Piper single axis autocontrol question redux.
Old April 27th 08, 10:43 PM posted to rec.aviation.owning
Mike Noel
Default Piper single axis autocontrol question redux.
Just to finish this thread, the fix for the bridle cable wraps slipping
around the aileron servo capstan was relatively simple. There is a recessed
set screw in the front face of the capstan holding the bridle cable locking
pin. The mechanic backed out the set screw with a .050 allen wrench, pushed
in and held the bridle cable locking pin with several snaps of a dimpling
tool (one of those tools you push until it snaps to create a dimple for a
drill bit), and tightened the set screw while pressure was kept on the
dimpling tool. All of this was done with the bridle cable locking pin
positioned so the pin was a the bottom of the capstan when the ailerons were
centered so the pin could not interfere with full aileron deflection.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Piper single axis autocontrol question. Mike Noel Owning 5 May 20th 08 10:06 PM
Piper PA-28 question GE Owning 14 September 21st 04 12:02 AM
A/D Question for Piper Cherokees zatatime Owning 6 June 11th 04 01:43 AM
Piper Autocontrol IIIB PaulaJay1 Owning 8 January 16th 04 09:43 PM
Autocontrol IIIB PaulaJay1 Owning 13 October 24th 03 02:39 PM
