At what rpm do people see their vacuum pressure drop below an acceptable
level(3.2?). I also have a standby vac with a low vac pressure red warning light. When I reduce power to 1200-1300 rpm the vac pressure drops off and the red light comes on. I thought in the past the pressure would hold until around 1000 rpm. Does this seem to be working properly? TIA, Pete |
![]() "Peter MacPherson" wrote in message = news:rrluc.26283$n_6.22507@attbi_s53... At what rpm do people see their vacuum pressure drop below an = acceptable level(3.2?). I also have a standby vac with a low vac pressure red warning light. = When I reduce power to 1200-1300 rpm the vac pressure drops off and the red light comes = on. I thought in the past the pressure would hold until around 1000 rpm. Does this seem to = be working properly? =20 TIA, Pete =20 I see 5 inches Hg at ground idle, either engine alone. Normally, your vacuum regulator should be able to maintain that. Check for leaks in your vacuum plumbing. ---JRC--- |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 7 | November 6th 04 08:34 PM |
Attn: Hydraulic experts - oil pressure relief fix? | MikeremlaP | Home Built | 0 | November 2nd 04 05:49 PM |
Vacuum "pressure" for gyros | Jari Kaija | Home Built | 3 | March 18th 04 05:08 PM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
