level. I know accidents happen, but this is one that is avoidable with two checks before the radio transmission.
Old May 15th 15, 08:36 PM posted to rec.aviation.soaring
son_of_flubber
I've seen this eventuality addressed on an L-23 by putting a ziptie around the gear lowering handle.
Old May 15th 15, 10:29 PM posted to rec.aviation.soaring
Bob Pasker
all of the club retracts I've flown have had the handle disabled, either with a ziptie or with safety wire
Old May 15th 15, 11:22 PM posted to rec.aviation.soaring
Bill D
I don't think that's going to work with a Discus
Old May 15th 15, 11:23 PM posted to rec.aviation.soaring
Mike the Strike
Disabling an aircraft control sounds not only insane but likely also illegal.
Old May 18th 15, 12:52 AM posted to rec.aviation.soaring
GM
Slightly off topic but has entertainment value: Go tell that that to the mechanic who services the local CAP L23 and routinely safety-wires the canopy emergency jettison lever with SS-wire rather than thin copper wire which one could break .....
Old May 16th 15, 04:32 AM posted to rec.aviation.soaring
Bill T
Not the best idea for a Club LS4 going cross country.
BillT
Remove layer of cloth/Gelcoat glider[_2_] Soaring 1 February 9th 10 07:39 PM
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [1/5] - "01 Blackhawk--note optional 'real human feet' landing gear.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
composite using aluminum windowscreen layer Allan Morrison Home Built 4 January 27th 05 01:19 PM
sacrificial aluminum Rob Home Built 1 July 12th 04 09:45 PM
