![]() There has been a bit of a furore over here concerning the new US requirement to airlines to supply air marshals when requested. The concern is mainly over the possible puncture of a pressure cabin. What do readers think is the result of decompression via a bullet hole? Mike -- M.J.Powell |
"M. J. Powell" wrote: There has been a bit of a furore over here concerning the new US requirement to airlines to supply air marshals when requested. The concern is mainly over the possible puncture of a pressure cabin. What do readers think is the result of decompression via a bullet hole? Unnoticeable is almost all cases. A mild annoyance in the remainder, as long as we're discussing smallarm-caliber rounds. |
![]() "M. J. Powell" wrote in message ... There has been a bit of a furore over here concerning the new US requirement to airlines to supply air marshals when requested. The concern is mainly over the possible puncture of a pressure cabin. What do readers think is the result of decompression via a bullet hole? There won't be decompression via a bullet-sized hole. There are already a variety of leaks in the pressure vessel. There are simply some things which must penetrate the vessel. They're sealed reasonably well, but there's still some unavoidable leakage. The pressure is maintained by controlling the outflow of pressurized air. Another small hole will simply cause the control valve to close a bit to compensate. |
![]() What do readers think is the result of decompression via a bullet hole? Whose bullet? The American sky marshals (and presumably others) use frangible bullets, which wouldn't make a hole. The Brit argument is that the terrorist would use their guns in a "shoot-out" caused (of course!) by the sky marshal's gun. Okay, we've postulated that the terrorist has successfully smuggled a gun on board. Why is that? So he can crash the plane into a target? Could be, huh? So are you worse off risking explosive decompression, or of crashing into Times Square at midnight? As to the possibility of explosive decompression, as I understand the matter, it could happen if a bullet fractured a window (though not if it went through the skin). That's a mere possibility, as opposed to the certainty of a suicide dive, absent the sky marshal. A normal bullet hole would be no problem. There's already a much larger vent to the outside, which stabilizes cabin pressure against the fresh & heated air being pumped in from the engines. People smarter than I say that this hole is about three inches in diameter. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Cub Driver wrote in
: What do readers think is the result of decompression via a bullet hole? Whose bullet? The American sky marshals (and presumably others) use frangible bullets, which wouldn't make a hole. To the best of my knowledge,that's wrong;US Sky Marshals use .40 cal JHP (jacketed hollowpoint) ammo(premium,the good stuff),as they might need to penetrate some barrier that a hijacker hid behind. Frangible ammo can be defeated by some forms of clothing,or a shield.(briefcase?) -- Jim Yanik jyanik-at-kua.net |
![]() "B2431" wrote in message ... From: Cub Driver snip As to the possibility of explosive decompression, as I understand the matter, it could happen if a bullet fractured a window It would still be only annoying. A few ear aches and a lot of noise along with oxygen masks dropping. The person sitting next to the window might lose his reading material or dinner. This has been discussed here before and a Google search would turn up a lot of information. Dan, you are forgetting that there was indeed documented evidence of a passenger being sucked out of a blown window brought out during that discussion--a TAM Fokker F28 turboprop somwhere over Brazil (see: www.crashdatabase.com/cgi-bin/ webdata_crashdatabase.cgi?cgifunction=Search&Airli ne=%5ETAM%24 ). There was also a fatality during a 1989 Piedmont Airlines 737 rapid decompression (www.canard.com/ntsb/ATL/89A099.htm ). As to the non-fatal effexcts, the experience of an Aer Lingus 737 tends to point to some rather significant injuries during a 1999 depressurization accident, with lots of ruptured eardrums and severe nosebleeds, etc. I would not disagree that these potential problems are far outweighed by the threat of some whacko with a knife/bomb/etc., said whacko being dispatched by an air marshal, even with the remote potential of causing a rapid decompression being preferrable to the alternative. But the effect of such a decompression is likely going to a bit worse than cleaning your tray table off and causing a few earaches. Brooks Dan, U. S. Air Force, retired |
B2431 wrote:
: I agree a big chunk of skin suddenly departing the aircraft can cause major : damage and fatalities like the Hawaii Air stewardess deplaning prematurely. : There was also a case in the 1970s of a DC-10(?) where the aft cargo hatch blew : and took a row or two of seats with it. IIRC there have been incidents with the cargo hatches of DC-10s, but not limited to the loss of a number of seats; the entire aircraft was lost --- depressurisation of the cargo bay caused the cabin floor to collapse, destroying the control runs. As a result, modern aircraft were designed to have vents around the cabin floor. Emmanuel Gustin |
![]() "B2431" wrote in message ... From: "Kevin Brooks" Date: 1/1/2004 1:01 AM Central Standard Time Message-id: "B2431" wrote in message ... From: Cub Driver snip As to the possibility of explosive decompression, as I understand the matter, it could happen if a bullet fractured a window It would still be only annoying. A few ear aches and a lot of noise along with oxygen masks dropping. The person sitting next to the window might lose his reading material or dinner. This has been discussed here before and a Google search would turn up a lot of information. Dan, you are forgetting that there was indeed documented evidence of a passenger being sucked out of a blown window brought out during that discussion--a TAM Fokker F28 turboprop somwhere over Brazil (see: www.crashdatabase.com/cgi-bin/ webdata_crashdatabase.cgi?cgifunction=Search&Airl ine=%5ETAM%24 ). There was also a fatality during a 1989 Piedmont Airlines 737 rapid decompression (www.canard.com/ntsb/ATL/89A099.htm ). As to the non-fatal effexcts, the experience of an Aer Lingus 737 tends to point to some rather significant injuries during a 1999 depressurization accident, with lots of ruptured eardrums and severe nosebleeds, etc. I would not disagree that these potential problems are far outweighed by the threat of some whacko with a knife/bomb/etc., said whacko being dispatched by an air marshal, even with the remote potential of causing a rapid decompression being preferrable to the alternative. But the effect of such a decompression is likely going to a bit worse than cleaning your tray table off and causing a few earaches. Brooks Dan, U. S. Air Force, retired I was referring to the blown out window. The passenger you refer to was blown out a six foot hole according to your cite. Heh? "Pressurization was lost at an altitude of 33,000 feet when the right engine disintegrated, causing pieces of the engine to break two cabin windows." That does not a six foot hole equal. I agree a big chunk of skin suddenly departing the aircraft can cause major damage and fatalities like the Hawaii Air stewardess deplaning prematurely. There was also a case in the 1970s of a DC-10(?) where the aft cargo hatch blew and took a row or two of seats with it. Two windows is not a big chunk of skin. Neither was the Piedmont accident a "big chunk of skin", and a passenger still died. On the other hand in the late 1980s a C-141B departed Eglin AFB and a hatch over the cargo compartment blew. One of my men was standing directly below it at the time. He noticed sudden day light, very loud noise and a bit of pain. I believe the aircraft was at approximately 30 kilofeet at the time. It returned to Eglin, made a safe landing and everyone sent to the base hospital for evaluation. A cargo hatch blew out of a DC-10 in 1974, and it took a big chunk of the cabin floor above, with passengers, out of the aircraft--the rest of the aircraft then augered in. Face it, rapid decompression *can* (does not mean *will be*) be a very bad thing, even when it may just involve a window. Brooks Dan, U. S. Air Force, retired |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 7 | November 6th 04 08:34 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
Vacuum pressure | Peter MacPherson | Instrument Flight Rules | 1 | May 30th 04 04:01 PM |
Greatest Altitude without pressure cabin/suit | W. D. Allen Sr. | Military Aviation | 12 | July 26th 03 04:42 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
