#41
Transponder
Peter Clark wrote: On Tue, 18 Oct 2005 08:37:43 -0700, wrote: My take is that once a transponder acts up like that, it's time to have it bench checked. With a light aircraft panel mount, the owner could certainly remove the unit and take it to the avionics shop. Doesn't removing the transponder from the tray disconnect it from the static system and thus require a re certification under 91.411(2) before it can be used IFR in controlled airspace? Correct. I missed that point but it was gnawing at me. Then again, I don't do stuff like that so I have no need to know. I leave it to those who hold the tickets. |
#42
Transponder
My my perch it indicated either an igorance or predisposition to disregard the FARs. You are very kind to conclude that it simply did not indicate any kind of disregard for
the FARs. Asking any question implies ignorance - not knowing the answer. It also implies a desire to find out the answer. If he had a predisposition to disregard the FARs, he would have merely pulled the panel himself and attacked the offending microswitch with a fork. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#43
Transponder
Jose wrote: My my perch it indicated either an igorance or predisposition to disregard the FARs. You are very kind to conclude that it simply did not indicate any kind of disregard for the FARs. Asking any question implies ignorance - not knowing the answer. It also implies a desire to find out the answer. If he had a predisposition to disregard the FARs, he would have merely pulled the panel himself and attacked the offending microswitch with a fork. I see it differently. Your assumption disregards possible damage to the unit by just going at it. He asked here because this place is anonymous. In reality, if he felt he was in the clear he would have asked around in person at his airport. |
#44
Transponder
I don't think you know why he asked. As for anonymous, the internet is anything but anonymous. If it were me, I would ask here because it is easy, asynchronous, and one can get quite a bit of useful information. It is also self-correcting inasmuch as bad advice is usually contradicted pretty quickly (though good advice is also contradicted), and by reading a bunch of replies one can get a good sense of whether the proposed course is worth pursuing. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#45
Transponder
: If it were me, I would ask here because it is easy, asynchronous, and
: one can get quite a bit of useful information. It is also : self-correcting inasmuch as bad advice is usually contradicted pretty : quickly (though good advice is also contradicted), and by reading a : bunch of replies one can get a good sense of whether the proposed course : is worth pursuing. Exactly. In order to get good advice from researching the 'net (which includes asking questions on usenet), one has to have a finely-tuned bull**** detector. This entire thread is a perfect example of why, when it comes to GA and the FAA/FAR's: #1: What's legal is not necessarily safe. #2: What's safe is not necessarily legal. ... or more eloquently as a friend of mine puts it, "Hi, we're with the FAA and we're not happy until you're not happy." -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#46
Transponder
Jose wrote: He asked here because this place is anonymous. I don't think you know why he asked. True, I don't know for certain, but I have a pretty good hunch. As for anonymous, the internet is anything but anonymous. At the level of this forum it effectively is quite anonymous. Maybe someone should start an avionics maintenance forum. ;-) |
#47
Transponder
I'd use a needle so you can dig into the tip (if visible) and move it into
position. If it's a mode S transponder, don't do anything. It'll probably snitch on you during your next flight. And remember the old Navy saying: If at first you don't succeed, get a bigger hammer. "Scott Migaldi" wrote in message ... Tom Cummings wrote: My King KT-76A transponder has a stuck "Ident" button. It stuck when activated for ATC on the last flight and the button appears to have colapsed sideways underneath the cover panel. It is no longer visible in the opening now. ATC says the unit indicates an "Indent" signal presently. Does this require an avionics shop to repair or could it be a simple matter such as removing the unit, then remove the cover plate and look for a colapsed return spring? Thanks, Tom Can you still see the button inside the panel? The plastic button usually just pushes on the switch below it, if you pushed to hard the button sometimes gets lodged underneath the panel. If that is the case just get a paper clip, open it up and use the end to see if you can realign the button so that it pops back through the hole in the plastic plate on the transponder. Then don't push so hard the next time you ident. If you have to open up the unit best to have the avionics tech do it unless you are familiar enough with the unit to try it yourself. -- -------------------- Scott F. Migaldi CP-ASEL-IA N8116B PADI MI-150972 Join the PADI Instructor Yahoo Group http://groups.yahoo.com/group/PADI-Instructors/ -------------------- |
Similar Threads | ||||
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Operation without a transponder | flyer | Piloting | 11 | September 14th 04 08:48 AM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Transponder petition | Ian Cant | Soaring | 11 | February 28th 04 06:38 AM |
More on transponder petition | Ian Cant | Soaring | 1 | February 27th 04 06:37 PM |
